#1 |
no show, no go :(
just passed 5k on my '12, and got my oil changed. no problems so far. will report back @ 10k!
![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
I got the yaris since 2007 until now. I just replace oil filer every 5k, trans oil every 15k, replace battery 45k, replace air flow sensor 50k. I still using original front brake pad with 72k. Fun to drive and avg 31mpg.
#3 |
![]() ![]() Drives: yaris sedan 09 Join Date: Jan 2010
yaris 08-sedan ATX
many oil change 30 000-miles = air filter 60 000miles= air filter+ flush oil for tranny+ new coolant+spark plug -front disk+pad / new drums+shoe -new tire (summer tire) -clean TB just regular maintenance now the car have 72 000 miles |
#4 |
![]() ![]() Drives: Mazda Protege5 Join Date: Jan 2007
We have updated our reliability stats for the Yaris to include owner experiences through September 30, 2012.
Repair frequencies, in terms of repair trips per 100 cars per year: 2010: 18 2009: 14, small sample size 2008: 26 2007: 33 All are better than average. We have two additional statistics, "Nada-odds" and "Lemon-odds," to indicate the percentage of cars with no repairs in the past year and those that required 3+ trips to the repair shop. For the years with enough data: 2008: 77, < 1 2007: 76, 3 We'll have further updates in February and May. With more owners involved, we could provide more precise information and provide all three stats for all model years. To see how competitors compare, and to sign up to help: Toyota Yaris reliability ratings and comparisons |
#5 |
125k miles on my 08 sedan.
Replaced water pump once and that's it so far! :D Everything else is your typical general overall maintenance
a.k.a. "Aothachos"
#6 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
120,000kms. only regular maintenance so far on my 08 sedan.
180,000kms on my 05 Echo sedan also no problems
Have Yaris will travel.. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
236,900 miles - regular maintenance (tires, battery, oil and filter changes, serp belt, spark plugs) --- other than that only Front Wheel Bearings at 110K miles and an Alternator at 159k miles.
#8 |
We've updated our reliability stats for the Yaris to include owner experiences through March 31, 2013.
Repair frequencies, in terms of repair trips per 100 cars per year: 2010 Yaris: 9, low 2009 Yaris: 22, low, small sample size 2008 Yaris: 24, low 2007 Yaris: 26, low We have two additional statistics, "Nada-odds" and "Lemon-odds", to indicate the percentage of cars with no repairs in the past year and those that required 3+ trips to the repair shop: 2008 Yaris: 77, < 1 2007 Yaris: 83, < 1 We'll have further updates in August and in November. The more owners participate, the more comprehensive and precise these will be. To see how competitors compare, and to sign up to help improve this information: Toyota Yaris reliability ratings and comparisons |
#9 |
I think its not the clutch per se but the drive by wire throttle system. My cable actuated ECHO was flawless. In my (automatic) Yaris takeoffs require finesse.
I hate to think what driving a YAris with a clutch would be like. Although manuals rule!
Synthetic Oil: Its All In Your Head |
#10 | |
#11 | |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
One benefit of the electronic throttle is acceleration take-over on cruise control in the highway. You don't have to floor the pedal to actually make the car go faster because the pedal "home" position will already be close to the speed you're cruising at. In short, on long drives when you set the CC on and take off your shoes, you only need a push of the toes to go from 120km/h to 140km/h for the passing. |
#12 | |
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Hmmm... Well, it sucks in cold weather. Best described as annoying, irritating.Revs high its not cool when my gear box is struggling.Notchy gear shifting but ok when warmed up. I have never had this problem before. Just now after close to 7 years of ownership. |
#13 |
My ECHO was a manual and the transmission shifted very smoothly. In fact when my legs and feet made shifting difficult I did a lot of shifting without the clutch whenever possible.
I sold the ECHO and bought a Yaris in order to get an automatic transmission because I figured if I kept shifting w/o the clutch I would ruin the transmission. But I often wonder if I had kept the ECHO would the trans have held up? I think the ECHO, for my purposes, was a better car other than the trans.
#14 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
I liked my Echo better. The Yaris isn't bad, but the Echo was better (both manual transmission cars).
#15 | |
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
2007 LB W/Cold Wx Package |
#16 |
The key thing is shifting at the correct RPM. If you do, then no harm done. You'll know, as it's smooth when done right.
#17 | |
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
As far as reliability goes, I'm at 85k miles and have only done oil changes and oil filter changes on the car since getting it. I've changed the cabin filter a few times and vacuumed the air filter. Don't mean to thread jack but are there other maintenance items other people reccommend? |
#18 | |
Clean the leaves and crap out of the windshield wipers shafts where they go into the body and that area or they will rot and rust the car over a long period of time. Also open the trunk and clean the rotting stuff around the rubber sealing strip. Open the hood once a month when you check the oil and look for pink coolaand splashes on the right bottom that indicated a leaking water pump. I take the car to the car wash four times are year for interior and experior cleaning and consider that maintenance now that Im too old to do it myself. You dont want a car like my wifes Camry with is filthy and has a trunk full of crap!
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
