Old 11-05-2014, 11:35 AM   #1
Originally Posted by 62Fender View Post
Are we talking wave form instead of voltage? I probably better stick with the basic cruise light.
The TC is a 2008 'spec'. Thanks for the info.
Even more than wave form - We are talking about an encoded message within a stream of pulses. I actually have an enhanced version of my cruise control indicator module that I developed, which can drive separate LEDs for ON and SET. I haven't offered it for sale as of yet, as it is a $50 device, as opposed to the $25 one that just handles reading "ON" via the feed between the switch and the ECM. Set is more complex, as you really need the message feedback from the ECM to know that all conditions were met to allow the ECM to set it.
Old 11-06-2014, 03:02 PM   #2
62Fender
Drives: Scion TC
Thanks for the info. Any plans to make the 'set' indicator available separately?
62Fender is offline   Reply With Quote
Old 11-06-2014, 03:37 PM   #3
I can easily do that. It is just a matter of not having the second LED for "ON".
Old 12-18-2014, 09:03 PM   #4
62Fender
Drives: Scion TC
Dear CTScott,
Was wondering if this idea could be applied to remote audio controls, (ie seek/volume) without having to fork for the steering wheel upgrade? My head unit has the wires that typically go to the clockspring. The volume dial has to be turned too many times to be useful. I'd like to have an up/down rocker-type control if possible.
I thought about using two rockers for volume and seek plus a momentary switch for the "mode" selector.
Is this possible without adding resistors to the switches or does the head unit require variable voltages to know which switch is being pushed?
Old 12-18-2014, 09:39 PM   #5
Dear CTScott,
The headunit would require resistors for each function. If you have an aftermarket one, some of those use more complex methods than resistance.
Old 01-15-2015, 07:43 PM   #6
andreas14
Drives: Toyota yaris
CROUSE
can this work with vitz 2005 2SZ-FE SMARTKEY(KEYLESS ENTRY START BUTTOM) NO KEY AND IGNITION SWITCH HOLE
andreas14 is offline   Reply With Quote
Old 01-15-2015, 08:06 PM   #7
No. There is no easy cruise solution for the Vitz.
Old 04-03-2017, 08:34 AM   #8
Dohsh77
After all this years did any one find how to install cruis control for yaris if the measure between pin 40 and ground is 0 volt
Dohsh77 is offline   Reply With Quote
Old 04-03-2017, 07:34 PM   #9
If pin 40 is zero volts, then your only option is an aftermarket solution, such as the original Rostra kits (the kits with the non-OEM looking stalk).
Old 04-03-2017, 08:36 AM   #10
Dohsh77
My car is toyota yaris sedan 2010 with ecu 89661-52c00
Old 04-03-2018, 01:52 PM   #11
David C
Drives: White '07 3dr LB
Thanks again for the write up, today I just did my brother's car cruise control, after doing mine a while ago shortly after buying the car.
I've been wondering though why did toyota chose to have a non persistent CC function rather than always on like I've seen on other manufacturers. What's the idea behind the on/off design rather than just a standby ?
David C is offline   Reply With Quote
Old 08-30-2018, 03:21 PM   #12
Yarauto
Drives: 09 Yaris Base model
Recently ran across info from CTScott from 2009 on how to install a “two button” control on an 09 base model Yaris (The only luxury on this car is A/C).
Upon inspection of the D3 connector I found that there is only one black wire coming from that connector (no blue or brown wires).
Does that change the usability factor on this car for the “build my own” 2 button control system?
Thanks for any info you can provide.
Yarauto
Yarauto is offline   Reply With Quote
Old 12-27-2020, 10:28 PM   #13
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
So I read through the entire thread but didn't find a solution my issue (some similar cases but no resolution).
I have an 07 sedan, auto transmission, Canadian car. I went to perform this mod today, only to find that I have a factory wire (pin 40) at the ECM connection but no wire at the D3 connection under the steering wheel. No CC lights in the cluster either. Car has been dealer serviced since day 1.
Anyone else figured this one out?
EDIT:
Found the solution in another thread. The pin 40 wire seizes to exist after the firewall connection (AD4) on the drive side of the vehicle. Weird! See attached photo. Hope this helps someone out because it sure as hell gave me headache.
File Type: jpg DIY Cruise Control Wiring Issue Fix.jpg (132.7 KB, 44 views)
Kasbien is offline   Reply With Quote
Old 05-11-2021, 10:37 AM   #14
KermitAUS
Drives: Yaris 2009
Following.
KermitAUS is offline   Reply With Quote
Old 04-04-2023, 03:43 AM   #15
KermitAUS
Drives: Yaris 2009
Has anyone done this in Australia?
Old 04-30-2009, 12:14 PM   #16
Um SUBSCRIBED. Would come in handy for the IA road trip.
My thoughts as well
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
