#1 |
Thanks Herb,
I'm going to dig in a little bit more and see if I can do it with heat. I'm going to try again this weekend. This is the LINK for the installation so you get a better idea. Thanks a lot, any information here is appreciated. D.
. CLA 250, 4MATIC |
Just a Herbicidal maniac.
Drives: 2008 Yaris S Sedan Flint Mica Join Date: Oct 2008
You're welcome.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace. |
#3 | |
Also I got this: ![]() from Loren, and these are the instruction he gave me: "Just jack up the car and squeeze on in on each rear spring. Will raise the ride height a little, and by removing an active coil from the spring, also raise the spring rate." My rear springs are not holding well the extra weight, and adding woofers, box and Amps! you can tell on the pictures that the rear is lower than the front, and been so soft (NF210s) tires tuck inside wheel well very easy and rubs, so this may help a little bit! We'll see how it goes. Thanks! I'm sorry to make a right turn out of the topic here, but we'll continue on our project... I'm almost done with the floor, but pilot's area, and let me tell you that the noise makes it's way! so I need to make sure to get all leaks as possible, so for some one who only want's to do a portion of the treatment, I would suggest to do the DOORS, then WHEEL WELLS, at least with the doors treated you will improve the sound of your speakers, block outside noise but the most wonderful feeling is when you close your doors! THUMP, THUMP, very nice every time you slam your doors. D.
. CLA 250, 4MATIC |
#4 |
On a trek to upgrade...
Drives: 2003 Echo Coupe Join Date: Mar 2010
I talked to a guy in one of my classes and he says his place does sound deadening by using dynamat. How does this compare to the methods and materials you are using?
#5 | |
For SPL is good to cover every single surface of your car, it doesn't compare to the method I'm using to block the noise that penetrates the inside of the cabin. (remember that for SPL competitions you are been tested in NO motion) Applying many layers of MAT it does reduce the noise levels similar to the process I'm using. The Car Audio industry is one of the only ones that still uses "MAT" aka dyamat, as a primary material for deadening, and that is because of Marketing, but in other industries I found 3 common factors: 1. take care of resonances ... by using (Constrained Layer Damper) CLD Tiles 25% of the area is enough, covering all the surfaces with "Mat" may be use but not necessary unless you are going for SPL 2. help cushion high frequencies that still goes through metal ... Close Cell Foam also used to prevent rattles between panels 3. Sound Barrier ... MLV Mass Loaded Vinyl to block exterior noise (and it's cheaper than "lead") My goal with this process is to reduce the outside noise as much as possible specially at highway speeds, and in some places like front doors improve acoustical environment for speakers. I hope it helps! .
. CLA 250, 4MATIC |
#6 |
Very much so! Thank you!
#7 |
. CLA 250, 4MATIC |
#8 |
![]() The Rubbing issues are gone (90%) but at least I don't have to drive my car with black wheels in front and silver wheels in back, feels so good now! More info HERE ![]() D. .
. CLA 250, 4MATIC Last edited by derickveliz2; 05-12-2010 at 01:49 PM. |
#9 | |
![]() ![]() Drives: '09 Yaris Sedan Join Date: Mar 2010
Pioneer
Ascendant Audio Sundown Audio DC Power Engineering Knukoncepts Fosgate Stinger |
#10 |
I did more work on the floor, removed some OEM deadening material behind pilots seat, added 2 CLD Tiles some of that heat barrier insulation (since I have lots of left overs why not?) and 1/4 CCF. I left the MLV at work so I will cut that tomorrow.
Picture soon. D.
. CLA 250, 4MATIC |
#11 |
Audio Junky
Big three is a good idea for anybody with aftermarket electronics that pull a decent amount of amperage. If you're running more than 100amps worth in fuses on your amplifiers... it's really a good idea to upgrade the big three... mainly the big two is what most people need to upgrade.
1: Power cable 2: Battery ground cable 3: Alt charging cable 2 & 3 are the forgotten misfits. upgrading to a 2awg or 1/0awg on both of them should help your voltage stay more constant, and decrease the amount of current you lose in the wire due to heat & resistance. Every little bit helps your alternator work less. |
#12 |
Could any body list the materials for the Big 3! like how much cable to buy? how long? Terminal connectors and tools!
Thanks! and we are right into our topic (sound system upgrade) D.
. CLA 250, 4MATIC |
#13 |
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#14 |
![]() Taking a break! ![]() Clean! ![]() 2 CLD Tiles. ![]() Some of that Radiant heat insulator... ![]() 1/4" CCF and ready for MLV ![]() With no MLV to work last night I started playing around with the amps, the 3rd amp will be here soon, maybe I'll put it under the passengers seat? or in line with these 2. I didn't realize they where so big and heavy ![]() ![]() This one will provide power to midrange and tweeters... ![]() PS. I will try not to forget the MLV tonight.
. CLA 250, 4MATIC |
#15 |
Wow 2:30 am!!!
I put the MLV over the floor between back seats and front seats, all what's left is the passenger's side, (it's going to be noisy in that area, I now, I can feel it, we'll see how it feels on my way to work). The hardest part was removing the back seat (again); to slide and overlap the layer of MLV with the one that comes from the trunk to create a continues sound barrier all over the floor area. I also wanted to reach for all the RCA cables I had under the MLV going back to the trunk, (plan A was to have the amps in the trunk) plan B, thanks to sqcomp I'm going to put them on the floor in front of the back seats (that's the area I treated tonight). This will bring the floor up! let say 4 or 5 inches. I don't care only my 3 year son goes in the back seat any way. I'll upload pictures tomorrow, or should I say "later" (o: D. I'm running low in CCF and MLV, I still
. CLA 250, 4MATIC |
#16 |
![]() ![]() Drives: 3dr Lftback (meteorite) Manual Join Date: Apr 2010
When you project is completed, I would love to know how much sound deadening you put into your car. cld=(sqft) ccf=(sqft) and mlv=(sqft) and any other materials... adhesives, velcro, anything else.
Thanks for the thread!! |
#17 |
Sure, so far the list of Materials goes like this:
CLD Tiles = 91 aka 38 SF MLV = 95 SF 1/4 CCF = 56 SF 1/8 CCF = 56 SF RAAMmat BXT = 45 SF Ensolite IUO Peal and Stick = 14 SF Reflectix = about 9 SF Industrial Strength Velcro = about 4 pieces (1"x2" each) D.
. CLA 250, 4MATIC |
#18 |
These are the pictures I took last night, Basically is the MLV over the floor on top of the CLD Tiles, Reflectix and 1/4 CCF. I had to take the back seat out and loose the structure to slide the MLV under the layer that comes from the trunk and goes under the rear seat. ![]() ![]() I've been using Mat to hold the overlaps in place, I'm supposed to glue them, but since I'm overlapping 4 to 5 inches it's OK to do it this way, it's better if I ever need to get something down there, Like the RCA cables I had laying down previously towards the trunk for the amps, I just lifted the layer of MLV and pull the cables (o: ![]() The OEM carpet goes on top.
. CLA 250, 4MATIC |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
