Old 06-21-2018, 02:50 PM   #253
Captain Yaris
Captain Yaris's Avatar
Drives: 2016 Yaris 3 Dr Super White
Got it figured out, and now it’s alive!!!!!!!!!! I had to swap a wire that was just a plug with a ground with a different wire that included the ground and connection to the cruise control unit. A special thanks to DarkShadowFox for hyperlinking that video of the Rostra install. It gave me the idea to pursue the correct wire from Toyota. Thanks for the help.
Part numbers to install on US Spec 2016 Yaris L are as follows:
Cruise Control Switch (84632-08021)
Clutch Switch; for cars with manual trans. (8820-42010)
Steering Wheel Switch Cover (45186-0D150-C0)
Cruise Switch Wire (84633-02020)
Cruise Control Switch Screws; need 2 of these. (90159-50199)
File Type: jpeg 4AB0BF84-8153-4B63-B522-72276B4A09F7.jpeg (207.3 KB, 369 views)
File Type: jpeg A52410CA-9F2A-4CF7-BB71-48548B662609.jpeg (164.6 KB, 359 views)
Captain Yaris is offline   Reply With Quote
Old 06-21-2018, 03:10 PM   #254
DarkShadowFox
LMAO JFC dont tell me even the L gauge cluster has a spot for the cruise control omfg. they are ripping people off on these yarises lmao.
Old 06-21-2018, 03:16 PM   #255
Captain Yaris
It sure as hell does!
Old 06-21-2018, 03:22 PM   #256
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
Your dealer person is crabby apparently. The dealer I bought my 2016 Yaris L from actually gave me the clutch switch and installed it for me after I showed them I plugged in the factory switch from another car into the steering wheel and that it lit up on the dash. The service adviser wanted to see if it would actually work hahaha.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 06-21-2018, 03:49 PM   #257
Captain Yaris
I remember that! That’s why I wouldn’t give up, I know it’s been done before. My dealer deals with a lot of little old ladies buying Corolla’s, Camry’s, and Rav4’s. They just sell the higher package and could care less about modding.
Old 06-21-2018, 04:33 PM   #258
DarkShadowFox
DUMMM. o well i wanted power locks and the rear lock squishy panel vs a manual lock and im not going to be the one to make a thread on how to install that. thats more money then you save on buying an L .
Old 06-21-2018, 04:50 PM   #259
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I hope CTScott is well.
On Instagram
On Wheelwell
Old 06-21-2018, 05:42 PM   #260
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Me too.
Old 06-21-2018, 05:48 PM   #261
Captain Yaris
Is he not ok? I haven’t seen him on here in awhile.
Old 06-21-2018, 09:29 PM   #262
He's been on, just not posting.
Old 07-12-2018, 02:17 PM   #263
irakli_86
Drives: Yaris MK2
I've just installed the cruise control stalk into my 2012 Yaris with a 1.3 (2NZ) engine. Its automatic and GCC (middle east) spec. Straight plug and play into the 4 pin connector slot which was empty next to the 10 pin connector. Mine has audio buttons as well bluetooth handset buttons. I didn't have to swap any pins whatsoever, cruise light and set all work fine.
Took about 10 minutes including setting up the audio after battery disconnect.
Only thing remaining is for the oem cover with the hole and rubber grommet to arrive.
Thanks to CTScott for all the info in this thread !
irakli_86 is offline   Reply With Quote
Old 07-28-2018, 01:52 AM   #264
Per Olof
Drives: Toyota yaris G 2014
Hello I´m new at forum,I want to now if my Toyota Yaris is ok for cruise control
the picture is from under the steering next to yellow socket,the 10 pin socket
and if I can buy a set from you Scot
Per Olof is offline   Reply With Quote
Old 08-23-2018, 03:16 AM   #265
vigvoodoo
Drives: 2016 Toyota Yaris L
Will this work for:
2016 Toyota Yaris L base model
Automatic
Touchscreen
No steering wheel controls
vigvoodoo is offline   Reply With Quote
Old 08-23-2018, 10:27 AM   #266
DarkShadowFox
scot does not sell sets he is not a dealer. you can buy all the parts from the internet. on camelback. he just assembles things.
Old 09-08-2018, 05:36 AM   #267
Per Olof
thank you for your ansver,I have look at Rostra and conection to ECM is not possible
Its a diffrent ECM behind the glove compartment,But I found a good universal one at
CANM8 England,It works fine in my car from OBD and can bus,the only thing is that it
dont get brake signal to can bus, but they send me extra conection from the brake padel to cruise module,I have test it already and it works fine without extra adjustment,it has a cruise brake butten on the backside of the stulk
Old 10-23-2018, 06:29 PM   #268
DarkShadowFox
Originally Posted by Sparty View Post
Hi everyone,
I have a US Model, 07, M/T, 1.5L, 3 door hatch. I'm installing this CC solution and I'm at the point where I'm running the D3 connector to the ECM pin 40. Please see the pic below. Which wire and pin do I send to the ECM and which one do I ground? The picture of my Yaris is different then the pictures in the instructions from CTScott. Thanks!!
https://share.icloud.com/photos/04lH...ah7sf_DqrWtH0A
this is the 2012 forum and up. the changes are different subtle but different.
Old 10-29-2018, 05:08 AM   #269
Civic_JDM
Drives: KSP130
Interesting that both of the Greek 1.33 are not working. Can either of you give me the part number of your ECM (engine computer)?
Hello CTScott,
Please help to confirm if ECM # 89661-5C340 (Japnese spec, 1.0L engine i.e. 1KR-FE) support cruise control?
Civic_JDM is offline   Reply With Quote
Old 12-05-2018, 01:46 PM   #270
stykerdk
Yaris Hybrid Limited 2015
Originally Posted by petros37 View Post
Hi
I have yaris 2013 1nr-fe 1.33 engine europe specs and installed the cruise stalk .
The problem is the indicator at the instrument cluster doesn't lit .Otherwise the cruise control works just fine .
Is it possible to fix this problem ?
Which instrument do you have.
If its the basic one without RPM meter it probably also dont have the cruise light.
Then you can switch it to one of these which should have cruise lights, my car has it.
https://www.ebay.de/itm/Toyota-Yaris...p809:rk:2:pf:0
https://www.ebay.de/itm/Toyota-Yaris...UTE:rk:36:pf:0
https://www.ebay.de/itm/Tacho-Kombii...MAAOSwyWlbpqhd
C-HR 1,8 Hybrid premium 2020
cruise control. 2012
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
