Old 11-03-2008, 06:07 PM   #1
YAR1S
YAR1S's Avatar
Hm.
will you be getting the LB or sedan?
Old 11-03-2008, 09:45 PM   #2
AVALover5498
AVALover5498's Avatar
Drives: Piece of junk for now....
Hm.
A LB, Maybe the four door. I'm not sure yet.
-Chris-
AVALover5498 is offline   Reply With Quote
Old 11-03-2008, 09:39 PM   #3
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
yah man! closest thing to blink 182!
Old 11-03-2008, 09:47 PM   #4
AVALover5498
-Chris-
Old 11-06-2008, 08:46 AM   #5
detroiter
detroiter's Avatar
Yeah I know exactly where the Fillmore is. It used to be called the State Theatre for ages (and I still refer to it as the State Theatre and always will). It's located downtown on Woodward Ave, right across the street from Comerica Park (Detroit Tigers stadium).
Old 11-06-2008, 11:43 AM   #6
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
I wouldn't write off the sedan; that extra foot and a half of length allows for LOTS of stuff, and the lower roof line seems to give slightly better FE...
Old 11-06-2008, 04:39 PM   #7
AVALover5498
I've driven both of them, and I just prefer the LB. I was going to go with the two door but now that I look at the four door it isn't that bad looking. I'm still not sure which I will go with but it will probably be the four door. There are just too many perks about both of them. Ugh.
-Chris-
Old 11-06-2008, 12:14 PM   #8
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
You should be OK so long as you don't keep it pegged to highway speeds for the entire day. I put on that kind of distance in 3-4 months of my usual commute, and the Yaris is holding up fine. Make sure to do both your oil changes during that trip with the best filter you can find at the time, and you might consider putting a K&N air filter before you leave and keep the factory one for spare.
Lastly, check and fill your tires before the trip starts. I found mine to be a few psi under-inflated from the dealer delivery.
SpaceShot is offline   Reply With Quote
Old 11-06-2008, 04:43 PM   #9
AVALover5498
Sweet, thanks alot for the info!
-Chris-
Old 11-07-2008, 08:16 PM   #10
justjesus
justjesus's Avatar
Drives: 2008 Liftback
yup yup. keep that speed constantly changing for the first 1000k. I've pretty much read the stupid owner's manual cover to cover, since it was my first new car.
I put 1k on mine in one week, but was cautious to keep varying my speed. OH, and no hard accel and no hard braking either. After that, do as you will :)
Old 11-09-2008, 02:51 PM   #11
AVALover5498
Ok, so that main things are:
Vary the speed as much as possible.
Keep the tires filled.
Be sure to change the oil.
That sounds easy enough guys. I just wasn't sure if the car would blow up or something because it's so new.
Thanx everyone!:)
-Chris-
Old 11-09-2008, 04:46 PM   #12
Kal-El
Kal-El's Avatar
I would personally buy it early enough to put the first 2-3K on it with regular day to day break-in driving and then go on the roadtrip and not have to worry to much about driving style.
And why do people worry about mileage? The Yaris is good for 300,000 miles easy.
Old 11-10-2008, 10:19 PM   #13
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
Change the oil & filter before you leave, avoid freeways for the first 500 miles, and be sure to follow the recommended maintenance intervals when the times come. Above all, have fun!
Reddog99 is offline   Reply With Quote
Old 11-11-2008, 02:05 AM   #14
Jack Reacher
Jack Reacher's Avatar
Drives: 08 Yaris sdn
Just drive the damn thing. Get the oil changed on the road when it's needed and you'll be fine. Have fun.
Jack Reacher is offline   Reply With Quote
Old 11-11-2008, 01:33 PM   #15
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Agreed. I don't know why people baby cars so much. You want your heads, pistons, etc. to seat properly. Vary engine speeds, and follow maintenance schedule. You're good to go! BTW that band AVA sounds no different than B182. Not very original IMO. But have fun on your ROAD TRIP!!!
anonymous user is offline   Reply With Quote
Old 11-11-2008, 02:23 PM   #16
AVALover5498
AvA sounds completely different than Blink. I have no idea as to what you have been listening too. But anyway, this isn't about music. It's about the car. And I value your input on that aspect. So thank you.
-Chris-
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
