Old 11-06-2014, 07:32 PM   #289
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
2010 Yaris Liftback
55,000 -ish miles (bought in March 2011 with 6k)
* Front tires in '12
* Battery died yesterday (11-5-14). Was the original and build date for car is late '09, so it was about due to go bye-bye. I'd noticed that it didn't start with the usual enthusiasm these days, and yesterday POOF! Got the cheapie 26r @ Sears.
* Misc stuff: Rear brakes make a noise sometimes, right before car comes to a stop, but usually only when it's hot out, which is most days in SoCal. Heater/AC has that musty smell.
And that's it. Lots of little things I don't like about it, but most can be addressed (sound insulation project coming soon, rear sway bar, etc.)
Don't know how long I'll keep it, but if it's half as reliable as my '88 Festiva, I'll be happy.
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 11-06-2014, 09:46 PM   #290
ThatGreenSedan
Drives: 07 Olivemist Sedan-PowerPack
-Mileage Thread- -Log your mileage, year, model, color, any problems here...
2007 Sedan with power package
Olive Mist
160,*** miles ..I do a lot of driving
Water pump replaced..years ago. Only problem was a broken valve timing solenoid..and minor suspension problems cv boot..etc all fixed this year.
And break pedal feel is very mushy..is there a fix for this..maybe new rotors ? .. Even with new pads. I notice no difference in breaking feel.
Also need to replace shoes. As they always squeak and make noise.
ThatGreenSedan is offline   Reply With Quote
Old 11-06-2014, 09:51 PM   #291
nookandcrannycar
My 26r from Sears lasted for 3 years (9-9-2009 to 9-9-2012) with somewhere between 85-90k miles driven during that period. On 9-9-2012, Sears was no longer offering the 26r in my area . I ended up getting a Wal-Mart 26r...and that only lasted 16 months and about 49k miles. We may be the only two members to ever go with the 26r. I hope you have the same good luck I feel I had (given the heat here) with my Sears 26r .
Old 11-30-2014, 10:26 AM   #292
donpalino
Drives: Yaris 2010 5Dr MT
2010 Hatchback MT
Silver
85K
Hatch struts replaced.
Seal connecting the engine to the exhaust replaced.
Drive belt replaced (my choice)
Using 0w30 mobil syntec every 3K.
Sent from my using Tapatalk
donpalino is offline   Reply With Quote
Old 11-30-2014, 07:10 PM   #293
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
07 LB
Absolutely Red
Bought it with 65.000km on it in 2011
Now it has 127.384km
No problems at all, just basic maintainance
Sent from my awesome Toyota Xperia Z1 C6903 - Yaris Edition using Tapatalk. xD
Cheers, George.
vivalaflam is offline   Reply With Quote
Old 12-07-2014, 08:42 PM   #294
harda toenail
Drives: Want a yaris
104k. MT 3dr
Replaced original battery a couple months ago.
New water pump 15k miles ago. Current one is making noise. Bearings are bad. Will replace with aftermarket this time.
harda toenail is offline   Reply With Quote
Old 12-08-2014, 08:46 PM   #295
nookandcrannycar
A little over 1.5 hours ago I had the first oil change performed on my 2014 Yaris at 3,673 miles on the odometer.
Old 12-10-2014, 02:37 PM   #296
lablancjc
Drives: Toyota Yaris S
2007
Sedan S
Blazing Blue
120k
Timing chain cover leak, fixed under warranty, still leaked, they said they forgot a solenoid, replaced under warranty, STILL LEAKS! no longer under warranty (I do not care enough to fix it, it drips on pig mats on garage and by the 5k mileage oil change it doesn't even have low oil) No other problems other than regular maintenance.
lablancjc is offline   Reply With Quote
Old 12-10-2014, 02:52 PM   #297
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
2007 White 3dr
154,213
New battery around 70K
Water pump failure at 152k
I hydrolocked the engine at around 100k which was completely my fault.
Otherwise no problems.
