Old 07-01-2011, 11:26 PM   #1
Iain
Drives: 2007 Yaris
ABS AGAIN
I have two 07 Yaris', a sedan and a HB. The ABS problem, I believe, is due to road salt probably causing corrosion. The dealer will fix, I believe, for about $600 - $1000 by replacing all the wiring (not needed only the rear wheels cause the problem). I found that the front wheels were fine. However on the rear wheels the elctrical connection going into the wheel hub does not have an outer plastic insulation covering (as it does on the front hub) only the individual wires going to the sensor. I sprayed the cables with WD40 and then regular engine oil and filled the little pocket/pit/depression with oil at the hub. After a couple of weeks the ABS came on less frequently. Now after about a month it no longer comes on at all and that has been like that for about 4 months now. Got the idea because the one vehicle I had rust proofed never developed a problem. Hope this helps someone and save a pocket full of cash.
It's heaven, before the ABS light was always on.
Cheers Iain
Iain is offline   Reply With Quote
Old 07-02-2011, 01:49 AM   #2
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
If you're handy and Toyota seems a bit much, you can always order 2 new after market rear ABS sensors for $288 CAD (taxes, brokerage and shipping included) from Rockauto. http://goo.gl/L6z5o
salmonz is offline   Reply With Quote
Old 04-14-2012, 12:43 AM   #3
"G"
Drives: 2007 Yaris Hatch
Here is how to save your toyota from rusting if you drive it in the winter >> http://www.fluid-film.com/ Spray it on all metal surfaces underneath your car and suspension. As well as these skid sensor connections and you won't have these problems. This stuff is amazing.
"G" is offline   Reply With Quote
Old 01-30-2013, 02:00 PM   #4
aromo
Drives: Yaris 2007 Sedan
Just joined to post that last night my wife's Yaris 2007 Sedan had the same issue described here. 85,000 Km on it and warranty expired 2 months ago!!
Still there is no response from Toyota. I filed my complaint this morning with Transport Canada, let's see what happens on that front.
Thank you for sharing your knowledge, especially the TSB numbers (TSB-0120-08 for US and TSB3027 for CAN).
What I'll do is take it to a shop for sensor cleaning, if it doesn't work take to the dealership. I need to hear their diagnostic and get a quote for fixing it, then ask them to fix it for free as it is an acknowledged defect and I have serviced the car at the dealership for 5 years to keep the warranty (now expired) current. If they don't accept to fix it for free, I will submit a claim at Canadian Motor Vehicle Arbitration Plan (http://www.camvap.ca/claiming/apply/).
I am going to replace my car (Toyota Corolla) with a minivan this Spring and was considering the Toyota Sienna, but the way Toyota is handling this issue makes me think twice about that for sure.
aromo is offline   Reply With Quote
Old 02-04-2013, 09:08 PM   #5
edmscan
edmscan's Avatar
Drives: 2020 Corolla
It seems that my car cannot make up its mind what it wants to do. Some days .. the ABS/Emerg light is on and other days it doesn't show its face. I will just ignore it I guess .. and see how that works out.
edmscan is offline   Reply With Quote
Old 04-10-2014, 02:31 PM   #6
robkay
Drives: Hatch
Can somebody help with a question? I'm trying to do the rears. Does that clip on top actually get removed, or is it a molded part of the connector? I lift the clip with a screwdriver, then try to pry to connector back with another screwdriver and the connector doesn't want to slide off easily. The connector is somewhat loose because I can actually slide it back and forth a tad. However, there is significant resistance to sliding the connector off. Am I just being too timid about prying on the connector to pop it off? I just don't want to break it. Thanks,.
robkay is offline   Reply With Quote
Old 07-28-2011, 11:56 AM   #7
ChitownY@Ris
ChitownY@Ris's Avatar
Drives: '07 Yaris Sedan
These sensors went out on me a couple times. Each time they were covered by Toyota warranty. First time was a few months after I bought the car brand new. Second time was two years later, which I thought was related to me pulling the hand break and drifting from time to time. But as I said, Toyota replaced sensors nonetheless. Now I have 2000 miles left under my 75000 mile warranty, so after that if it happens again, I guess I'll be in the same boat as some guys here looking to buy sensors and DIY.
