Old 12-10-2014, 02:37 PM   #1
lablancjc
Drives: Toyota Yaris S
2007
Sedan S
Blazing Blue
120k
Timing chain cover leak, fixed under warranty, still leaked, they said they forgot a solenoid, replaced under warranty, STILL LEAKS! no longer under warranty (I do not care enough to fix it, it drips on pig mats on garage and by the 5k mileage oil change it doesn't even have low oil) No other problems other than regular maintenance.
lablancjc is offline   Reply With Quote
Old 12-10-2014, 02:52 PM   #2
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
2007 White 3dr
154,213
New battery around 70K
Water pump failure at 152k
I hydrolocked the engine at around 100k which was completely my fault.
Otherwise no problems.
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 12-19-2014, 03:42 PM   #3
yaris0985
Drives: yaris sedan 09
08-sedan atx
125k miles / 200k km i got the car at 37kmiles -60k km in summer 2011
I change
2 boots cardan (cv joints)
1bushing table
I stil have
Oem battery
Water pump
Alternator
I do about 30k miles/year 50k km
Average 6.4l 37mpg
http://www.fuelly.com/car/toyota/yaris/2008/saws/107172
yaris0985 is offline   Reply With Quote
Old 12-20-2014, 02:21 AM   #4
colj00
DIYer
Drives: yaris 1.5 MT
2007 HB manual
58 000 miles
no problemo, except squeaky gear changes and clutch.
colj00 is offline   Reply With Quote
Old 12-25-2014, 12:05 AM   #5
lenzomaru
lenzomaru's Avatar
Drives: 07' Yaris S & 89' Mazda 323 LX
2007 Yaris Sedan
40000
no probs, i think i need new tires tho
"Cooler than the other side of the pillow"
lenzomaru is offline   Reply With Quote
Old 02-13-2015, 09:09 PM   #6
nookandcrannycar
Today I had the second oil change done on my 2014 Yaris at 6,676 miles (3,003 miles since first change). This time I took it to Brake Check (a Texas chain). I had Brake Check do the last two oil changes on my 2007 Yaris. They have a policy where you get every 4th oil change free. Before those changes, I asked if the 'counting' re those changes was specific to the customer or the car. I was told the customer, not the car. I dropped by about 3,000 miles ago to get the first oil change for my 2014. I was told I was too close to closing and they couldn't squeeze me in. I ended up going to Service First (mentioned on another thread).
Today, at Brake Check, I double checked this. It turns out the company policy (it is a Texas wide chain) has changed. The '4th free' is now car specific. Apparently quite a few people have a range of levels of cars that they own (with varying amounts they are willing to spend on upkeep), and too many people were paying for 3 basic changes on a cheap small car and then using the free one to get a synthetic change on a more expensive vehicle. They gave me over 1/3 off the first change today on my 2014 (because it is a first visit with that car with them). Their regular price is cheaper than Service First. I'll do two more changes with them, plus the free one, and then reexamine the situation. I'll do my next oil change, out of state (probably in Arizona), in a few weeks and then my next one after that at Brake Check when I get back to Texas. This particular Brake Check location did the wheel bearing replacement on my 2007 Yaris at 110,000 miles, and that work is still holding up 190,000 miles later. This location is under new (as in under 2 months) management (much improved ). The new manager told me that even if I had arrived 1 minute before closing for the first oil change for my 2014 (in December), they should have accepted my car and always should under such circumstances.
Old 02-18-2015, 05:02 PM   #7
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
2007, just over 57k miles.
Other than having the rack & pinion replaced at 40k and the clear coat on the bumpers re-sprayed, it's been smooth sailing.
Old 02-18-2015, 08:33 PM   #8
Kar98
Drives: 2011 Scion tC
Well at 57k it's barely broken in ;) Did you drive over a curb or why did the r&p have to be replaced?
Old 02-18-2015, 08:38 PM   #9
ern-diz
ern-diz's Avatar
The car was involved in a minor fender bender early on when a friend didn't realize I was parked behind her and backed into me. It was a low to no speed impact and I had everything inspected/repaired professionally, so not sure that caused it, but don't know what else might have. Maybe just a factory dud? I opted for the extended warranty, so luckily it only cost me the $50 deductible to have it all replaced by the stealership.
Old 02-20-2015, 02:12 AM   #10
blktiger60
blktiger60's Avatar
Drives: `08 HB S
08 2dr HB
73,300 miles
Bought new in March 2008
no repairs, only oil changes - not counting the recent accident
3-4-18, 92k and still running fine.
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Old 02-20-2015, 03:56 PM   #11
instantninja
Drives: 07 yaris rs
2007 yaris rs 5 door 225,000 km, no major problems, I had an ABS light come on 2 years ago during the spring. Cleaned the connector and it went away.
put on a tooter intake manifold and a 1zz throttle body about 20,00km ago, only issue there is if I don't let the car warm up sufficiently the throttle body gives an over current CEL and limits the rpm to 2000, and that only happens when its below -25. this car has been dead reliable and couldn't be happier with it.
instantninja is offline   Reply With Quote
Old 01-06-2016, 06:54 PM   #12
yak
yak
Drives: 2007 5 dr yaris
2007 5Dr Hatch milage
357km
drive it like I stole it every day
routine maintenance, oil, plugs, air filter cleaning (CAI)
replaced serpentine belt at 265km
yak is offline   Reply With Quote
Old 02-03-2016, 09:42 PM   #13
emgconsulting
Drives: 2007 Yaris Hatchback
2007 Yaris 2dr. Hatchback CE
No issues besides regular maintenance (1 headlight bulb, brakes, tires filters, oil)
165,000 miles and going.
Black mica
emgconsulting is offline   Reply With Quote
Old 02-05-2016, 04:26 PM   #14
Frank the Tank
Drives: 2007 Toyota Yaris
2006 hatch
162,000km
At the dealership right now and the camshaft gear needs to be replaced. Fffaawwwww-k
Frank the Tank is offline   Reply With Quote
Old 02-06-2016, 08:11 PM   #15
zoidberg444
zoidberg444's Avatar
2006 Hatchback, 5 door, 1KR-FE engine.
100,000 miles.
Water pump went bad at 65,000 miles. Made a lot of noise.
Alternator failed at 88,000 miles. Faulty voltage regulator. Drove it around for weeks.
Other than that. A few tyres, brake pads, a battery and an exhaust a bulb or two and servicing. I really can't complain. I drive it like i stole it and it takes me all over the country.
Old 07-08-2016, 07:14 PM   #16
dbosnake
Drives: grey
2008 4 door
168,698 miles and counting
No repairs besides recharging the AC
Sent from my Nexus 7 using Tapatalk
dbosnake is offline   Reply With Quote
Old 07-09-2016, 01:15 AM   #17
rabbito
rabbito's Avatar
drove 3 years..45,000km...battery died at 35,000km...exterior is wearing out such as black plastic trims, wipers, distorted rubber seals
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 07-12-2016, 06:55 AM   #18
laurenth
laurenth's Avatar
Drives: yaris
2004 Toyota Yaris 5door Hatchback 1.0 (65hp)
150,000 km (94000 miles)
Some electrical problems like the dome light won't turn on, front windshield wiper liquid pump isn't getting electricity. The headlights turned ugly yellow so I changed them, The little engine that could is purring like it's still brand new.
laurenth is offline   Reply With Quote
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 06:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
