Old 01-04-2009, 06:25 AM   #307
NonStopTuning
Do we have any new NST Pulley owners with user reviews or comments to share?
MIKE @ NST
www.NonStopTuning.com
Old 01-05-2009, 01:44 PM   #308
ruimond
Drives: Yaris YR
I was thinking of getting the NST pulleys, but didn't want the invest in the whole set yet. As it cost queit abit. I was just wondering from what i've read the Underdrive Crank Pulley would provide the most gains? Is there much of a difference in gained power from say Crank+Alt+Water Pulleys and just Crank Underdrive by itself?. Im thinking of just getting the Underdrive first and might skip the rest if they don't provide as much of an improvement.
Old 01-05-2009, 02:02 PM   #309
Klink10
Klink10's Avatar
Ruimond
I wish I could give you a solid answer on that, but it would be from the Butt dyno vs real world figures. I did mine with the regular crank pulley plus alt. and WP from NST until they came out with the underdrive. Then I went to that. NST should have some figures somewhere here on the breakdown in gains...where I don't know. Send them a msg. and ask. Or ask Calis Yaris at Micro Image he lists their products and I'm sure can give you an answer or steer you to what you want to know.
Old 01-06-2009, 12:48 AM   #310
NonStopTuning
The Underdrive Crank Pulley is definitely the way to go if you can only afford to pick up one pulley.
Let's put it this way...
Want the ABSOLUTE best gains from your n/a or turbo setup? Pick up the Underdrive Crank Pulley along with the Alternator and Water Pump Pulley Kit.
On a budget and want 65% to 70% of the performance you would get if you had the FULL setup? Then go with the Underdrive Crank Pulley alone and pick up the other pulleys in the future.
The majority of our customers pick up a crank pulley and then come back for the other two pulleys a few months later, once they experience the gains from the crank pulley.
Good luck and have fun with all your projects!
MIKE @ NST
Old 01-06-2009, 01:57 AM   #311
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
im not sure if i posted this or not but i picket up the complete set on ebay when you sold them there a few weeks ago. shipping was excellent and the items arrived in perfect shape! the install was easy (i have access to air tools though) and straightforward. the car revs a bit quicker and feels stronger through the whole powerband.
this is a perfect first mod!
Old 01-06-2009, 06:18 AM   #312
NonStopTuning
Thank you for posting sir! We appreciate it!!!
MIKE @ NST
Old 01-12-2009, 01:59 PM   #313
NonStopTuning
More user pics, thoughts, comments would be appreciated!
MIKE @ NST
Old 01-12-2009, 03:38 PM   #314
1NZYaris1
1NZYaris1's Avatar
These photo's where taken a few day's ago , the pullies have been in the car for 18,000KM's and no sign of wear or anodiseing comeing off .
Old 01-14-2009, 02:14 AM   #315
nigel
Drives: yaris
does the pulley kit works on the japanese corolla with 1.5liter engine?
nigel is offline   Reply With Quote
Old 01-14-2009, 01:56 PM   #316
NonStopTuning
It will work well if you have the 1.5liter 1NZ engine, with electric power steering!
MIKE @ NST
Old 01-21-2009, 12:13 PM   #317
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
What happened to the DIY guide for the water pump and alt. pullies?
cm07yaris is offline   Reply With Quote
Old 01-21-2009, 05:52 PM   #318
NonStopTuning
Good question!
MIKE @ NST
Old 01-21-2009, 06:03 PM   #319
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Not yet man , Whats up with sponsorship???
Old 01-21-2009, 06:16 PM   #320
NonStopTuning
blacksandiegovitz, you have a PM.
MIKE @ NST
Old 01-21-2009, 08:06 PM   #321
ruimond
Drives: Yaris YR
Just got my NST Underdrive Pulley and NST Shifter Cable Bushing in the mail! So excited, will be getting it installed this afternoon and post results.
Old 01-21-2009, 09:37 PM   #322
NonStopTuning
AWESOME!
MIKE @ NST
Old 01-22-2009, 03:15 AM   #323
ruimond
Drives: Yaris YR
Went to my mechanic today to get the underdrive pulley and shifter cable bushings installed.
First impressions of the underdrive pulley, it felt alot lighter then the stock crank pulley. Which was good. Installation was fairly quick about 30-40mins tops.
One problem my mechanic mentioned that he had the push the tension to the max setting which could require a shorter belt in the future if it started making start up noises/squeeks. But none the less he said it was good for now anyway.
Started the car up. No sound issues. Driving impressions were good, it felt abit smoother to get up to speed. The throttle response was abit more revvy, but i did not get to fully test it. So it did not seem like it was a huge difference, but there is definately abit more punch.
Onto the shifter cable bushings, my mechanic installed the fairly easy. Moving it around for the first time after the bushings were installed it felt very stiff, i almost could not move it. Haha, but after a few shifts while the car was sitting, the movement came back. I have the NST Engine Short Shifter and i must say that they work well together. It feels alot more firmer then it was, which makes it alot better to drive now.
Overall i'm pretty satisfied with these products, but i'll have to give the pulley abit more testing
Old 01-22-2009, 02:30 PM   #324
NonStopTuning
Thanks for the full review sir! Your NST mods will be more enjoyable as time passes, I promise.
Good luck and have fun with all your future projects!
MIKE @ NST
