Old 11-30-2008, 11:18 PM   #19
mmxcix
Drives: 2008 Yaris
Originally Posted by k r a y z e e . j o j o View Post
Why not just install one yourself?
That does not really fix the issue of the odor. A wet cabin filter cannot be the culprit when there isn't one installed. I already removed the glove compartment and removed the carpet on the passenger side just to see if there is any leak from the drain or any hoses and I can not find any. I already sprayed lysol (as suggested) on the vents but the odor is still there.
Plus it defeats the purpose of installing a cabin filter if I drive with the windows open just so I don't have to use the AC and increase fuel economy back when gasoline was $4+/gallon.
In any case, any other suggestions where the smell can be coming from. I sure hate to bring the car to the dealership as I know they would just tell me "we're not smelling anything". Any help would be much appreciated.
mmxcix is offline   Reply With Quote
Old 12-01-2008, 03:36 PM   #20
Did you actually clear the condensate drain tube?
Old 12-05-2008, 09:57 AM   #21
mmxcix
Drives: 2008 Yaris
Yes I did that yesterday, I used a long thick plastic cable tie and inserted it in the drain tube and the drain seemed clean and clear. Just for good measure, I tested the cable tie I used for similar odor and there was non't any odor. Morever, it was also dry (that's because I have not used the AC that day because of the cooler weather) which meant that there isn't a stagnant water condensate in the tube. Oh yeah, I installed a cabin filter while I was at it ('should have gone back to the dealership and told them they sold me the car without the cabin filter installed).
This is really bugging me. I googled the issue and to my surprise it is not an uncommon problems with cars of any type. I may have to go to the dealership and deal with the inconvenience. *sigh. Why are dealership customer service only good when you're buying the car but it's the exact opposite when you're having your car fixed under warranty (at least from my experience)?
Old 12-05-2008, 10:09 AM   #22
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I was experiencing this before when I ran the AC and then let it sit. The moisture builds up in there and becomes stale. I used the recycle air when running the heater and noticed a funky smell also. Try running the heater and AC using the fresh air option instead of the recycle.
Old 12-05-2008, 02:02 PM   #23
pz's yaris
Drives: 2008 Black Sand Pearl HB
I have the same problem and have asked my service guy at Toyota about it. It's a common problem they have seen...there's a tray under the dash where condensation collects when the A/C is run a lot and it can get that musty, gross smell. The only thing they do is spray Ozium into the vents (Lysol is the same thing...air neutralizer/germ killer) and say to keep the vents on the fresh air when the car is parked or a/c isn't used. Not much else they can do about it...you can pay to have the a/c service done, but, I have been making sure my vents are open now and I have noticed over time the smell has gone away. It's just going to take time...a lot of time! That is coming straight from my Toyota Service Department...hope it helps! :)
pz's yaris is offline   Reply With Quote
Old 12-07-2008, 02:30 AM   #24
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
You know what, the smell has been starting to fade away very slowly on its own since I cut down on my A/C use. Guess these colder Winter months are helping. I'll try these tips anyway when the weather starts warming up again to gauge how well they work. Thanks for the advice, guys
Old 02-03-2009, 10:44 AM   #25
mmxcix
Drives: 2008 Yaris
...It's a common problem they have seen...there's a tray under the dash where condensation collects when the A/C is run a lot and it can get that musty, gross smell...
That sucks... where exactly is the tray... anyway, i still smell it from time to time... it's not bad this time of year since I have not been using the AC due to a cooler weather... i have tried using the ozium, but that thing smells like bathroom deodorant...
Old 02-03-2009, 11:07 AM   #26
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
its also due to your cabin air filter, get it changed and the smell will go away.
My car didn't come with a cabin filter from factory. and I use to get the smell even before I installed a cabin filter. and even after I installed a new Toyota OEM filter I still get the smell for a lil bit and then it goes away. I was thinking that the R134 gas is leaking into vent every so often.
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 100 06-20-2019 12:59 PM
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 01:22 PM
$7 Ram air intake pictorial turbodiesel Performance Modifications 19 10-27-2008 05:46 PM
air filter multipart btc50 DIY / Maintenance / Service 1 08-31-2007 06:37 PM
