#289 | |
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
I wont say im a expert at tuning but what im seeing on his dyno sheet is very obvious to whats going on. Im not saying maxing the turbo out is bad just saying he did that and his dyno proves it. As for running lean its not detonation you need to worry about its going to be scuffing pistons and cracking rings and ringlands and pre-ignition. |
#290 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
#291 |
Drives: "Burning It Down GTX2860RS XB" Join Date: Sep 2010
Garm, your no hater. I still love you...........In a non-gay way!
My tunnner "Rolo" is coming over to the shop on my side of the bay for a tweak on my ride for street driving. Setting it up as the way I drive and not just a heated pull on the dyno. XBG |
#292 |
#293 | |
#294 |
The actual correct terminology is "no homo."
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
#295 |
xnamerxx: Explain to me how this matters, hes not running a stock cam iirc and not only that he doesn't have a stock intake and why dont his torque numbers drop sharply like they would if he fell out of the stock cams torque band. Not only that doesnt Garm use stock cams with vvti turned off.
You cannot compare Garms build to xB build to Art's build. They are all different. The only thing they have in common is the the are turbocharged. I wont say im a expert at tuning but what im seeing on his dyno sheet is very obvious to whats going on. Im not saying maxing the turbo out is bad just saying he did that and his dyno proves it. What is obviously going on? As for running lean its not detonation you need to worry about its going to be scuffing pistons and cracking rings and ringlands and pre-ignition. How do pistons get "scuffed" BTW detonation & pre ignition is the same thing.... |
#296 | |
^that post is for Carlos. For everybody else that doesn't understand what is going on, I'm not saying these two builds are in any way identical. Also, Cotton needs new shorts, and I still would like some discussion on ETs, as I am a 1/4 mile nut. Aras, did you run the old build? Are you gonna run this one? Any idea what you think she'll run? And I'm out of beer. Anyone close to VA?
#297 | |
1 The port job on the head 2 Weapon-R sheet metal intake 3 Edlebrock Victor-X 70mm TB 4 Garrett GTX-2860 RS Turbo w/ SS Housing and Billet Wheel 5 LHT Performance custom Exhaust manifold/ down pipe and all intercooling pipe 6 680cc Precision injectors All the above items make HIS build incomparable to Garms or Arts...... |
#298 | |
I actually took the time to respond to each of these points individually and weigh a valid argument for why the builds are similar enough to be comparable, but then I re-read your response, and realized that you are far too defensive and obtuse at this time to actually give any serious thought to a word that I would have said. I initially though that someone with (what I thought was) your level of understanding of what goes in to engine design would understand my initial comment, hence why I singled you out so that others wouldn't read in to what I had posted. I guess I had given you too much credit, although I doubt that's it. In my experience with you, you seem decently knowledgeable. Perhaps you just aren't willing at this time to hear any other points of view. Some other time, I guess. Also, I'm still out of beer. How close are you to VA? Wanna grab a beer and talk shop? My treat...
#299 |
defensive and obtuse, wow. And on that note Im done........
#300 |
No, no, no. You got it all wrong.
You're supposed to say "What? What did you call me" and then I'm supposed to post "Obtuse. Is it deliberate?" And then you're up again with "Son, you're forgetting yourself." and we go back and forth like that for a while, and I end up getting a bunch of time in solitary.
#301 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
Ehh whats going on here
. Been awhile since i seen this type dribble since Tamago days . Lets not attack each other over a dyno sheet its not that serious.
#302 |
I'm not attacking anyone.
#303 |
So can we see that video? :)
#304 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
I really don't understand this post and I hope that XBgod can respond clearly here
#305 | |
0-60 in slow
When you run lean your combustion temperatures get hotter then optimal. Heat causes metal to expand. Since a piston and cylinder only have so much clearance if the metal expands to much it will reduce clearances and press against the walls of the cylinder which causes the pistons to scuff in the bore. Also running hotter will cause the rings to expand more then designed for and if the rings touch end to end they will crack and probably break the ring land in the piston causing a failure. As for detonation and pre-ignition being the same thing no. If you believe that I suggest you google the subject. You get detonation from a many things but it always happens after the spark and pre-ignition before the spark. Since you clearly don't understand/believe the information being given maybe you should try to prove why your right rather then argue why I'm wrong. |
#306 |
I stand corrected on the detonation/pre ignition. As for anything else I will comment no more.
| Want to build costom turbo kit. Need advice from boosted guys! | pimp my yaris | Forced Induction Forum | 639 | 09-28-2013 11:26 AM |
| FS: 2005 Scion xA RS2.0 Turbo | uberegg | Cars for Sale by private party | 40 | 04-03-2010 11:45 AM |
| Scion xd turbo | PARIS | Yaris TS Talk | 22 | 02-26-2010 08:08 AM |
| Chevy Aveo RS: Turbo + good looks = build it! | Thirty-Nine | Off-topic / Other Cars / Everything else Discussions | 22 | 01-12-2010 12:36 PM |
| Check out the new Scion iQ concept. In the States in 2011/2012 | LA Yaris | California | 9 | 10-23-2009 08:11 PM |
