Old 06-10-2009, 12:35 PM   #1
mrbond
mrbond's Avatar
^ you need wires going from the ECM to the little hub in the steering wheel column, a wire going from that hub to a ground point, and the stalk, and then a jumper wire for two pins in the engine bay. Everything's been outlined and explained, so you just need to read carefully. That's about it. I'm selling my stalk btw, since I just don't really want it.
- A Toyota Yaris
- A whut Yaris?
Old 06-10-2009, 07:46 PM   #2
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
cool thanks for the input
pennyracer is offline   Reply With Quote
Old 06-11-2009, 11:54 AM   #3
petyanca
Drives: 09 LB, 3 door, auto
So it should work ..
I have 09 3 door liftback, and it seems all I need is a stalk. Could someone give me a link to where you got the stalk ? Thanks a lot for the investigating this !
petyanca is offline   Reply With Quote
Old 06-11-2009, 12:03 PM   #4
regal
If you have a clutch you need the clutch switch, the part number is in this thread
Old 06-11-2009, 02:34 PM   #5
Either ebay ($12.99 + $17 shipping):
http://cgi.ebay.com/ebaymotors/TOYOT...lenotsupported
or TRDSparks.com ($81.99 plus shipping):
part number: 84632-34011
Old 06-18-2009, 01:46 PM   #6
menz
Drives: yairs blue 2007 automatic 1.3
i am going to try this soon as i get bk home next month i have 07 yaris i just hope ull all b here to ask for my questions
menz is offline   Reply With Quote
Old 06-18-2009, 02:15 PM   #7
I don't think it will work on your car. On European manufactured Yaris cruise control is not an OEM option, so the ECM doesn't support this mod.
Old 06-20-2009, 08:00 PM   #8
Prisonguard
Drives: 5 door hatch
Ok, after reading all these posts I am now REALLY confused so please bear with me since I am also new here. I have an '09 S 5 door liftback, auto trans. In real simple terms since I am not an electrical engineer, what do I have to do to have the factory cruise installed. The dealer wants over $500 for an aftermarket one which is ridiculous.
Prisonguard is offline   Reply With Quote
Old 06-20-2009, 09:26 PM   #9
With an 09, you can simply purchase the OEM cruise control stalk (Toyota part number: 84632-3401), pull the steering wheel and install it, and you'll have cruise control.
Or, check out this thread for adding cruise to your 09 auto for about $10:
http://www.yarisworld.com/forums/sho...ght=diy+cruise
Old 06-22-2009, 03:04 PM   #10
Henry G.
Drives: 2008 Yaris HB
Just to confirm after reading 24 pages.....this will work on an '08 MT but you need the stalk, the clutch switch and need to do some wiring to the fuse box, correct?
Henry G. is offline   Reply With Quote
Old 06-22-2009, 03:13 PM   #11
Correct. We really need to do a DIY for 07-08's...
Old 06-22-2009, 05:14 PM   #12
Henry G.
That would be AWESOME. Thanks for all the info so far guys, great job.
Old 06-24-2009, 09:20 PM   #13
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
when I finally get around to doing it, I will make one, however it will be the stalk method, since I like more of an oem look.
Old 06-22-2009, 05:20 PM   #14
POORSHA
POORSHA's Avatar
Drives: 2008 LB
I have a 08 mt lb and a stock, lets do it.
POORSHA is offline   Reply With Quote
Old 06-22-2009, 09:36 PM   #15
For your MT you're going to need the clutch switch as well. It's OK to bypass it for testing, but for normal use you really should have it in place.
Anyone else from the New England region interested in doing theirs? We could do a DIY cruise control workshop.
Old 06-23-2009, 12:02 AM   #16
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
I may move the led I have mounted next to the switches up into the guage cluster before I install the LED module CTScott has provided. Make it look a little more stock-ish. Also scott, if my LED is too bright I can just add a resistor of my choice in series and that'll dim it down some correct? And also I'm going to just buy the stock clutch switch for 20$ from the dealer, rather than try to fix the frankenstein I put together :)
My Car Rules!
nickhjort is offline   Reply With Quote
Old 06-23-2009, 09:26 AM   #17
Yes, you can add a resistor to dim it. If you used a blue LED, you might have to go up to between 30K and 50K Ohms for it to not be blinding.
Old 06-23-2009, 03:33 PM   #18
POORSHA
POORSHA's Avatar
Drives: 2008 LB
A workshop would be great.
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
