Old 08-20-2009, 02:58 PM   #1
OK. With ignition power off, try reading resistance between the center wire and either of the outside wires. That will verify if you're actually making a good connection to the wire. You should see 48K ohms between the center and either outside wire.
Old 08-20-2009, 03:07 PM   #2
MGargano
Drives: 2009 Yaris Hatchback
Ok. Should I keep the sensor clamped for this exercise? And I assume I'm changing the setting on the multimeter from VDC to ohms?
MGargano is offline   Reply With Quote
Old 08-20-2009, 03:12 PM   #3
Correct on VDC to ohms. Clamping is fine - It won't have any effect on the readings.
Old 08-20-2009, 03:22 PM   #4
MGargano
Which setting am I putting the multimeter to?
I got a reading each time (center to left and center to right) with the black lead on center and the red on either outside wire but I have a feeling I have the meter on the wrong setting.
Old 08-20-2009, 03:26 PM   #5
Put the meter on 200K (always go to the next highest above what you are trying to see).
Old 08-20-2009, 03:45 PM   #6
MGargano
Ok, with the meter on 200k, black lead in the center, red on either outside wire, I got 4.4 both times. I tried a few times and the numbers kept bouncing around some, but the most consistent (when I held my hands steady) was 4.4.
Old 08-20-2009, 04:07 PM   #7
OK. So right now your SRS light is off, air bag off is lit, and passenger seat belt is lit?
Try disconnecting the battery for 2 minutes, reconnecting and then measuring the voltage on the center pin to ground. for a really solid ground you might want to pop the passenger kick panel and touch the black lead to the ground bolt there.
Old 08-20-2009, 04:13 PM   #8
MGargano
No, sir. All three lights, including the SRS, are still lit.
Old 08-20-2009, 04:32 PM   #9
Here's what I've found with the oscilloscope - Every 100ms the sensors transmit a packet of data. The beginning of the packet is always the same and the latter part varies based on pressure on the sensor.
Here are two sequential data packets from the front right sensor:
Here is one packet with no weight on the sensor:
Here is one packet with enough weight on the sensor for the airbag light to be lit:
Based on this I can easily build a module to simulate the sensors (and to switch between an empty and occupied seat).
Old 08-20-2009, 05:21 PM   #10
MGargano
I just tried this and registered nothing with the meter set to VDC. When I moved it to 200k ohms, it registered 6.0 between the center pin/wire and ground.
Old 08-20-2009, 05:51 PM   #11
It really looks like your OC ECU is not responding. Take a close look at all of the wiring to and from it. Look for any sign of a damaged wire.
Old 08-20-2009, 06:57 PM   #12
MGargano
I don't see any signs of damaged wiring or anything else out of the ordinary. I can't think of anything I might have done to damage it (dropping, etc) so I hate to think there's a problem with it. Should I start looking for a replacement?
Old 08-20-2009, 04:18 PM   #13
With the SRS, are you still seeing the DTC 32?
Old 08-20-2009, 04:23 PM   #14
MGargano
I just checked it. I now have 32, 55, & 56 again.
Old 08-20-2009, 04:30 PM   #15
You might want to check your resistors. I had trouble with mine not making great contact. I ended up shoving mine in through the wire side so they would fit tighter.
Old 08-20-2009, 04:31 PM   #16
MGargano
Ok, I'll try that. Then do the dreaded reset of the SRS ECU again?
Old 08-20-2009, 04:35 PM   #17
Oh yeah. I've gotten mighty good at doing it.
Old 08-20-2009, 04:36 PM   #18
MGargano
Haha! Feel like taking a road trip to Jersey and doing it for me?
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 03:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 06:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 03:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 02:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 05:07 PM
