Old 11-02-2008, 11:27 PM   #19
jronald
jronald's Avatar
Drives: Black NCP91R
and I thought catch tank is for dry sump system...
lol
jronald is offline   Reply With Quote
Old 11-02-2008, 11:47 PM   #20
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
Originally Posted by cleong View Post
If you had a stock AFR chart you'll see that the car runs roughly stoichometric till about 4000+ rpms when it goes very rich.
But compared to another engine it runs pretty lean in comparison, doesn't it?
Everyone who's had it dyno'd always say that the engine runs lean. Of course the VVTI is something else and then it turns into another animal altogether.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 11-03-2008, 11:01 AM   #21
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
On the graph I saw, the AFR went to around 10. I've not seen that many AFR charts, so I don't know if you consider that as relatively lean compared to other engines.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 11-03-2008, 11:20 AM   #22
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
No, that is rich for an N/A car.
13:1 across the board is fine on a WOT pull. A good tune with timing and fueling adjustments should pick up about 10% on these cars.
Old 11-03-2008, 11:29 AM   #23
cleong
cleong's Avatar
In a previous post I said it went very rich at high rpms but mojoyaris said that it was relatively lean. Hence the question I asked.
TRD Blue brake pads
DC Sports header
Old 11-04-2008, 02:07 PM   #24
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Originally Posted by 33lam View Post
will the oil catch tank increase the car performance??
I knew I ran into this in a recent magazine. I went home and found the article. It's a section called Fact or Fiction in Import Tuner Magazine.
This is NOT my opinion, my own findings, nor my theory
As quoted from the October 2008 issue:
"Traditionally added to keep cylinder heads and intake tracts vented and clean, rather than to increase horsepower..."
They tested an oil catch can on a SR20DET-swapped 240sx. Both an oil catch can and a breather filter (from Autozone) were tested, which included some dyno pulls.
Their findings:
"Not only did the catch can make pwer; we could actually see how it worked."
They included a dyno graph. The bigger gains were between 2500 and about 3000 RPM, then again starting around 5200 RPM.
The average whp with the breather filter was 242.8, while the average whp with the catch can was 244.3.
Hope this helps.
Old 11-05-2008, 01:27 AM   #25
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
so I wonder if it's the vvti that makes it run rich at high Rpms, but lean at low to mid rpms. I'm happy with the catch tank n the engine, but wouldn't mind entertaining a piggy back system to tune it to run richer at mid range.
Toyota Rally Canada
Old 11-06-2008, 07:02 PM   #26
revoturbo
revoturbo's Avatar
Drives: yaris
oil catch tank improve engine bay cosmetic. not add performance..
multimakmurperformance.com
revoturbo is offline   Reply With Quote
Old 11-10-2008, 10:03 PM   #27
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
I don't think you've been around cars much, but people in the
Racing community would beg to differ. I've made these out of pop bottles and tubes in past cars. So it's not about cosmetics for me
Toyota Rally Canada
Old 11-10-2008, 11:11 PM   #28
largeorangefont
Break'em off some.
Since it is not a racing engine, it is not that big of a deal. Race engines do not need a PCV system for emissions compliance, they run breathers and catchcans. If you change your PCV valve occasionally you dont need a catch can on a 1.5L low output NA economy engine.
Look into one if you run a forced induction setup.
Old 11-10-2008, 11:13 PM   #29
largeorangefont
Break'em off some.
No, it is the engine mapping that dictates the fueling. VVTi has nothing to do with it.
Old 11-11-2008, 01:08 PM   #30
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
Oil Catch Cans are just eye candy in the yaris.
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
$30 Oil Catch Can, DIY Ogredude DIY / Maintenance / Service 79 05-13-2011 11:05 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
