Old 06-16-2013, 08:23 PM   #2503
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
Originally Posted by Denzel_m View Post
I dunna how to make a new post lol but I hope someone will be able to help me. I have a 2007 Yaris sedan. I'm not happy with the stock speakers, I have a sub running off the stock HU but I keep hearing distorted bass coming from the speakers in the back and the doors.
I was thinking about changing the speakers and leaving the HU stock I wanna keep the look. What speakers would you recommend? I need them to run off the HU so they should still be loud but with no bass. I'm thinking something with low watt rating and resistance. I dunna
Thank you
Near the top of the forum page, before the thread titles, there's a button labeled "new topic."
MyzticZ3r0 is offline   Reply With Quote
Old 06-18-2013, 03:52 PM   #2504
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Ok, so what I came through takes my system to a much better stage, the issue that I'm trying to resolve it's an issue related to my Yaris and my System, so it probably won't apply to other installs. but here we go....
So I was looking for a "WOW" factor in my system, first I thought adding a second sub would do it, but not really if I wanted to keep with Sound Quality and not starting fall into SPL (sound pressure level) I still would like to try a 2nd woofer in the near future.
After attending the SQ competitions in NY, a guy who listened to my system said... "some tuning is need it" and I think he said the word "ques" or some thing like that..
For a better understanding he was referring to the female voice followed by a "ppsssst" at the end of some words from the song coming from the female voice, kind of like you could tell the location of the female voice on the stage but at the end it drags to the left or right up and/or down.
So after this conversation I was really challenged on how to take care of this. He said tuning and x-over points but I was sure that something else was going on!
D.
CLA 250, 4MATIC
Old 06-18-2013, 05:21 PM   #2505
derickveliz2
So I found the what could be the "WOW" factor...
as mentioned above I found issues in my system that was or is not letting me have a good stage:
One day in my regular tuning session going through the frequencies and trying to center the image with the EQ I got stuck in a particular frequency... according to my Technic I play a Frequency into the Mids and Tweeters and with the Right & Left EQ I move up and down until I hear/feel the sound in the center of the stage (or at least where I feel it should be) but at some point...
I got stuck! it didn't matter how much I input I had on the EQ the noise was still hitting my LEFT ear no matter what! I started blocking the LEFT Tweeter with my hand thinking that this was the reason I was hearing the signal in my LEFT ear, but nothing...
By accident I moved my RIGHT hand up and down when I notice the signal fades away, "What's going on????" so I found out that the RIGHT Mid has a straight hit directly into the LEFT window and bounces back to my LEFT ear...
Later on I found the same issue with the LEFT Mid a straight path going between my legs and the bottom of the dashboard hitting the RIGHT window and then reflecting the signal to my Right ear.
I spoke with my brother who studies music in NY he understood the issue right away saying "First Reflection"!
I'll try to draw it later for better understanding!
D.
CLA 250, 4MATIC
Old 06-18-2013, 11:16 PM   #2506
derickveliz2
D.
Image 1:
Image 2:
D.
CLA 250, 4MATIC
Old 06-18-2013, 11:45 PM   #2507
derickveliz2
The temporary fix!
or should I say "taking care of some issues"
After doing this dirty improvised fix and some light tuning the stage gets a "WOW" factor!
Very solid, localizing vocals and instruments in the stage is fantastic!
So now comes the Design part! and how I'm going to address this issue in a proper way, I have some ideas!
stay tuned!
D.
CLA 250, 4MATIC
Old 07-16-2013, 12:14 AM   #2508
derickveliz2
Let my speakers breathe!!! I'm talking 63Hz - 160Hz...
After going through the experience in meca and iasca I got some good feedback from the judges, one that called my attention was...
-Your Lows (HAT L6 in doors) sound like if you put a piece of cloth over. And you know what? yes the sound wasn't perfect, so I start digging about it, tuning, x-over points R+L EQ and more tuning until I got them a little better but on the shy side.
-At high volume I could tell something wasn't right, and I was getting a rattle once in awhile, I checked the Baffles... very solid, I checked the Deadening in the doors... Overwhelming but I was still getting that little rattle at high volumes, I had to tame them down to prevent that ugly rattle I was getting, I'm not putting a huge amount of Watts but 175 watts to each driver go to go somewhere...
-One day I had my left hand rest on top of the window's controllers and I could feel some little pressure (wind?) coming out from the edges like a small vented box with a subwoofer ... mmm so it got me thinking "Is the internal air space of the door enough?"...
-These L6 are designed as "Free Air" AKA IB (infinite baffle). So maybe Yes! the door is not big enough for the L6's and that is the pressure I feel at high volume levels. Same as I did when I had my mids in spheres with not enough airspace.
-So lets them breathe! I made 3 big holes in each door next to an existing little hole that had a rubber cap sealing the door. See pictures below.
D.
CLA 250, 4MATIC
Old 07-19-2013, 08:34 PM   #2509
dragoonmc
Drives: 07 hatchback
I would put something behind those holes so that Water will not just drain into your door as it run down the seam between the doors
dragoonmc is offline   Reply With Quote
Old 07-25-2013, 11:45 PM   #2510
derickveliz2
I was thinking something like this:
D.
CLA 250, 4MATIC
Old 07-25-2013, 11:46 PM   #2511
derickveliz2
Everybody, a friend of mine in the car-audio world will have a mini-meet at my place it's going to be on 8-3-2013 from 3pm to 6pm and it's 15 minutes from Sturbridge MA.
Send me a PM if you are interested.
D.
CLA 250, 4MATIC
Old 07-26-2013, 03:21 AM   #2512
MyzticZ3r0
If only I lived on the East Coast..
Old 08-05-2013, 12:53 AM   #2513
derickveliz2
Turned out a good event!
There were other 2 SQ cars there besides the Yaris and one SPL
This was awesome to listen... I mean feel!
D.
CLA 250, 4MATIC
Old 08-05-2013, 12:54 AM   #2514
derickveliz2
D.
CLA 250, 4MATIC
Old 08-06-2013, 02:37 AM   #2515
derickveliz2
The super loud 4 woofers according to the owner hits 140db!
This is what we wrote to me after the meeting:
"I must say that Yaris is really impressive. Your hard work has really paid off! "
D.
CLA 250, 4MATIC
Old 08-13-2013, 01:04 AM   #2516
derickveliz2
I've been doing my home work too:
Blue is Before, Yellow is after (1st round at RTA)
D.
CLA 250, 4MATIC
Old 08-13-2013, 01:04 AM   #2517
derickveliz2
And this is how EQ end up:
D.
CLA 250, 4MATIC
Old 09-04-2013, 12:34 PM   #2518
derickveliz2
So I have a few requests for more detail pictures at the Big 3, so here we go:
From the Alt. to Battery:
D.
CLA 250, 4MATIC
Old 09-04-2013, 12:35 PM   #2519
derickveliz2
From the Engine Block to Ground:
D.
CLA 250, 4MATIC
Old 09-04-2013, 01:38 PM   #2520
sqcomp
Roadrunner Jr.
sqcomp's Avatar
On that posi stud coming out of the alternator.
I ran mine under the shroud as well. I have mine split loomed coming out of the alty and just before it reappears on the other side, I've used heat shrink and tech flex to "pretty it up".
― Thomas Paine
