#1 |
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
Thanks, good info as I'm still trying to decide on tires for this season!
racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
I wanted to do a back to back between my R1R's(195/50/15) with about 50 runs on them and my brand new z2's(225/45/16) to see how much of difference I would have between them.
The toyo R1R's have tons of grip but are a really really numb tire that doesn't have great turn in feel and requires lots of camber to work correctly. I was running at best 66.2 on my Toyos and the car was skiddish hard to control and very very loose. Tire pressure was set at 30 psi. Switching to the z2s later in the day after I had finished my runs on the R1Rs, the z2s were sharper had more overall cornering grip, but they didn't let go quite as easily as the R1Rs so the car didn't want to rotate very well at low speed. The biggest thing I liked about these tires was that I could get the slip angles pretty bad and it would still hold on, and I mean wheel cranked really really far over, the tire would just scream and eventually pull over, these tires require a lot of work to get the most out of them, but seem to be a touch heat sensitive(at least on my car). above 130 degree's they give up slighly. No where near as bad as the Toyo's but I didn't quite have the same results at the STX BMWs. Car setup Front Camber -3.5 degrees Caster 5 degrees Toe 0" Rear Toe .2" in Camber didn't bother checking Dunlops (42.5 psi) 16x7 OZ Chrono HT Toyo's (30 psi) 15x7 Kosei K1R I think Going over my data I was able to stay on the limit longer with the z2 than I was with the R1Rs. The r1rs seem to hold about 1.1gs according to the data and the z2 were holding 1.15 steady state but I did lose a bit of acceleration going to the taller tire. These results are subjective as the course was very very dirty in the morning when I ran the toyos, I was picking up OPR and rocks like no ones business, but it felt quite a bit more clean in the afternoon. The surface was asphalt so I don't know if the results will carry over to concrete. On a side note this was the first time I didn't have horrible shoulder wear on a tire after an AutoX run so at least for camber limited cars I would say the z2 is a good pick. Overall I think the Z2 is going to be a tire to have in the future. So I went further into my data and I was faster on the Toyos for the most part but I was having some pretty bad issues with the Toyos just letting go out of nowhere. Not sure if it was a course issue or not but it was something I was experiencing. Last edited by xnamerxx; 02-17-2013 at 11:33 PM. |
#3 |
hmmm. interesting info, Namer. Especially the last part about the toyos being a bit faster for the most part.
Damn. I really need to sell some wheels and do a little more prep work on the Yaris. I just signed onto SD regions' site, so I'll be looking to run some events there. I'll be alternating between the cars. hehe... in pursuit of learning and developing as a driver. Thanks for sharing your findings with the community. |
#4 |
0-60 in slow
i think there was something wrong with the course when i ran with the toyos, the car was really loose on the edge, almost like driving on dirt or oil.
#5 |
![]() ![]() ![]() Drives: 2012 Yaris SE Join Date: Nov 2011
Just wondering why you chose 42psi for the ZIIs? Seems very high for a light car like the Yaris. Dunlops also don't reach their prime until after a couple events or a couple weeks of street use.
#6 |
0-60 in slow
I varied the pressures from 38-45 and was fastest with 42. I treated them like the old Z1s for pressure and kept them on the high side.
At 42 I ran a 65.282 At 44 I ran a 65.537 At 38 I ran a 66.235 At 40 I ran a 65.713 Going with temps on the tires the center was still cold at 42 psi and even at 44 but the car felt quite a bit more stable transitionally at 42 than it did at 44 but at 44 it felt as if I could hold the corner better. Here is a screenshot of my fastest runs with both the Toyo and the Dunlops. For whatever reason I had more confidence driving on the Dunlops vs the Toyos, I'm pretty sure it was due to something on the track but I'll have to test this again at another place to be sure. Red is Toyo Blue is Dunlop
#7 |
Interesting. They'll get better with use. Is your site asphalt or concrete? Air temps?
#8 |
Namer, we could always do testing at Adams! !
Tuesday nights (and some saturdays as well) |
#9 |
0-60 in slow
I can do a sat, but the tues night ones are difficult for me since I get off work so late
![]() Air temps were mid 70s for the toyos and 80 or so for the dunlops. This sight was asphalt with track temps in the 80s for the toyos ad 90s for the dunlops. |
#10 |
Thanks Namer, great info and data. Our first test 'n tune is March 10 on a runway site but the rest are at the Meadowlands, which is smooth, perfect asphalt.
#11 |
NJ Drive, I'm with you on this one, most tires I have run need a heat cycle and a shelf time before all out running/racing. I've only experimented with R-Compound tires for the most part, Yokos, Toyos, and Kumhos, but all needed a heat cycle and then about 24-48 hours down time before racing on them. Tires would also last much longer this way too! Not quite sure what to think of the current crop of 140+ tread wear rated Street and Touring tires, but I'm looking to go a slightly different direction than most around here. I'm more than likely going to run Federal 595RS-Rs in the 195/50/15 size, due to our much shorter/ tighter coarses, where gear plays the biggest part.
http://www.performanceplustire.com/t...95_SLASH_50-15 racerb
#12 |
i LOVE my RSRs. I haven't run them during competition in autoX, but have at Adams (go-kart track) and have posted decent times with those.
What I like about them more than anything? The price. |
#13 |
You got that right!!
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
Yea, I enjoyed my RSR alot too. Still debating if I should get new ones or try a different tire
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
#15 |
Has anyone weighed their car in STF trim yet?
#16 |
Mine is still very stock, so in other words heavy! My plan is to kinda go with the Andy Hollis weight lose plan, replace driver's seat, lighter exhaust, >13 pound wheels, and hopefully lighter suspension. But hey with every pound making a difference, 50-100 pounds can be huge, so shouting for at least 100 lbs. removed.
racerb
#17 |
0-60 in slow
Yep, I was at 2160 at nationals. I still have the stock seats to replace and go lighter on the battery.
#18 |
Yeah. I figured three door 2nd gens are going to be 80 to 100 lbs lighter than me on average.
| How many posts till ChinoCharles locks this thread? | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 9 | 04-14-2009 05:54 AM |
| Reported posts | ChinoCharles | Suggestions - Feedback - Questions | 10 | 09-25-2007 07:48 AM |
