Old 02-26-2017, 04:07 PM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
^^^ I was going to answer your question, but it looks like you may have found some wheels already! You guys are only about 100km's (1 hour) apart. Maybe meet in the middle and you're both happy. Good luck.
Old 02-26-2017, 05:46 PM   #2
Jboss
Drives: 2008 Yaris Sedan
I understand all the aspects of the tire and rim sizing except for offset. How do i know if the offset is too high or too low for the car? Stock tires/rims is 46 offset.
Jboss is offline   Reply With Quote
Old 03-01-2017, 02:42 PM   #3
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
I need help with offset two the this description of the wheels will fit with no modifications plus I got trd springs on the way drop is 0.5 front 1.2 rear tire size 195/55/16 ???
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 03-01-2017, 02:52 PM   #4
Yaris874
Yaris874's Avatar
This eat the description of the wheel s
Old 08-02-2018, 05:47 PM   #5
HDTechVideo
Drives: Yaris MK3 1.33L Dual VVT-i CVT
I'm planning to change the tires. Is it ok to change from 175 65 R15 to 205 50 R15.
Im using stock alloy.
HDTechVideo is offline   Reply With Quote
Old 08-02-2018, 06:39 PM   #6
kimona
kimona's Avatar
205/50/15's are a little shorter but will fit the stock alloys fine.
Tyre Diameter: 175/65/15's are 24" (609mm) and 205/50/15's are 23.1" (587mm).
You could go with 205/55's @ 23.9" (607mm).
Old 08-05-2018, 02:46 PM   #7
HDTechVideo
Thank you.
Old 08-05-2018, 07:58 PM   #8
Thank you.
I already told you that weeks ago.
Old 08-06-2018, 12:47 PM   #9
HDTechVideo
Yes I do remember, but I confused with the OP.
Old 08-07-2018, 06:32 PM   #10
HDTechVideo
Ordered this one x 4
https://www.hankooktire.com/uk/passe...ime3-k125.html
205/55/R15
Sent from my SM-G935F using Tapatalk
Old 08-07-2018, 07:18 PM   #11
kimona
kimona's Avatar
^^^ That's actually an excellent choice for tread pattern; non-aggressive for a quiet ride, and a solid, continuous centre band for straight-line tracking.
Please, let us all know how they work out for you.
Old 01-30-2019, 05:43 AM   #12
rayfloyd170
Drives: Yaris 2016 1.3 Manual
i have yaris 2016 1.3 base sedan with stock tires 175/65R14 with steel rims. I am planning to change to 15inch/16inch alloys. Would 16inch be advisable?
initially i plan on 195/55R15 but if 16inch rims will not be an issue with my smaller engine then i will go for it.
What could be the potential problems i will face later on when upgrading to tires with 16inch rims?
rayfloyd170 is offline   Reply With Quote
Old 02-03-2019, 05:34 AM   #13
rayfloyd170
very bad, i already changed to clone OEM Rims 15x5.5 and there is no available 195/55R15 in the shop.. They only have 195/60R15. The worst part i agreed to use it...
Feels sluggish and heavy to me, considering i am on 1.3L engine only. Also i need to put more pressure while braking. If only there is 195/55R15, i guess i need to wait for another 70k KM to change tires... I hope fuel consumption would not be affected that much since now i feel i am running faster with lower RPM.. its like i am ~5km/ faster than my stock 175/65R14
Old 04-30-2019, 08:12 AM   #14
rayfloyd170
Sold my set of 195/60R15 for half the price after using them for 2500km and used 185/60R15 instead... I cannot believe the huge difference in handling especially on corners and theres no more slouch start from my small engine, powerful start is what i need.
195/55R15 could have been much better but i dont want to hit all the crazy humps here in KSA roads.
Old 10-17-2020, 07:36 PM   #15
spoonzz
Drives: 5D YR 2012 Auto
This thread was very handy.
Looking to get 16x6.5" wheels with an offset of +40. Not sure about what tyres though!
spoonzz is offline   Reply With Quote
Old 10-17-2020, 10:42 PM   #16
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
How about a set of Accent 16" x 6.5" alloys? They're cheap, readily available, same bolt pattern, same offset as the 15" RS alloys and the Toyota center caps snap right in.
Here's my car before my coilovers:
https://www.yarisworld.com/forums/sh...ighlight=wharf
Old 10-17-2020, 08:59 PM   #17
kimona
kimona's Avatar
^^^ 16x6.5, ET40 is a great fitment with 205/50/16/'s on stock suspension or with a mild drop.
Old 10-17-2020, 11:02 PM   #18
spoonzz
Damnnn, they do look good! If anything, I want to paint it black and that seems easy enough. I'm gonna have a look on eBay and see if they pop up. Thanks!
Edit: I found some nice 16"/7" wheels with two offset options, +35 and +40. Would either be a good fitment with 205/50/16 tyres?
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
