Old 05-03-2010, 03:45 PM   #289
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Glad to see you and the Yaris are OK .
Is that a Fluidyne or Koyo radiator ? Also where did you get the radiator hoses from ? I will be needing both of those soon .
Thanks
Old 05-06-2010, 06:17 PM   #290
Jason@SportsCar
Round two getting slowly under way... The new hood and intake system have shown up.
Plan is to get the trans out this weekend, and next week having the LSD rebuilt and the gears changed.
Now we just have to pull the trigger and pick which engine builder we are going to use. We have talked to everyone from the local guy we know, to an engine shop Toyota uses for ALMS/Rolex/Nascar. For the most part they are all starting at ground zero with a Yaris engine.
Hopefully during the tear down process we find our steering issue.
Old 05-06-2010, 08:47 PM   #291
Did you get to the bottom of the steering lock issue yet?
Old 05-10-2010, 03:12 PM   #292
Jason@SportsCar
Transmission came out on Saturday... Man that is so much easier when you don't have the front end on the car.
Old 05-27-2010, 06:06 PM   #293
Jason@SportsCar
Progress... New radiator and hoses arrived. Just visited the shop that is rebuilding the LSD and putting in the new gear set, should be done tomorrow.
Going to be busy doing some driver coaching on Sat, but hopefully will be able to install the trans on Sun.
Old 05-28-2010, 12:18 AM   #294
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
any word on the part that broke?
Old 06-01-2010, 01:49 PM   #295
Jason@SportsCar
The transmission is back in. Freshly rebuilt Kaaz LSD ready to put power down. And the way to tall 3.722 final drive has been replaced with 4.312, this should help acceleration - even more so when we drop from the 23" Goodyear slicks to the 20" units. We should just about be able to launch in 2nd gear now.
Old 06-01-2010, 06:09 PM   #296
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
I'm assuming you grabbed the 4.3 final from a C52/C56/C156 or similar? If so, did you just swap the Yaris bell housing onto the C5_ centre casing? Any problems with shifter cables etc?
rob323 is offline   Reply With Quote
Old 06-01-2010, 06:36 PM   #297
kou
Drives: 08 lb
My geuss is the wheel got suck up in the fender.
Old 06-01-2010, 06:55 PM   #298
Jason@SportsCar
That seems like a lot of work... We found it much easier, and cheaper, to use the final drive and output shaft from an xB C50. Direct bolt in.
Old 06-01-2010, 06:58 PM   #299
Jason@SportsCar
The fenders are flared, not an issue. It was also nothing in the trans/lsd.
This has been very low on the priority list. As we take the car apart and prepare for the Runoffs we are checking the various parts.
We have found two questionable items that may be related to the problem, once we nail it down for sure I will post our findings.
Old 06-04-2010, 03:44 PM   #300
Jason@SportsCar
I am just putting a feeler out to see if there is interested in OE style fiberglass front fenders...
After the recent mishap with our HP Yaris we are replacing all of the front body work. To meet the SCCA Production class rules we have to cover the tops of our 10.5" wide slicks, this has required the use of flares. I was talking to the vendor who supplies our flares about building a one-piece fiberglass fender, with the flare already built in.
This should cut some weight on the front of the car, and give us the tire clearance/coverage we need. The other option would be just a direct OE replacement with no flare, if you want the flares you just add them on.
I just did not know if anyone other than us would be interested in such a product. He should have a ballpark figure for me in the next week, and a minimum number needed to proceed - so far it sounds like six pairs.
The end result would look very similar to the image below.
Old 06-06-2010, 05:07 PM   #301
rob323
Is your box a C150 or a C154?
C50's are rare as over here (And I wouldn't be able to make use of my TRD 4.7:1 final drive kit).
Old 06-06-2010, 10:18 PM   #302
Rob, I can send you a C50 anytime, we get them from salvage.
Old 06-06-2010, 10:28 PM   #303
rob323
Thanks for the offer Garm but it's not needed. I have a C52, a C150 and a C56 all stripped on my bench at home, I'm too far down the track to not make the most of it now. Bearings and synchros for the C56 are ordered. Just got to drill the C56 casing for the mount, throw it all together including the lsd and the TRD final drive and slap on the C150 bellhousing on it. End result should be a close ration gearset with a top speed of about 110mph depending on rev limit and tyre size.
Old 06-09-2010, 03:38 PM   #304
Jason@SportsCar
OK, what smart guy came up with an 8mm bi-hexagon head bolt. We got all the peripherals off, and the cams out, only to find we need this special socket to pull the head.
Oh well, the tool is on its way, and the head will wait a few more days.
Old 06-11-2010, 05:42 PM   #305
Jason@SportsCar
Things can start moving again... The 8mm bi-hexagon showed up today.
So sometime between the tire test tomorrow, and racing on Sunday, I will hopefully find time to pull the head.
Old 06-14-2010, 06:01 PM   #306
Jason@SportsCar
Between our testing on Saturday, and playing on Sunday, no progress on the Yaris.
And what a disappointment, the Corvette I was racing on Sunday had ABS issues again, so the owner decided to park it.
I did find a suitable replacement, 430 Scuderia... http://www.youtube.com/user/SportsCa.../0/m6-YM5FHGpI
That was the coolest thing I have ever gotten to take a lap in. If you have the means I highly recommend getting one. If you don't, just find someone else who does.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
