Old 05-19-2009, 12:07 AM   #1
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Total running tally for this mod so far:
$9.50 for two black switches, two packs of resistors, and the little LED mount thingies
$3.50 for pack of 4 switches for the clutch switch
$???? for the LED light module (soon to be completed by CTScott)
Also include the cost of wire, some spade connectors, soldering stuff, electrical tape, all of which I already had.
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-19-2009, 10:50 AM   #2
I just road tested the LED driver module on my 09. Having the indicators on the combination meter was quite handy. It took a couple of rounds of the PIC firmware to get the switch debouncing correct. I am shipping it to you today. Below are a couple of pictures (the PCB and the packaged module). I will post the schematic when I have a chance. The module hardware is fairly simple; basically a Microchip PIC12HV615 microcontroller (with built-in shunt regulator), 9 resistors, and a NPN transistor. The PIC microcontroller monitors the switch input via one of its analog to digital inputs. This lets it sense the difference between the on/off switch and the other switches. The PIC "HV" series microcontrollers have a built-in regulator which allows them to operate off of an unregulated power supply, eliminating the need for a voltage regulator.
As you can see from the labels, there are three connections:
1. Switch Input - This input gets connected to the wires going from the ECM and ground to the switches (Red to CCS and Black to ground).
2. LED Output - This output drives the Cruise Control on/off LED. This supplies 12 VDC, so it is intended to drive a panel mount LED with a built-in resistor.
3. +12 VDC power input (IG switched) - This wire gets connected to an ignition switched 12 volt source. The easiest place to connect to is the pink wire on the ignition switch connector.
This module will work with the DIY switches or with an OEM cruise stalk. I am shipping nickhjort's for no charge in appreciation for him being the guinea pig for this mod. If anyone else is interested in a completed module, I would probably need to charge $25 shipped to cover the parts cost (with the silly little box being the most expensive component) and labor to assemble.
Old 05-19-2009, 12:56 PM   #3
PatrickJohnson
Drives: 2008 Yaris LB
I'd love to see a schematic. I would be willing even to have some PCBs etched for people as drop-ins. Does this just drive the On/OFF LED? What about the SET light?
EDIT: I see you mentioned it can sense the difference between the switches, so I assume this drives both LED's. Again though, if you post the schematic I can etch actual circuit boards (instead of perfboard) for you or anyone else if there is interest.
PatrickJohnson is offline   Reply With Quote
Old 05-19-2009, 01:34 PM   #4
It just drives the power LED. Because the switches are all paralleled together, the ADC is required to differentiate the on/off switch from the other three.
The problem with driving a SET LED, based on just the switch, is that there are too many conditions where you could press the switch, but not really be "set". Tonight I should have a chance to drop the schematic into ORCAD. If there was enough interest in the modules I figured I would do a run of boards.
Old 05-19-2009, 02:06 PM   #5
PatrickJohnson
I see. pretty cool either way. I was thinking of just doing a cmos flip flop switch to run the LED. I figured I could use the connection made by the on/off to touch a flip flop circuit or a relay and reset it's state, turning on the LED. of course, that might be using a sledgehammer to drive a thumb tack :)
Old 05-19-2009, 08:46 PM   #6
Here's the schematic:
Old 05-20-2009, 04:42 PM   #7
mg_xpower
mg_xpower's Avatar
Drives: na
Nice work. Please consider the fact a car power supply is really "dirty". You'll have to take bursts and surges into account. I'd add a nice big elco to VDD (at least 100uF 35V) and a 100nF 50V X5R/X7R ceramic capacitor close to the controller.
Are you measuring battery voltage at p6 ? -> Add 100nF over R7.
Citroen C2 MGF
mg_xpower is offline   Reply With Quote
Old 06-03-2009, 12:17 PM   #8
regal
If you have an 09 LB I'de say the ebay stalk with a sparks oem clutch switch is the way to go, anyone tried it/.
Old 06-05-2009, 11:20 PM   #9
nickhjort
nickhjort's Avatar
Hold on just a couple more days and I'll have that module installed. I just haven't had time to rip the dash again. I also have to rethink my clutch switch, the switch broke. That's what I get for going cheap :) Anyway, I'll prolly just buy the oem one. I'll put picks up when I'm done with all of this...
My Car Rules!
Old 06-05-2009, 11:25 PM   #10
regal
but I understand an 09 has no need to rip apart the das?
Old 06-06-2009, 11:30 AM   #11
PhilD424
Drives: Red Yaris
http://store.summitracing.com/partde...5&autoview=sku
-Phil
PhilD424 is offline   Reply With Quote
Old 06-06-2009, 12:45 PM   #12
Originally Posted by PhilD424 View Post
The cost of that kit is exactly why we looked for a cheaper route. Looking at the installation instructions for it, it actually does the cruise control itself, as opposed to using the Yaris's built in functionality.
Old 06-06-2009, 11:24 PM   #13
lunjiaow
lunjiaow's Avatar
Well i pulled apart my dash on the 07 Australian Delivered Yaris, to find there is no CCS blue wire from the ECM to the AD4 Plug. Unless i got it wrong but there was a blue wire on the bottom row which i doubt was the CCS wire.. Very disappointing.
lunjiaow is offline   Reply With Quote
Old 06-07-2009, 03:40 AM   #14
PatrickJohnson
You can run one very easily. It took me literally 20 minutes to install this from popping the hood all the way through to drive testing. And i had to run a wire.
Old 06-07-2009, 07:55 AM   #15
lunjiaow
lunjiaow's Avatar
Ah yes. i saw on Page 16... will give it a shot tomorrow.
Old 07-20-2009, 12:17 PM   #16
Vince87
Drives: 2007 2DR Yaris
Hi guys ! first of all I want a thanks everyone who contributed in making this amazing mod available for everyone, especially CTScott and . I found this community while I was looking for a DIY CC installation for my Yaris, and I never thought I would be able to make it for less than 10$, thats just the coolest mod ever ! I followed very carefully your instruction and still can't make it work... Here's a few pics of my installation :
The switches
Connector D3 without CC wires
Red wire from switch to pin 40 of connector A21
Gray ground wire in the back grounded in the door sill
Jumper from clutch switch cable to ground
At first I thought that my ground was bad so I changed from a bolt behind the passenger glove box to that one with no success... I also changed the jumper wire to a bigger one. I still believe that the problem is the ground, I have a multimeter and knows how to check if a ground is really a ground but not if it is a good one. If any of you can explain it to me it would be very appreciated ! Thanks
Vince87 is offline   Reply With Quote
Old 07-20-2009, 12:28 PM   #17
The switches
Try soldering the wires to the switches. If you just have them twisted, they may not be making a reliable connection.
Old 06-10-2009, 11:38 AM   #18
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
i have read most of this thread looks cool and cheap for cruise control . so on my early 08 lb automatic i can use the oem stock and what else do i need ? please help i put ton of miles on my car and cruise would be way nice to have for cheap
pennyracer is offline   Reply With Quote
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
