Old 03-13-2017, 12:33 AM   #325
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
A little write-up on how to convert the 2zrfe over to a external oil filter:
http://www.armstrongfamilyblog.com/a...ter-conversion
Old 03-13-2017, 01:41 AM   #326
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Very cool!
m.flores.0928 is offline   Reply With Quote
Old 03-13-2017, 03:17 PM   #327
ArmstrongRacing
Data doesn't lie
Yaris Sedan weight without interior - MT5
The 2zrVios weight at the National Tour. They had the scaled pads backward of course haha
Old 03-13-2017, 04:20 PM   #328
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Undisputed lightweight Yaris champ lol
On Instagram
On Wheelwell
Old 03-13-2017, 06:49 PM   #329
Jason@SportsCar
Not even close. But it will be interesting to see how light he can get the sedan, because I would certainly consider going that route...
Our 2007 chassis H Prod car (with carbon hatch and hood, when we ran 13" wheels and tires)
Old 03-13-2017, 06:57 PM   #330
m.flores.0928
Drives: 2014 Yaris
That's fantastic. Lightweight is name of the game! Faux headlights?
Old 03-13-2017, 07:05 PM   #331
Jason@SportsCar
Stock lens cover, just cut away the rest of the fixture.
Old 03-13-2017, 07:07 PM   #332
m.flores.0928
Drives: 2014 Yaris
Clever, I like it.
Old 03-13-2017, 08:30 PM   #333
ArmstrongRacing
Data doesn't lie
WOW! Yeah I've got a long way to go, I still have all of the standard equipment i.e.; lights, wiper, evap system, EPS system, glass and regulators, and the passenger seat is there for ride alongs 🤣...
Old 03-14-2017, 01:18 PM   #334
ern-diz
ern-diz's Avatar
Wow, 1814 total.
On Instagram
On Wheelwell
Old 03-14-2017, 01:54 PM   #335
Dabuu
Radical Dreamer
Drives: spiritedly.
Mmm them 13s though <3 wish I could run those on mine.
Enjoy Family Car Sports
Dabuu is offline   Reply With Quote
Old 03-14-2017, 02:08 PM   #336
Jason@SportsCar
We gave up on those, the tires overheated quickly, and braking suffered with the small contact patch.
Old 03-14-2017, 02:18 PM   #337
Dabuu
Radical Dreamer
Drives: spiritedly.
I'd run them purely for aesthetics, and autocross. I love small wide wheels!
Old 03-14-2017, 04:28 PM   #338
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Good to know, I was trying to track down a set of Enkei, Panasports, or Minilites on the market cheap an used. I talked to FastBrakes the other day though, and they said they'd be willing to do a set of 11.0 Wilwood Dynalite front brakes at 15lbs per side versus what he said was the normal iQ brakes at 25lbs. per side, to further reduce my unsprung weight, so I'll probably just keep my 15x7 VOLK TE37s and 195/45/15 Toyo T1R since the combo is down to 25.1lbs each. I personally want to take advantage of every available one of the 94 horses my car came stock with before I modify too much in the way of the engine. Thanks for sharing Jason, this was really informative.
MugenRep is offline   Reply With Quote
Old 03-14-2017, 04:41 PM   #339
Jason@SportsCar
It is not easy to find a 13" that will clear the Yaris brakes without sticking them way out of the fenders, Jongbloed was able to do it, but they were costly. The Jongbloed was 8lbs, so only about 1lb less than an Enkie RPF1 or Volk, the real weight savings is the tire.
http://jongbloedracing.com/wordpress/?page_id=57
Garm had some great looking Compomotives that also fit, which you can still order from the UK. They are not as light as the Jongbloed, but also not as expensive.
http://www.comp.co.uk/wheels/wheels....tion=cxr-20-13
I tired a set of Panasports once that a guy was using on his Miata, in addition to nearly 3/4" difference in offset the wheel was made with I also needed a 1/4" spacer to clear the brake caliper, they stuck out a little.
Old 03-25-2017, 08:32 PM   #340
ArmstrongRacing
Data doesn't lie
Newest video showing the LSD benefits!
https://youtu.be/ED43-Q1EZ6U
Old 04-24-2017, 02:36 AM   #341
ArmstrongRacing
Data doesn't lie
Epic autox battle and FWD driftage
https://youtu.be/-GqqHDwu9cI
Old 04-24-2017, 02:53 PM   #342
Jason@SportsCar
You need some proper tires, and an ECU so you can skip that 3rd gear shift.
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
