#325 | |
![]() ![]() ![]() Drives: two yaris liftbacks Join Date: Jan 2006
#326 |
![]() ![]() Drives: 06 Silver Yaris 3-door Manual Join Date: Feb 2006
43.57mpg when I filled today. All city driving - very hard at times.
#327 | |
![]() ![]() ![]() ![]() ![]() Drives: 06 3-dr auto RS Join Date: Jan 2006
#328 | |
Only Happy When it Rains
Go by what is on the tire, not what the car says. As long as you make sure to keep the pressure within those limits, then the higher up in that range you go, the better it is for gas mileage. And while too much air pressure is a bad thing, there are rumors of some tires being overinflated too 100 psi, etc, and the tires not having a problem. In general, if you try to overinflate a tire the air pump will blow long before the tire does.
Colin Chapman disciple |
#329 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
umm how do i do the math, I got 598Km on my first tank, it took 38l to fill it, whats the formula?? 598/ 38= 15.74km/l I then took 100km/15.74 and got 6.35
so if this is correct I got/used 6.35l per 100km, which is close to sticker epa ratings.. |
#330 | |
It's all about VVTI
Drives: Yaris 5Dr LE White Join Date: Feb 2006
One really stupid question tho, should all tire pressure to be the same to get best milage?
Ziv on Vitz '06. |
#331 | |
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback Join Date: Mar 2006
#332 | |
It's all about VVTI
Ziv on Vitz '06. |
#333 | |
5 Stars, Bitches
#334 | |
It's all about VVTI
Ziv on Vitz '06. |
#335 |
5 Stars, Bitches
Heh, I think mine are set ridiculously high right now because I didn't let air out after the rallycross I cranked them up for. :O
#336 |
Prototype Tester
Drives: Yaris S-Sedan / FJ Cruiser Join Date: May 2006
Yes you might get some better milage by increasing your tire pressure above the factory recomended settings - but remember you will also increase uneven wear (the centers will wear out before the edges) your braking will be reduced and your corner grip will be reduced - plus the harshness of the ride will be increased... all cause by overinflating the tires.
The numbers on the door are a result of lots of testing with that size tire on that excact style of car - it's the pressure that gives you the best milage along with the best contact patch of rubber on the ground that size tire for that car. Reduce that, and you get less milage, more wear on the edges, and slop and roll on curves. Increase it, yes you might get some milage, but less rubber and control on the ground, harsh ride, and wears the middle. So keep that in mind.. Oh yeah, drive a car with tires inflated to the max in rain? That's just asking for loss of traction in either braking or corning, and even hydroplaning. Those numbers are not just random that they post on the door. As for the max tire pressure listed on the tire? It's just that, it's the max the tire should ever be inflated under any condtions, it's what it's tested to at the rated speed. Go over that or the speed rating and the tire could fail is what they are saying. Just because your engine is rated for 6500 RPM max before redline does not mean you should drive it there all the time. The most I'd go over the door sticker is 5psi, that might gain you some milage but still have a good contact patch. You can also increase it if you have a heavy load in the car. And it usualy is correct, the front will be higher than the rear due to the engine weight, but if so the door sticker will list a higher number for the front than the rears. Toyota has already paid engineers the money to figure out the correct tire pressure for the car, why go around guessing on your own? There is some tests you can do to find the right pressure for a modified vehical, I do this all the time with modfied trucks with oversized tires for street use, but the point is on a factory Yaris with the factory sized tires it's all been done for you by experts, listen to it. |
#337 | |
MORDSITH
Drives: 2007 Yaris Hatchback Join Date: Apr 2006
I was just there on Monday around 1030am dropping off a friend on my way from TO back to Collingwood. And yea, RH, not many hills... now fucking NEWMARKET!! THat's a WHOLE bloody OTHER story! Egad! LOL Newmarkt is BRUTAL for stick IMO!!! |
#338 |
![]() Drives: ecoh Join Date: Feb 2006
I got 42.5 MPG in pure highway mileage. I live in Seattle with lots of hills and get anywhere from 25 to 32 in mostly city driving.
#339 |
![]() ![]() ![]() ![]() Drives: 06 yaris 5-dr le man Join Date: Mar 2006
the best i have acheived is 40 mpg on average, and that is driving very easy 50/50 highway/city, tire pressure is checked every 2 weeks
i don't understand how some can get better mileage in the city, driving hard, are some of us not doing the math properly or can there be that much variation with the same car? |
#340 | |
It's all about VVTI
Newmarket? dude, what da fork are you doing there at the local road? I only drove there during the winter so I felt like I am in a rollercoaster. bahahah, especially on yonge street or bayview. ha ha ha.
Ziv on Vitz '06. |
#341 | |
It's all about VVTI
Ziv on Vitz '06. |
#342 |
![]() Drives: yaris sedan Join Date: May 2006
Thought I'd add this report:
Yaris sedan - automatic For a 166 mile stretch of highway (I86 through New York State, so quite hilly), I used 3.76 gallons, which is about: 44.1 mpg (or 5.32L per 100km). Most of it was at 70mph except for a 20 mile stretch of construction at 50mph. I had the air conditioner on for only a couple of minutes. The trunk was full. I'm pretty impressed by this little car (assuming I calculated everything correctly, and the trip meter and gas pumps were all functioning properly). I'll have to measure it again on my next trip and see if it compares. |
