Old 10-22-2010, 10:54 PM   #307
yarisbird
yarisbird's Avatar
Drives: 2007 Yaris HB Bayou Blue
Thumbs up
Great. Thanks!
yarisbird is offline   Reply With Quote
Old 11-08-2010, 11:03 PM   #308
Originally Posted by cicici00 View Post
Hello all,
I hope my question isn't stupid. I have been reading all the forum hours and hours. They are kind of confusing. BTW, I have 08 Yaris LB.
So, I ordered a cruise stalk from here:
http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories
I understand that I can just "combine" the "DIY cruise control 07-08 with button" and "OEM stalk 2009", then everything should work magically.
Here are my questions:
1. So, the stalk I purchased from eBay could be just substituted as the switches in "DIY cruise control 07-08", right??
2. If Question 1 is a yes, then how do I know which wire from the stalk goes where?
3. Do I need to get any other parts besides the stalk?
1. Yes.
2. It actually doesn't matter which of the two goes to the ECM pin 40 and which goes to ground.
3. Yes. You need a repair pin for the ECM and one for the connector under the steering column. See this thread for the details:
http://www.yarisworld.com/forums/sho...ght=cruise+faq
Old 11-09-2010, 07:36 AM   #309
CB900F2
Drives: 08 Sedan
Hi Scott.. I priced out the two repair kits for the connectors (82998-24250, 82998-12870), and man they are pricey.. They are $11.98 each. Do you know what comes in the kit for $11.98?
1. Yes.
CB900F2 is offline   Reply With Quote
Old 11-09-2010, 10:41 AM   #310
A little piece of wire with the pin attached is all that you get for $12. I recently bought the parts so that I can offer the 3 pin/wire set for $10 shipped.
Old 11-09-2010, 03:49 PM   #311
Thanks for the answer. There must be something I still not getting. In the instruction, DIY Cruise Control 07-08, it did not say anthing about the "repair pin". If I missed it, please kindly point it out...
Isn't the repair pin.. just a piece of wire??
And, what is a repair pin? any pictures? what does it do?
Thanks!!
The DIY shows just sticking a piece of wire into the connector. This is not a good long term solution, as it will allow moisture to enter the sealed connector. The repair pin is one of the correct pins (with the rubber seal) that inserts into the connector.
Old 11-09-2010, 04:49 PM   #312
Eatoman
Eatoman's Avatar
Drives: '07 Yaris 5dr HB
Just wondering if this CC kit would work on a Yaris? Seems pretty cool!
http://www.conrad-anderson.co.uk/pdf...P300-AP500.pdf
Eatoman is offline   Reply With Quote
Old 11-09-2010, 10:40 PM   #313
It would, but I am sure it's a whole lot more expensive than simply adding the stalk and wires to use the ECM equipped CC.
Old 11-10-2010, 12:45 PM   #314
Eatoman
Eatoman's Avatar
Expensive yes. But then again, there's always a price to pay for "stylish" features.
Old 03-17-2011, 02:21 PM   #315
gam668
Drives: 2008 yaris auto
cc kit 4 2008
Hey CTScott I seen your set up on micro image 4 sale. I have a 2008 Yaris hatchback w/Automatic
vin# Starts J1DJ and ecm is 89661-52g51. Will your package work? If yes how do I pay You for the stalk and wires needed to do this? I would like to do this, IT WOULD BE A GREAT SAVINGS TO ME.... Thanks alot :
gam668 is offline   Reply With Quote
Old 04-17-2011, 08:18 AM   #316
yariskids1
Drives: 2007 hatchback
Thanks to you and CTScott. Just did this yesterday and it works great. I used the 2 switch set up. Took about 2.5 hours all in, time very well spent. Thanks again!
yariskids1 is offline   Reply With Quote
Old 06-17-2011, 05:43 PM   #317
PROX4x4
1.5 or 2.5 both=0-60 in 8
Drives: 08 Toyota Yaris
Thumbs up 08 Yaris HB
Thanks for the step by step info, I was wondering if it works for a 08 Yaris HB? and what type of switches are they, are they the click type (sorry not very professional) or push on-push off type?
Thank you,
PROX4x4 is offline   Reply With Quote
Old 06-17-2011, 06:56 PM   #318
Thank you,
The switches need the be momentary normally open switches. Momentary is the type like a key on a keyboard, where you press it and it pops back up. Normally open means that it completes the circuit when you press it.
Old 06-19-2011, 07:42 PM   #319
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Is anyone having an issue with the cruise control indicator light? For some reason my LED doesn't light up when I engage the cruise (OEM stalk) all the time. I will press it again to disengage it and then it comes on. It will do that sometimes, and sometimes it won't come on at all when I engage it, and other times it works properly. At first thought, was thinking it might be a short -- but it only happens when the cruise is either engaged or disengaged as opposed to just randomly coming on or off while driving.
white_rice is offline   Reply With Quote
Old 06-19-2011, 08:07 PM   #320
The indicator module detects the voltage change when the on/off switch is pressed. If the connections between the ECM and the stalk are not solid, then the voltage drop across them can cause the module to misinterpret the press.
Old 06-29-2011, 12:45 PM   #321
PROX4x4
It's actually 240 and 390.
You can use any value within these ranges:
216 to 264 ohms for one between resume and on/off
351 to 426 ohms for the one between set and resume
819 to 1001 ohms for the one between set and cancel
For wattage, 1/8 or 1/4 watt is fine.
I wonder if this switch would work for the on/off & Set setting for this type of cruise control setup?
http://cgi.ebay.com/ebaymotors/CARLI...Q5fAccessories
Old 06-29-2011, 12:53 PM   #322
The switches need to be momentary. That on is ON/OFF/Momentary, so it would be OK in one direction, but not the other. You'd want Momentary/Off/Momentary.
Old 06-29-2011, 01:08 PM   #323
PROX4x4
Been looking around to see if I can make something funky using your lighting module and resistors set up with below switches, but I guess nothing beats the stock CC setup.
http://cgi.ebay.com/1-Stainless-Mome...item43a7fb8cea
Your innovations clears the way to personal styling of Yarises in this world :D
Thanks again!
Old 06-29-2011, 01:53 PM   #324
Thanks again!
Those would work, and the lighting is isolated from the switching, so that's good as well. For $9 each though the cost for 4 is the same as what I sell the stalks for.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
