Old 01-17-2011, 01:20 PM   #271
cdydjded
Drives: Yaris LB Turbo
Well first of all it why would you think that you could compare NA vs Boosted on a dyno sheet? HP comes in very differently between the 2. Also he has an aftermarket intake manifold & a ported head with stock cams. Im not going to speculate on why his dyno looks the way it does. I congratulate him on his efforts.
cdydjded is offline   Reply With Quote
Old 01-17-2011, 02:03 PM   #272
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Unless that stuff was hurting the flow or restricting it, wouldn't it promote power in the higher revs since you are making it easier for the motor to breathe? especially when still using stock cams?
Old 01-17-2011, 02:08 PM   #273
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Seeing as his dyno looks like any other dyno with a maxed out turbo Im going to go out on a limb and say he maxed his turbo out.
The fact that just because your car has air being forced into it doesn't mean your dyno curves will looks drastically different. All your doing is compressing air in a given space. The engine will still consume the air as it would in N/A form. If you look at any car be it PD induction or turbo the peak power is still the same as it would be N/A as long as the boost levels are held until the power adder is maxed out on its induction.
Im not going to sit here and congratulate a guy on making power when its obvious to anyone who knows anything about engine tuning when there are clear problems. In the end do I care if this guy blows his motor no but when people believe his setup is normal and good then more people will continue on the wrong path of how to setup a motor adding more noise for people who are looking to get the right info.
Old 01-17-2011, 02:55 PM   #274
It's xbgod's thread, to "share with the community" this build and the results. I've asked my questions, so I'm done for now. If the answers get posted, I think that will be valuable to all of us.
Old 01-17-2011, 05:31 PM   #275
cdydjded
xnamerxx : Seeing as his dyno looks like any other dyno with a maxed out turbo Im going to go out on a limb and say he maxed his turbo out.
I have to agree with you on that, Garrett claims max HP on that turbo to be 360HP
http://www.turbobygarrett.com/turbob...S_739548_1.htm
Id have to completely disagree on this. Manifold runner size, plenum size & what work is done will dramatically affect the power curve
As for the above comment, this is the first time the car is dyno'd with the current combo. Iv never seen a car come out of the box with no issues. Im sure if he feels changes need to be made to correct the so called "lean issue" he will fix them.
Old 01-17-2011, 05:33 PM   #276
cdydjded
BTW, what are the questions you are waiting answers for? And who are you waiting for to answer them?
Old 01-17-2011, 05:54 PM   #277
^ read the thread. You've already said you can't answer them and don't want to speculate, which is fine.
Old 01-17-2011, 05:57 PM   #278
cdydjded
THX for answering my 2 question so clearly......
Old 01-17-2011, 06:10 PM   #279
You're welcome!
Old 01-17-2011, 07:49 PM   #280
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Xb has turned ghost....
Old 01-17-2011, 07:56 PM   #281
cdydjded
I would too considering the hostility in this thread....
Old 01-17-2011, 08:07 PM   #282
xbgod
Drives: "Burning It Down GTX2860RS XB"
No ghost, just out having a little fun and had to fix an exhaust leak.
I see I missed alot in past few days, holy-crap.
Remember I don't use VVTI so that has some play in what your reading. Also the XB starts to fall on it face at around 5000-5200 RPM. Paul at Dezod can even tell you this. It's just the way it is. As far as being lean My car likes it there. It dosen't detonate and pulls like a beast. More than likely because of my 107 octane and M1 meth.
All is well so I hope this helps, if not sorry..........I'm running'em down and enjoying the car.
You guys can keep running your own senarios and speculation, it happens especially on forums.
Thanks to all that have followed me.
XBG
xbgod is offline   Reply With Quote
Old 01-17-2011, 08:16 PM   #283
cdydjded
XBG
Well there you go, 1 reason (the biggest) for the difference in HP is that he is NOT using the VVTI. So in essence you cant compare a NA dyno that uses VVTI to his....
Old 01-17-2011, 08:38 PM   #284
H3LlIoN
Drives: '09 Yarrrr hatch
I'm gonna chime in...I don't think any of the heavy 1nz hitters are running VVT-I, AFAIK, mostly because of A) Some standalones don't offer control modules yet (I can vouch for that) and B) from earlier speculation in this same thread by Aras and others, at a certain point it becomes a hindrance as opposed to a power builder. (Which doesn't make sense to me, but whatever...I don't have a 350hp 1nz to play with and speak from experience.)
Also, I'm currently picking my nose and drinking a miller light. I may or may not have already consumed a number of long island iced teas.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 01-17-2011, 08:40 PM   #285
H3LlIoN
Also, this post got pushed to the side and I was hoping for some speculation from Aras. Thanks
Originally Posted by H3LlIoN View Post
Sweet numbers. Curious...what are you hoping to run at the track? What were your E.T.'s on the old build?
Toyota
Moving Forward
Old 01-17-2011, 08:42 PM   #286
H3LlIoN
And in regards to this, I highly doubt that Garm is comparing an NA dyno to Aras'....I think he's more comparing his non-vvt-i turbo set up.
Toyota
Moving Forward
Old 01-17-2011, 08:42 PM   #287
All I did was ask two questions. (1. Why does it stop making power at 5200, and why was it tuned that lean). I was called a hater and now hostile. I haven't said a critical thing about the build or the tune. Lame.
I asked why, it was just a question. Art's didn't (280whp). Mine doesn't (357 whp). So, that question remains unanswered. "That's just the way it is" is not a useful answer.
The second question really belongs with the tuner, as he seems to be the only one who can answer it. "It likes it there" is great to hear, but again is not a useful answer IMO.
xbgod, you got great numbers. (I already said that). If you're not curious about the why of these things, that's fine, it's your project of course!
Old 01-17-2011, 08:43 PM   #288
H3LlIoN
Hater.
Toyota
Moving Forward
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
FS: 2005 Scion xA RS2.0 Turbo uberegg Cars for Sale by private party 40 04-03-2010 11:45 AM
Scion xd turbo PARIS Yaris TS Talk 22 02-26-2010 08:08 AM
Chevy Aveo RS: Turbo + good looks = build it! Thirty-Nine Off-topic / Other Cars / Everything else Discussions 22 01-12-2010 12:36 PM
Check out the new Scion iQ concept. In the States in 2011/2012 LA Yaris California 9 10-23-2009 08:11 PM
