Old 05-05-2009, 10:27 AM   #1
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Nice.
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-05-2009, 05:46 PM   #2
MGargano
Drives: 2009 Yaris Hatchback
Any ideas on where I can find a steering column cover that already has the opening for the cruise stalk? My car's basically brand new and I don't wanna mess up the OEM cover if I can help it.
MGargano is offline   Reply With Quote
Old 05-05-2009, 10:50 PM   #3
MGargano
try a scrap yard. you might get lucky and find one there if not there is always the dealership
Anybody know the part #?
Old 05-05-2009, 10:51 PM   #4
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i thought the cruise came through the steering wheel, not the column cover?
Old 05-05-2009, 11:06 PM   #5
Cover, Steering Wheel Boss, Lower: 45184-52130-B0
This is for one that has factory cruise control, (and it is the plastic back of the wheel, not the column cover).
Old 05-05-2009, 11:18 PM   #6
MGargano
Ohh so it's actually the back of the steering wheel, not the column cover? Doh! This fits & color matches the US 09?
Old 05-05-2009, 11:24 PM   #7
Yes.
Old 05-05-2009, 11:27 PM   #8
MGargano
Thanks, just ordered from TRDSparks. Should be getting the fogs, OEM combo stalk, shrouds, clutch switch, and boss this weekend to go with the cruise stalk. I figure I'll pull the steering wheel once and be done with it.
Old 05-05-2009, 11:34 PM   #9
nickhjort
nickhjort's Avatar
CTScott, I checked every pin (just to be sure) on those two IC's (IC500,IC501) and the pins for the blank spot where the third IC should go (IC502). Nothing :( they were all the same after I hit the Cruise switch. I grounded my meter to the frame and checked the pins with the red lead of the meter while it was on DC Voltage "20V" setting. That's how I do it right (I don't think I'm that dumb, but just to make sure) I guess it's not gunna happen the easy way as usual :)
My Car Rules!
Old 05-06-2009, 11:06 AM   #10
Sounds like you tested it correctly. As PK mentioned prior, there was little chance that it would be there, but it was worth a shot. I have to order some parts today for another project, so I'll order what I need as well to test my method of lighting your LED.
Old 05-09-2009, 10:17 AM   #11
I received the parts this week for lighting your LED, without changing your switch. I will be using a PIC12HV615 microcontroller to sense the switch press (and differentiate between the on/off and one of the other ones being pressed) and to drive the LED. The entire circuit will only require the 8 pin microcontroller, a transistor, and a few resistors (totaling maybe $5 in parts).
I will hopefully have some time this weekend to experiment. PM me your mailing address, and when I have it all figured out, I'll mail you the "module" (at no charge, since you've been the guinea pig for this).
Old 05-06-2009, 11:18 AM   #12
nickhjort
nickhjort's Avatar
Awsome. Thanks.
My Car Rules!
Old 05-06-2009, 11:47 AM   #13
stran
Drives: '07 Yaris 3D HB Auto
CTScott and nickhjort, you guys are awesome. keep up the good work.
this info is super helpful. i will do this on my car once i have some downtime. i have an 07 auto, FYI.
stran is offline   Reply With Quote
Old 05-06-2009, 12:43 PM   #14
nickhjort
nickhjort's Avatar
Thanks. It feels good to be able to actually help for once instead of just sucking in all the information and hard work of others to make my car better :) I like being one of the first to do a mod.
My Car Rules!
Old 05-06-2009, 01:27 PM   #15
MGargano
This is a little off topic but does anyone out there know where I can find the leather wrapped steering wheel? Even just the toyota part number would be great
Old 05-06-2009, 05:19 PM   #16
tk-421
tk-421's Avatar
Drives: 5D-07-LB
"a little off topic?"
Old 05-06-2009, 05:26 PM   #17
MGargano
Ok... a lot off topic. It's just that I'm pulling the steering wheel to install the cruise and fog light stalks, so I thought if I could find the leather steering wheel I'd be able to do it all at the same time.
Old 07-17-2009, 07:52 AM   #18
manta
Drives: Yaris 2009 5LB
I've seen here a question about the European Multimode (robotic transmission),
This guy had a 2007 model; I own the new 2009 face lifted (+new engine, new transmission) 2009 model NSP90L – CHLGKW, does anyone knows if its ECM supports Cruise Control?
10x
manta is offline   Reply With Quote
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
