Old 07-21-2009, 02:55 PM   #1
jkuchta
Drives: 2007 Yaris hatch (red)
I've got close to 10,000 miles on my chipped 1ZZ TB, so I don't think it went bad on him.
jkuchta is offline   Reply With Quote
Old 07-21-2009, 03:13 PM   #2
PatrickJohnson
Drives: 2008 Yaris LB
I'm hoping he just removed it because so many are having issues and not because he is being a pissant...
PatrickJohnson is offline   Reply With Quote
Old 07-21-2009, 07:21 PM   #3
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
i just did a swap last night from the stock throttle position sensor to a scion tc throttle body. i havent put the throttle body on yet to see it worked though. my corolla throttle body didnt set any cels when i installed it as is
Old 07-21-2009, 09:28 PM   #4
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
my 1zz throttle body that i put on without switching the chip or adjusting the idle screw and was running perfectly for the last two weeks has just turned gay on me. It started oscilating the other day, and i unplugged the battery, replugged it and it was fine. However, again it is now back to oscilating and i can't disturb it by tapping the gas to interupt it. my only hope now is to do a chip swap; but i don't think i want to.
Old 07-21-2009, 09:48 PM   #5
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Na, he always does this. We're not sure why he does though.
Why wouldnt you? I didnt even bother trying it with the stock 1zz chip since I heard almost everyone's problems being fixed by a swap. Swap it!
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 07-21-2009, 10:00 PM   #6
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Just do the damn swap already Peter
Old 07-21-2009, 11:17 PM   #7
jkuchta
Also...adjust the idle set screw and the problem will go away.
Old 07-22-2009, 12:12 AM   #8
fuji
fuji's Avatar
Drives: Polar White Yaris HB
I would have to agree Peter, I have been running the throttle body with the chip swap with no issues yet. Never had a cel
fuji is offline   Reply With Quote
Old 07-27-2009, 11:36 PM   #9
whooppee777
i swapped the chips from the stock tb to a Tc tb. set a CEL the first day and had oscillating revs and high revs on cold engine starts. after 4 days cel went away and rev issues fixed itself. chip swap ftw
Old 05-05-2010, 09:43 PM   #10
mick.wheelz
mick.wheelz's Avatar
Drives: 2006 NCP91R, 1991 ST184R
Send a message via MSN to mick.wheelz
since OP is a douchbag and removed his shit, I will post my experience with this....
IMO, the 1ZZ TB upgrade is one of the best bang-for-buck mods that us yaris owners can do... What else can you pay $50 for performance wise and actually feel a difference?
Anyway, onwards with the DIY.
NOTES:
From my expirence you MUST do the chip swap... don't be a lazy fuck, just do it! If you dont, it will idle like a pig and oscillate.
Also, the idle screw NEEDS to be adjusted, but be careful, if you cock it up and strip your idle screw like i did, you will need to drill it out and tap in a new one. (You don't want to have to do this.)
Steps;
1. You need to remove your 1NZ TB, its held on by 6x 10mm nuts, and 1x 10mm bolt, you will also need to disconnect the cable that goes into the chip, as well as the coolant lines (be sure to clamp these if you don't want to lose coolant. also, now is a good time to do a coolant bypass.)
side note: for the coolant bypass, all you need to do is take one of the stock coolant lines, disconnect the other at the engine and connect the remaining one on, creating a loop.
2. Remove the stock TB, you will note it does not have a gasket. there is an o-ring in the plenum that it seals against.
3. Here are some comparison pictures of the 1ZZ and 1NZ TB's
1ZZ
1NZ
Side by Side
4. Take your stock TB and drill out the rivets, also do this with your 1ZZ TB.
5. Pull the 'chip' off the stock TB and attach it to the 1ZZ TB.
6. Get some small bolts to hold the new TB chip to the TB
7. Remove the glue from the idle screw and make sure you can adjust it before fitting it to the car.
8. Put the TB back in the same way it came out.
9. Reconnect all hoses and fittings. If you are still using the stock hose/airbox you can simply turn it around (be sure to use some grease to get it to fit on the new TB flange/airbox... you will also need a new PCV hose as the old one will now be too short.
10. If you have not done already, pull the negative off the battery and reset the ecu (just stand on the brake pedal for 30-60sec)
11. Wind the idle down a tad (wind the screw out) and try and start the car, it will fast idle quite high and settle down, ones it has, fiddle with the idle until its back to factory (or close)
12. You are done. The car may oscillate a tad at first and the idle might require re-adjustment, but after 100kms or so, it should be right.
Hopefully this helps :)
mick.wheelz is offline   Reply With Quote
Old 05-05-2010, 10:42 PM   #11
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Thanks for posting this info again.
What's the best way to replace a stripped idle screw? It was pretty worn when I bought the TB, and I ended up stripping it completely after a while. I don't think I can drill it (without hurting the TB) since it's pretty much level with the enclosure already.
I'm pretty much used to the high startup idle @ ~2.5K, but it goes down after 20 seconds or so. Not a huge deal, but I might fix it just to make it perfect.
As far as the bang-for-buck comment, I agree this mod is one of the best candidates out there for the Yaris.
Old 05-05-2010, 11:14 PM   #12
mick.wheelz
All I did was get a big ass drill bit (~10mm) from memory, and drill the whole screw/etc out and tap a new thread.
edit: a pic
You can see the bolt used here. Once i got it right i putt a little glue down it to set it in place.
Old 05-06-2010, 12:15 AM   #13
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Thanks!
I'll probably rethread the sucker once I get the TB spacer installed in the next week or so.
Old 06-01-2010, 05:59 PM   #14
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
hmmmm...tb...part#
Old 06-01-2010, 06:56 PM   #15
Astroman
Modded Moderator
Astroman's Avatar
If you can find a TB with #22030-0D030. I didn't have to do a darn thing.
Old 06-01-2010, 08:28 PM   #16
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Do you happen to have the info of the car it came off of? (year, model, etc)
edit: nvm, found answer in other thread (05 corolla, right?)
Old 06-02-2010, 11:51 AM   #17
marcus
toyota
marcus's Avatar
can anyone confirm if this tb will work.. 1zz-fe part# 0d110
http://www.khengine.com/servlet/the-...Body-03/Detail
Old 06-02-2010, 01:26 PM   #18
Astroman
Modded Moderator
Astroman's Avatar
Sorry that TB won't work for your Yaris, you need one thats DBW (05+).
Yup, mine is from a '05 Corolla.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
