Old 11-07-2008, 11:02 AM   #19
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Originally Posted by Split View Post
how can you guys get above 160km/h? as soon the automatic shifts to 4th at 160km/h the car can't gain anymore speed..
should be more than that then again it might be different with manual...
Old 11-07-2008, 11:22 AM   #20
Split
Drives: 2008 Yaris Sedan
i guess with a manual you can pull to the end of 4th gear instead of 3rd gear. what does 4th gear top out at on the manual?
Split is offline   Reply With Quote
Old 11-07-2008, 04:54 PM   #21
Jerkratt
Jerkratt's Avatar
ive gotten 118mph numerous times in my 08 yaris hb coming home from NC i hit the goven a few times all its does is cut ur fuel for a few seconds so u slow down... if u stay at redline long enough it does it then to... ive personally done both.... as soon as i get my 15" back on ill use my gps again... see with 17" my speedo said 118.. my gps said 109... so when i get the konigs that i want ill try again
just for the record... i hit 118 in 4th gear...
"It hurts more when its wet"
Old 11-07-2008, 05:04 PM   #22
Jerkratt
Jerkratt's Avatar
Originally Posted by kou View Post
i have heard if you pull the e brake up one click so the light comes on but is not realy doing anything to the brakes,this turns the governor off.
does not work... i tried that on the way home... lol
Old 11-07-2008, 07:45 PM   #23
justjesus
justjesus's Avatar
Drives: 2008 Liftback
I just hit about 117-118 mph (about 187km/h). Completely stock 2dr LB. Rolling on stock 15" steelies.
I didn't let off the gas, but at the limit, it felt like the gas pedal let off by itself, or something. I don't have a tach, so I'm not sure if it was fuel cut off, RPM limit, or speed governer???
Old 11-07-2008, 08:13 PM   #24
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
i did 206Km/h, and it was still going.
harveyjai is offline   Reply With Quote
Old 11-08-2008, 08:34 AM   #25
1nz
Drives: Vios
i was still using stock 15" but with 195/55/15 tyres when i ran the car to its limit so i dont think theres a speed governor on my car hehe thailand vios dun hve speed limiter?
1nz is offline   Reply With Quote
Old 11-08-2008, 10:56 AM   #26
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
if there was a limiter, then my Apexi RSM must have overided it..
Old 11-08-2008, 01:38 PM   #27
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
i did 120mph uphill
Red Horse is offline   Reply With Quote
Old 11-08-2008, 08:59 PM   #28
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
my car is manual transmision and i felt that too, i think i was cuz i was on 1st gear and i pass 7000 rpm
t0m4s is offline   Reply With Quote
Old 11-08-2008, 09:35 PM   #29
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
This car's got a relatively "soft" rev limiter such that it doesn't bounce off the redline like most other cars do when you over-rev it.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 11-08-2008, 10:39 PM   #30
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
Governor on us models clicks in at 118 the gearing on the car suggests 148 mph without it but that is not taking into account the drag on the car pushing 130 would be hard in this car.
ztrack157 is offline   Reply With Quote
Old 11-09-2008, 03:07 AM   #31
andries
aka Jack Wolfskin
Send a message via MSN to andries
129 mp/h on GPS
andries is offline   Reply With Quote
Old 11-17-2008, 09:58 PM   #32
Greytimberwolf68
Greytimberwolf68's Avatar
Drives: 07 abosolute red Yaris
i can only go 88 mph before the flux capacitor kicks in.
Greytimberwolf68 is offline   Reply With Quote
Old 11-17-2008, 11:36 PM   #33
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
then go to the future, get some new yaris parts, get ur ass back here and let the modding begin.
Its a Chao!!!
Old 11-18-2008, 09:45 AM   #34
puetato89
Just call me Ray, better?
puetato89's Avatar
Drives: 08 Yaris
word...
Old 11-18-2008, 09:46 AM   #35
custom Lftback
custom Lftback's Avatar
haha that was good
Old 11-19-2008, 03:48 PM   #36
Split
Exclamation
with my new intake filter and mid-pipe i'm going to try this again. maybe i should wait until i have my lightweight summer wheels on though because right now i'm using winter tires... although, the cold air probably makes more power...
Max Speed in Each Gear for 5 speed man. Yaris with no tach?? 09TRD General Yaris / Vitz Discussion 53 09-24-2010 04:18 AM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
Finding a 5 speed LB to test drive grampi General Yaris / Vitz Discussion 16 05-10-2007 07:58 AM