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 12-19-2014, 03:42 PM   #298
yaris0985
Drives: yaris sedan 09
08-sedan atx
125k miles / 200k km i got the car at 37kmiles -60k km in summer 2011
I change
2 boots cardan (cv joints)
1bushing table
I stil have
Oem battery
Water pump
Alternator
I do about 30k miles/year 50k km
Average 6.4l 37mpg
http://www.fuelly.com/car/toyota/yaris/2008/saws/107172
yaris0985 is offline   Reply With Quote
Old 12-20-2014, 02:21 AM   #299
colj00
DIYer
Drives: yaris 1.5 MT
2007 HB manual
58 000 miles
no problemo, except squeaky gear changes and clutch.
colj00 is offline   Reply With Quote
Old 12-25-2014, 12:05 AM   #300
lenzomaru
lenzomaru's Avatar
Drives: 07' Yaris S & 89' Mazda 323 LX
2007 Yaris Sedan
40000
no probs, i think i need new tires tho
"Cooler than the other side of the pillow"
lenzomaru is offline   Reply With Quote
Old 02-13-2015, 09:09 PM   #301
nookandcrannycar
Today I had the second oil change done on my 2014 Yaris at 6,676 miles (3,003 miles since first change). This time I took it to Brake Check (a Texas chain). I had Brake Check do the last two oil changes on my 2007 Yaris. They have a policy where you get every 4th oil change free. Before those changes, I asked if the 'counting' re those changes was specific to the customer or the car. I was told the customer, not the car. I dropped by about 3,000 miles ago to get the first oil change for my 2014. I was told I was too close to closing and they couldn't squeeze me in. I ended up going to Service First (mentioned on another thread).
Today, at Brake Check, I double checked this. It turns out the company policy (it is a Texas wide chain) has changed. The '4th free' is now car specific. Apparently quite a few people have a range of levels of cars that they own (with varying amounts they are willing to spend on upkeep), and too many people were paying for 3 basic changes on a cheap small car and then using the free one to get a synthetic change on a more expensive vehicle. They gave me over 1/3 off the first change today on my 2014 (because it is a first visit with that car with them). Their regular price is cheaper than Service First. I'll do two more changes with them, plus the free one, and then reexamine the situation. I'll do my next oil change, out of state (probably in Arizona), in a few weeks and then my next one after that at Brake Check when I get back to Texas. This particular Brake Check location did the wheel bearing replacement on my 2007 Yaris at 110,000 miles, and that work is still holding up 190,000 miles later. This location is under new (as in under 2 months) management (much improved ). The new manager told me that even if I had arrived 1 minute before closing for the first oil change for my 2014 (in December), they should have accepted my car and always should under such circumstances.
Old 02-15-2015, 02:17 PM   #302
canadian deacon
Drives: 2014 yaris 5dr
I just sold my 05 Echo 5 dr with 377,400 km on it and bought a new 2014 5 dr Yaris with 55 km on it.
The 05 was never any trouble. I replaced the clutch at 290,000 km myself. I do all my own maintenance. Hoping to get 300 K out of the new one too.
canadian deacon is offline   Reply With Quote
Old 02-15-2015, 06:45 PM   #303
nookandcrannycar
Welcome . Is your new 5-door Yaris an automatic or a manual? In the U.S., the 3rd Gen 5-door isn't available with a manual , unless you get an SE.
Old 02-16-2015, 02:25 PM   #304
canadian deacon
The 2014 is a manual. It has the convenience package on it with air, power windows and locks, and came with cruise (although I didn't ask for or pay for it - a happy accident).
Thanks for the welcome. I joined the forum hoping to learn more about the emission control system for the yaris. I've done some troubleshooting on other cars and am looking to gain some insight.
Old 02-16-2015, 05:49 PM   #305
nookandcrannycar
IMO, it is a shame your particular vehicle isn't available in the United States. I would have purchased one....prefer it to the SE re tighter turning circle, and a few other reasons. I wonder if Toyota doesn't offer a non-SE 5-door manual (the XP130) in the U.S. because of a perceived lack of demand. I purchased my 2014 in Florida in August of 2014, but the manufacturing date on the door jamb plate is January of 2014.
Old 02-18-2015, 04:38 PM   #306
canadian deacon
Just noticed your '14 is classic silver - mine too!
My '05 was the same or similar color. I figure it doesn't show the dirt as much
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 06:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