ChitownY@Ris is offline   Reply With Quote
Old 07-29-2011, 12:21 AM   #8
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Mine are ON all the time now! I guess I'm going to have to get down there and solder them directly.
D.
CLA 250, 4MATIC
Old 08-20-2011, 10:39 AM   #9
jit
Drives: yaris sedan 2008
i did an abs at dixie toyota for 1000 cad right in the thick of a january snow - they changed wire and the calipers or so i think - sometimes when it rains i also have an engine check - surely toyota canada does not not give a damn of canadian weather for our 20000plus money - toyota was the best, now falling way behind ford, hyundai et al.
They need take responsibilities of their mess over n over, Toyota Engineering My Ft!
jit is offline   Reply With Quote
Old 10-13-2011, 02:36 AM   #10
derickveliz2
Exclamation
TOYOTA please take notice!
This is why my lights (ABS + BREAK) turn on! (I'm guessing)
I did solder them directly and cover with a Sealant. We'll see how much they hold on!
D.
CLA 250, 4MATIC
Old 11-06-2011, 06:46 PM   #11
Dave
Drives: 2007 Yaris Sedan
Just a friendly reminder to check on your sensors if you're changing over to your winter tires in the next three weeks or so. I know I'll be giving them their annual cleaning and application of dielectric grease.
It's a lot easier to clean them now, before the temperature gets into the negative double-digits!
Dave is offline   Reply With Quote
Old 12-02-2011, 06:27 PM   #12
Delfire
Quebec greekster
Delfire's Avatar
Drives: Yaris Hatchback
I just want to say, that whichever the problematics with sensors, specially ones around wheels, underbody, try lubing them with dielectric grease, or grease, whatever. Cause no matter how many times you change em, water, ice, salt snow.. aint helping.. and seems Toyota made a big bobo with Yarises or othr model sensorabilia.... up to date, i have changed, ABS sensors, Alternator Sensor, The radio ( a lil transistor thing burnt inside it) , and now im on my Camshaft sensor... Yeeee i wonder wich sensor will go next!? good thing i get parts cheap or free, and make em myself.. when its sunny... and aint raining or snowing.....
Note, before changing your ABS sensor, clean the connectors,and add dielectric greasse they should work just fine. IF pin isnt brocken from rust.
Delfire is offline   Reply With Quote
Old 12-02-2011, 07:46 PM   #13
"G"
My brain is hurting after trying to read your post ^^^^^.
Old 01-01-2012, 04:23 AM   #14
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
Yeah I had this problem last winter, the lights would come on and then go off a few days later, after winter it had not come back on, we still are waiting for our first snow here in Kentucky, and I feel it will start coming back on... I have 198,000 miles on my vehicle now, should be at 200,000 by end of January.
198K Miles
N9QGS is offline   Reply With Quote
Old 01-02-2012, 01:50 PM   #15
Gman
Drives: 2008 yaris
I am back after almost a year and with good news. Since following the instructions here about opening the connection and cleaning the leads and then plugging it up with dielectric grease I have not had the light come on, and I have not lost my ABS brakes.
Big thanks to those of you who posted pic's and explained this easy fix.
Sad to see Toyota not putting a recall on this since it is a very dangerous situation. A couple times I would have ABS and then poof lost it when the lights came on, pretty scary stuff when you are skidding along a highway with cars on front and behind you.
So if you have not tried this fix, TRY IT!!!! My independent garage did it for free when I had them switching my winter tires to my summer tires.
Even if you DO NOT have this situation, I would do it as a preventative measure.
Gman is offline   Reply With Quote
Old 01-03-2012, 12:22 AM   #16
"G"
Uhm your an idiot. When the light comes on you lose abs, but you do not lose any braking power.
Old 04-13-2012, 09:57 PM   #17
Gman
Drives: 2008 yaris
I never said I lost braking power, I said I lost ABS. BTW thank you for sharing your maturity level with all of us with your "idiot" comment.
Old 04-13-2012, 10:06 PM   #18
auxmike
auxmike's Avatar
