#307 |
#308 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
The other issue is the engine harness for the 2az likely doesn't match up to the yaris harness like the xd's does.
Doesn't mean it wouldn't work, your just have a lot of rewiring to do and your want to have wiring diagrams for both cars to know what ever wire does on the engine harness
#309 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
True true.. also size may play a factor. Probably not enough room in the yaris if it is a tight fit in a corolla
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
#310 | |
![]() ![]() ![]() Drives: 2014 Yaris Join Date: Feb 2017
Also make sure if you run just a motor swap without the transmission, that the 2AZ mounts up to the Yaris trans. You may want to do a whole powertrain swap with trans and axles. Sent from my iPhone using Tapatalk |
#311 |
the 2zr in considerably tallker than the 1nz and seems to be wider as well. Not too sure how the 2az compares size wise to either engine
#312 |
Yea, be we are talking about a 1.5L to a 1.8L which having a longer stroke in the crank (if the cylinders are the same size) will make the engine taller and wider obviously.. but now the 2az is a 2.4L, so I am sure that boy is much fatter
#313 | |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
#314 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
I actually located and prepared to do the 2az swap 4 months ago. A guy wanted a 2zr swap, so I offered him mine and I would attempt the 2az.
The project got abandoned once the buyer backed out, oh well. I'm sure every 2az ECM has immobilizer anyway |
#315 |
The 2AZ also mates to an E351 gearbox, so it's probably not a direct fit to the C50.
#316 |
Data doesn't lie
Needing a transmission and axles also makes the 2.4L swap much more difficult and expensive. It would be cool but not easily performed like the 2zr. It may be cheaper to buy a turbo kit for the 2zr vs attempt the 2az swap
#317 | |
http://www.turbokits.com/Toyota/Corolla/Turbo_Kits/ |
#318 |
Turbo kit... would Probably have to be custom header and down pipe... but would use the piping and other components from a yarisingle zage kit..
#319 | |
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
Sent from my phone with Tapatalk. Please excuse any typpos. |
#320 | |
Data doesn't lie
#321 |
#322 |
That's a steal!
#323 |
Data doesn't lie
#324 |
![]() Drives: Yaris 2006 2ZZGE Join Date: Nov 2016
5 bucks less
http://monkeywrenchracing.com/produc...-matrix-09-13/ But you will probably would like to upgrade the turbocharger to gt2860rs |
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
