Old 10-02-2006, 11:32 PM   #253
tca4
tca4's Avatar
Drives: Yaris RS (white)
Hmm a little confuse.. maybe someone with a DIY writeup would be excellent :D
tca4 is offline
Old 10-02-2006, 11:44 PM   #254
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
AHH here we go.
1) Disconnect negative battery terminal
2) Remove stock tail light assembly
3) Disconnect stock light plug from body side plug (the plastic plugs that snap together are known as the molex)
4) From the BODY side, disconnect each Female Molex Pin.
There is a total of 6 pins, and you will need to "map out" which wire matches up with the OPERATIONAL function of the each wire on the JDM tail light. Take a close look at the transplant page at http://www.k4.dion.ne.jp/~vitz/RStail.htm# to determine this.
The female molex pins look like slits. You can use a Female Molex Pin Removal Tool if you have one that works with pins this small, or you can use a sewing needle, flat head microscrewdriver, or some other tool that is thin enough (and sturdy enough) to push down the clips that lock each pin it its original molex.
5) After you have removed all female molex pins from the original molex connector, fix each molex pin by pulling the clips back out a bit so that it can lock in place.
6) Connect each female molex pin into the JDM connector for the tail lights following the "map" from the transplant page. This is very important, do not mix up where your wires should go. Refer to the transplant page and double check that the body side wire matches the corresponding function the JDM light side wires are intended for.
7) Each female molex pin should snap into your JDM connector and be secure.
8) Connect your new body side molex (plug) into the JDM tail light molex (plug)
9) Reinstall your tail light, reconnect negative battery terminal, and give it a go!
It sounds complicated, but it is real easy. Hyde wasn't lying.
The most painful part is removing the female molex pin connectors from the body side molex (plug). It takes about 5 minutes per pin if you don't have the proper tools.
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline
Old 10-03-2006, 12:04 AM   #255
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
A hair clip (those tiny black ones) will do the job of removing the pin from the connector!
Your wife/gf/whatever should have one. :)
So all the harness, bulbs and connectors are in the package ready to go? Just have to reconnect them? That sounds easy!! Waiting for some pics!
GabL is offline
Old 10-03-2006, 12:09 AM   #256
bigsky2
Cousin Vitz
bigsky2's Avatar
Good one GabL.. I've got a few on my wallet because I keep finding them in my car.
Yes, all the bulbs are in place. It's basically plug and play after dealing with the pin/molex issue.
bigsky2 is offline
Old 10-03-2006, 12:15 AM   #257
bigsky2
Cousin Vitz
bigsky2's Avatar
I would install mine tonight, like right now, if I had BOTH assemblies here.
But for some weird reason I only received the left side, and the right one is still being held by my best friends at Canada Customs.
bigsky2 is offline
Old 10-03-2006, 02:51 AM   #258
tca4
tca4's Avatar
So is connector that came with the tails the one that we order for $15?
tca4 is offline
Old 10-03-2006, 03:40 AM   #259
Linkseal
Drives: DBA-NCP91
Send a message via MSN to Linkseal
My friend's VITZ in HK with close look at LED tail...
Linkseal is offline
Old 10-03-2006, 04:23 AM   #260
bigsky2
Cousin Vitz
bigsky2's Avatar
Yes.
bigsky2 is offline
Old 10-03-2006, 06:10 AM   #261
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
So you guys get a complete assembly.
Good.
Why not just install the one, bigsky2?
Violin is offline
Old 10-03-2006, 08:43 AM   #262
GabL
I want JDM bumpers!
GabL's Avatar
RS Rear Bumper!!!!
GabL is offline
Old 10-03-2006, 08:50 AM   #263
GabL
I want JDM bumpers!
GabL's Avatar
hahaha, what are you trying to say there? Your hair isn't that long!
GabL is offline
Old 10-03-2006, 02:46 PM   #264
bigsky2
Cousin Vitz
bigsky2's Avatar
Yep it's gonna happen today..
I'm going to install ONE tail light (left).
Will post photos of my half ass job later.
bigsky2 is offline
Old 10-03-2006, 03:10 PM   #265
Linkseal
Drives: DBA-NCP91
Can't wait to see ur pic and installation....
Linkseal is offline
Old 10-03-2006, 04:55 PM   #266
Violin
Violin's Avatar
Molex Pin Removal:
http://www.gruntville.com/howtos/psu_sleeve/page6.php
You should be able to find the removal tool at Radio Shack/Comp USA/similar.
Violin is offline
Old 10-03-2006, 05:01 PM   #267
bigsky2
Cousin Vitz
bigsky2's Avatar
Just have to make sure it's small enough for the pins used for the Yaris.
bigsky2 is offline
Old 10-03-2006, 05:16 PM   #268
GabL
I want JDM bumpers!
GabL's Avatar
But for us getting the RS LED tail, we don't have to replace the pins right? Just have to take it out and plug into the new connector?
GabL is offline
Old 10-03-2006, 05:24 PM   #269
bigsky2
Cousin Vitz
bigsky2's Avatar
Correct
As long as you don't damage the pins during removal from the original molex, they can be reused for the new molex (connector).
bigsky2 is offline
Old 10-03-2006, 07:00 PM   #270
w1ngzer0
w1ngzer0's Avatar
Drives: Subaru Impreza
Wow, those tail lights look 10x better then the stocker one.
w1ngzer0 is offline
JDM RS LED taillight GabL Cosmetic Modifications (Exterior/Interior) 6 08-22-2006 12:51 PM
