Old 10-30-2008, 07:25 PM   #19
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
well now that thats been all cleared up. does the blitz supercharger have an electronic clutch? i was reviewing the installation manual and the wiring diagram and it had this thing for an electronic clutch and i'm assuming thats apart of the S/C bcuz our car sure as hell doesnt have an electronic clutch
Old 10-30-2008, 07:32 PM   #20
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Agreed on all accounts with largeorangefont. The gauges are an indicator to monitor how your parameters are doing. An EGT meter is very important on FI cars, and i'd like to know your readings on track days, to see how hot this motor gets.
The lights on the dash, when they do on, usually it's too late. All the damage has been done, hence the need for gauges.
anonymous user is offline   Reply With Quote
Old 10-30-2008, 07:41 PM   #21
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
And what would be considered too hot on an EGT guage? Do they typically have a green and red zone?
What would be the remedy?
Old 10-30-2008, 08:15 PM   #22
the remedy is to stop driving.
I'm looking into some aluminum radiators for our cars, I know mine will benefit from running a little cooler under boost.
Old 10-30-2008, 08:41 PM   #23
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
One item that will be on my car (an Echo, not a Yaris) before it starts competing will be a shift light, but not used as a shift light. It will be hooked up to the oil pressure sensor. By the time an oil pressure gauge drops, and by the time you actually notice it has dropped, it can be and usually is too late. A big ass bright light in your face on the other hand at least gives you a chance of saving your motor.
And for any forced induction car, a knock sensor and gauge.
rob323 is offline   Reply With Quote
Old 10-30-2008, 08:42 PM   #24
nemesisz
559 Before the Hack
nemesisz's Avatar
Drives: 07 Yaris LB
Originally Posted by whooppee777 View Post
who makes a good wideband AFR gauge
PLX Devices
They make a lot of different products. They are popular in the 300ZX and 350Z arenas. If I were to get a wideband Id get on of theirs, AEM or Innovative.
nemesisz is offline   Reply With Quote
Old 10-30-2008, 11:09 PM   #25
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I'd say 1500 F is time to start to be concerned. This is probably a bit conservative for the Yaris, and it varies depending on the car, piston type etc.
My WRX could hit 1600 no problem, and my Cobra rarely breaks 1400.
Turbo cars can get you into trouble because you can hit full boost at less than full throttle. An example would be going up a hill. If you go part throttle up a hill in a turbo car the boost will rise and you will see EGTs climb. This is where you can cause engine damage. This is precisely why EGT and boost gauges are needed on a turbo car.
The solution for this is to let off the gas and not make any boost, or floor it to get the car to the open loop fueling map and bring down the EGTs with extra fuel.
Supercharged cars do not have this problem because boost is limited by engine speed.
Old 10-30-2008, 11:13 PM   #26
largeorangefont
Break'em off some.
Your coolant temps are hot under boost? or EGT?
Old 10-31-2008, 05:37 PM   #27
LtNoogie
LtNoogie's Avatar
Ok, I need a little bit more clarification.
A wideband A/F will read exhaust O2 levels and calculate whether I'm running lean or rich.
An EGT will measure my exhaust gas temperature.
I already have an O2 sensor in my header. Do I need to have a muffler shop poke two more holes in my exhaust system to put in the A/F and EGT sensors? I am assuming I should put this after the header and before the cat, right?
Old 10-31-2008, 05:55 PM   #28
You actually have a 0-5v A/F sensor in your header, just to be clear.
Yes, you will need another bung for the other sensors you add in that path. I don't think EGT is a critical one, but that's just my opinion.
If you're adding a bung for an A/F sensor, it should be as soon after the existing one as possible.
Old 10-31-2008, 05:59 PM   #29
LtNoogie
LtNoogie's Avatar
That's what I thought but I figured that the signal only went to the ECU. Can I splice into that set of wires to feed the A/F also?
Old 10-31-2008, 06:13 PM   #30
largeorangefont
Break'em off some.
No, the stock sensor is a narrowband sensor. The wideband will come with the wideband 02 sensor you need to use.
Old 10-31-2008, 06:19 PM   #31
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
isnt there two sensors the first one closet to the header was a wideband and the second one after the cat a narrowband
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-31-2008, 06:40 PM   #32
no. the first one is an A/F, the second (between the cats) an O2.
the wideband will come with the wideband 02 sensor you need to use.
Old 10-31-2008, 07:06 PM   #33
battleversiontc
but as 0-5v sensor is a wideband and 0-1v is a narrowband
there's narrow band and wide band o2 sensors, they are both a/f sensors
narrow band, like nearly all cars have are normally referred as just "o2's"
and they either read rich or lean, hence the term narrow band
a wide band o2 sensor is comonnly called a "wideband" or "air/fuel sensor" it reads more in depth and allows for more precise tuning of the air fuel ratio.
Old 10-31-2008, 07:24 PM   #34
battleversiontc
http://www.aa1car.com/library/o2sensor.htm
http://www.aa1car.com/library/wraf.htm
Old 11-22-2008, 02:38 AM   #35
LtNoogie
LtNoogie's Avatar
Can I get a single combo Boost/Vacuum gauge or does it have to be boost only?
Does this mean that the intake manifold pressure will show max vacuum at idle and then swing to low vacuum at WOT (S/C not engaged) to boosted psi if the S/C is spinning?
It's been a while since I thought about how an engine functions.
Old 11-22-2008, 08:06 AM   #36
I've seen those around, sounds like a good combo!
NST (NonStopTuning) Pulleys. Info, Specs, User Data... NonStopTuning Performance Modifications 636 12-13-2013 09:47 PM
Gauges! Gauges! Gauges! at Blow Out Price. MC-BPT Sponsors Classifieds Area 5 06-07-2007 09:55 PM
