Old 05-05-2014, 07:39 AM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Matt I told you that way back when, everyone gets on me for running my shocks granny long back there but they love it lol
Old 05-08-2014, 06:59 PM   #2
mr_miles
Drives: 2013 Yaris
Lol yeah we learned our lesson after blowing enough of them out :p People get on me too when they see downward travel when I three wheel lol.
Old 05-13-2014, 07:02 AM   #3
1.5
Form>Function
1.5's Avatar
yea lol but we are pro's now lol we know what we're doing
Old 07-07-2014, 10:37 PM   #4
iceage
Drives: no car
is this the proper way to install the megan coilover?
iceage is offline   Reply With Quote
Old 05-08-2014, 06:49 PM   #5
JTGoodridge
Drives: 2002 Yaris
I have a question would all of these work on a 99-04 model Yaris?
JTGoodridge is offline   Reply With Quote
Old 05-13-2014, 02:46 AM   #6
FlushYaris
Drives: 07 yaris 3dr
ahaha I had the same problem with that washer!! It needs to go Under the bushing..
FlushYaris is offline   Reply With Quote
Old 06-19-2014, 01:39 AM   #7
Jerkratt
Jerkratt's Avatar
I really like the D2's. Tho they are my first set of coils I've had on a car of my own. With there adjustable height and dampening I can't complain
"It hurts more when its wet"
Old 07-08-2014, 12:35 AM   #8
mr_miles
Drives: 2013 Yaris
I don't recall that metal spacer going there, Pretty sure it goes directly underneath the top nut so you can tighten it with a regular wrench with everything assembled on a car.
Old 07-08-2014, 06:59 AM   #9
1.5
Form>Function
1.5's Avatar
im pretty sure I have the metal spacer on mine
Old 07-09-2014, 12:37 AM   #10
iceage
Drives: no car
can someone help me out and let me know how it should exactly look like? thanks
Old 09-18-2014, 12:27 PM   #11
JL512
Drives: Toyota Yaris
LUK Schaffer rotors were well priced and have been performing well so far after about 6 months of use. Installed them on my Toyota Yaris and they work just fine, definitely recommend.
LUK Schaffer
JL512 is offline   Reply With Quote
Old 12-17-2014, 08:39 PM   #12
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I thought it might be good to make a definitive thread for Yaris coilovers. This would include what's available and any input people have. Please add to the list if you know of any other available applications.
Here's what's Available:
D2 RS Coilovers
Height adjustable
36-way dampening adjustable
Spring rates: Custom
http://www.d2racing.com
H&R Street-Performance
Height adjustable
Preset dampening
Spring rates: ?????
http://www.hrsprings.com
KW V3 coilover kit
Height-adjustable
14-way dampening adjustable (compression)
Infantile adjustable rebound
Spring rates: ?????
http://www.kw-suspension.com
Tein Basics
Height-adjustable
Preset dampening
Spring rates (F/R, lbs./In.): 224/174
http://www.tein.com
Tein Super Compacts
Height-adjustable
16-way dampening
Spring Rates (F/R, lbs. ??/??)
http://www.tein.co.jp
Megan Racing
Height-adjustable
32-way dampening adjustable
Optional Pillowball mounts (requires some modification)
Spring rates (F/R, lbs./In.): 280/336
http://www.meganracing.com
K-Sport
Height-adjustable
Front pillowball mounts
Compression/rebound adjustable
Spring rates (F/R, lbs./In.): 392/140
http://www.ksportusa.com
Cusco Compact-S
Height-adjustable
Preset dampening
Upper pillow ball mounts
Spring rates (F/R, kgs./mm.): 7/3.3
http://www.cuscoracing.com
Cusco Zero-1
Height-adjustable
Pre-set dampning
Spring rates (F/R, lbs./In.):392/18x (?)
eBay generic coilover sleeves
Height adjustable, no shocks
http://www.ebay.com
SilkRoad RMA8
Height-adjustable
8 Step Dampening
Spring rates (F/R, kgs/mm): 7/4
http://www.silkroad-usa.com/
HKS S-Compact
Height-adjustable
30-way adjustable
Pillowball fronts
Spring rates (F/R, lbs./In.): 280/448
http://www.hks-usa.com or www.hks-power.co.jp
C-One Sports Suspension Kit
Non-height adjustable (spring/shock kit)
Adjustable dampening
Spring rates (F/R, kgs/mm): 3.8/2.6
http://www.c-one.co.jp
SO, WHAT ARE THE BEST LESS THAN 1K COILOVERS ?
I think I bent my left front strut from a severe turn last week....I can call the car Irene or Ilene now.
If afraid to comment on best, I drive all street, but typically drive it like I stole it, and occasionally carry some weight. Haven't towed with it yet, but if I do, will be light stuff, less than 500 pounds.
Old 12-18-2014, 04:25 AM   #13
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Been running Megan's for 4 years now. Autocross every month and a couple track day events a year. Still running strong.
-Derrick-
Old 12-31-2014, 09:40 AM   #14
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I've blown 2 megan coilovers (right rear twice) ��
I've even stop using the car on daily basis so I can get tomthe track with my 4 coilovers intact ��
I think I need some pics of your installed coilovers, I must be doing something wrong
I Drive a 129whp Yaris ;)
Old 08-18-2015, 03:46 PM   #15
0BD1Kenobi
Drives: 2012 Yaris SE
i havent seen a bc review in this thread yet and i just ordered mine today with swift springs 6k/4k ill have to take some pics when they come in!
0BD1Kenobi is offline   Reply With Quote
Old 08-18-2015, 03:49 PM   #16
Jerkratt
Jerkratt's Avatar
My friend is sponsored by them. Was going to get them.. Ended up not having enough ��. They should ride very well.
Old 08-18-2015, 05:23 PM   #17
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
This resurrection is really making me chomp at the bit to get my tanabes installed.
Sent from my SCH-I545 using Tapatalk
Old 09-09-2017, 05:16 AM   #18
JRHPNG
Work in Progress
Drives: 2010 JDM Vitz RS NCP91
Location: From NZ, currently working in Papua New Guinea
Score! Tein Coilovers
Snapped up this deal.. $300 NZD. Only 10,000km on them. Just need an OCD clean.
Tein low down spec light weight master basic compact (what a mouthful)
If coil overs work out (my first experience with them) I'll likely keep for a while and upgrade to a new set.
JRHPNG is offline   Reply With Quote
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1706 06-22-2025 05:33 AM
Shift lever thread size Chaad32 Cosmetic Modifications (Exterior/Interior) 16 01-30-2015 02:16 PM
Shift Knob Thread Patter? eight_heads General Yaris / Vitz Discussion 6 10-21-2009 10:25 AM
Post Whores-aka Yaris chat thread Black Yaris Off-topic / Other Cars / Everything else Discussions 21 07-12-2007 05:37 PM
Thread request - Yaris is new in the US makaluch Cosmetic Modifications (Exterior/Interior) 1 08-13-2006 12:16 AM
