Old 02-27-2013, 01:51 PM   #1
tommih
Drives: Soon Yaris XP13
Yaris 1,33 2013 with lowered springs, do you guys think that ET 35 will rub?
195/50/16/7
Anyone ? Greatful for answers =)
tommih is offline   Reply With Quote
Old 03-21-2013, 11:39 AM   #2
JoãoMendes
Drives: Toyota Yaris D4-D
Hi mates..I have a 5 door hatchback..I am wondering to lower it like 1.2 inches..1.4 inch maximum. Will the mini cooper 17x7 et 48 wheel rub with 205/45 tire?
Thanks for the help one more time :)
JoãoMendes is offline   Reply With Quote
Old 06-02-2013, 11:04 PM   #3
mario98c
mario98c's Avatar
15x7" +30 offset 205/50/15 tires. Will it rub?
Old 09-17-2013, 02:07 AM   #4
jdmrye
Drives: Vios
16x7 et42 205/50 will they rub if i drop 1 inch all around?
thanks in advance
jdmrye is offline   Reply With Quote
Old 09-18-2013, 12:58 PM   #5
33OH
Drives: '08 Yaris
Likely to have minor rubbing there - it will be close and depend on your drop.
thanks in advance
You'll be fine.
Old 09-18-2013, 03:53 PM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
what do you mean help? I dont see a question?
Are you asking which of those two you should go with? That would be a personal preference. If you like the way 15s look go with that, if you like the way 16s look go with that. I would not go wider than 195 on a 7, not saying you CANT go wider, that is only my preference
Old 09-18-2013, 04:22 PM   #7
1.5
Form>Function
1.5's Avatar
I disagree with WeeYari, I have run 45/50 on 15s 40/45/55 on 16s without issue. The shorter the sidewall the lower you will be to the ground and give the harsher the ride. Thicker side walls are usually more cushy.
Its going to come down to your wheel preference. Find the wheel you want and then find a tire to match.
Think of what you want out of your new tire/wheel setup like weight, performance, looks, stance, handling, etc thats a good way to start
Old 03-30-2014, 07:58 PM   #8
Rigaud
Drives: 2009 Yaris
Precisely. If you go with lower profile sidewalls then invest in better shocks/struts. Your ride will be harsh. Theirs always a domino effect when you start changing your cars set up from stock specs. Been doing this for almost 33 years now, I see all kinds of messed up upgrades or set ups still.
Rigaud is offline   Reply With Quote
Old 12-07-2014, 08:17 PM   #9
Ben_
Drives: 2010 Yaris Hatch
how about 225/45/15x7 et40 with coilovers? will this need spacers?
Ben_ is offline   Reply With Quote
Old 12-17-2014, 05:58 PM   #10
225s! You trying to float the thing on water?
Old 09-18-2013, 05:07 PM   #11
He's only dropping 1" so with a 195/50/15 or 205/40/16 it would almost be pointless if an objective is to reduce wheel gap.
This was me when I had 195/50/16s dropped 1.5". Wheel offset is +42 with 10mm spacers in the rear. Essentially +42 in the front, +32 in the rear.
Old 09-18-2013, 10:31 PM   #12
yarisgeo13
yarisgeo13
Drives: gloss black 5 door
Send a message via Yahoo to yarisgeo13
I agre about putting over sized tire/wheel combo on a Yaris
yarisgeo13 is offline   Reply With Quote
Old 10-13-2013, 07:43 PM   #13
bcbushcub
Drives: Yaris 3 door
yaris tire advice
hey guys
Just a old man with a stock daily driver.
But I needed new tires and I do sometimes push it a tad in corners.
I went with the advice that gets posted on here from those in the know.
And Im happier then a pig in....Well you know.
So thanks guys!
bcbushcub is offline   Reply With Quote
Old 03-30-2014, 08:23 PM   #14
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
That is why I got coilovers and tires with a massive sidewall. I get sensational handling and tires with a gigantic sidewall to protect my wheels. Couple that with the stock seats and while I hear every bump I don't feel anything.
Colin Chapman disciple
Old 06-13-2014, 09:20 PM   #15
KTS
KTS's Avatar
Drives: Vitz RS
Hello everyone,
I have a question/concern.....
I put my OEM Vitz RS rims [16x6, ET51] with 205/50/16 on my wife 07 ncp92r 4 door sedan. The tire now rubs on the front shock and chassis with the steering at full lock. I installed a 5mm spacer and it still does the same. I observed that the sedan has a much, much smaller turning radius than my 07 Vitz RS. This combination was never a problem on my car. I am now using her 15x7 ET42 205/50/15 which gave no problems on either car.
Is it normal for the 16x6 ET51 with 205/50/16 to have fitment issues on the sedans????
What can be done to rectify the fitment issues without future problems????
Buying new wheel/tire combos for either car is not an option but if we have to switch back we will both be disappointed.
Any assistance will be appreciated.
Thank you.
KTS is offline   Reply With Quote
Old 09-09-2014, 03:46 PM   #16
rockyy
Drives: yaris 2013
Guys can i put 14" wheels on my yaris from 2013 year?
rockyy is offline   Reply With Quote
Old 09-09-2014, 05:28 PM   #17
sheekeebut
Minimalist
Drives: 07 silver sedan
Yes
sheekeebut is offline   Reply With Quote
Old 10-11-2014, 08:36 PM   #18
stevens_uk
stevens_uk's Avatar
Drives: Yaris Sport 2014
Does anyone know if Toyota sells these wheels? from the older 1.8 SR model.
stevens_uk is offline   Reply With Quote
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
