#19 |
![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
I know my '08 turns something on when I set it to defrost, I can hear something kick on. Anyways, what SD said, turn off recirculate, you need fresh air. I get heavy frost in mornings here, and while I haven't had winter conditions yet, I sure haven't had any problems defogging the frost.
#20 |
![]() ![]() Drives: '08 Hatch Join Date: Oct 2008
+1 on opening the vents. You are putting a LOT of water into the air just by being in the car while you perspire and breath. Human beings have one of the best natural temperature regulation systems on earth, but it burns through a LOT of water. If you have water in the air on the inside, raising the relative humidity, and the temp of the outside glass is below the dew point of the air inside, bingo, you get "fog." Simply, you are putting more water into the air than the cold air next to the windows can handle, so it condenses into liquid water on your glass. Bringing in air from outside equalizes the relative humidity with the great outdoors.
#21 |
![]() ![]() Drives: '07 Yaris 3D HB Auto Join Date: Jul 2007
i know my A/C turns on in the defogger mode. i started a thread on trying to unlink the A/C from the defroster in the DIY forum, in case you're interested.
#22 |
![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
What's that white stuff all over the car in that photo?
#23 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
We had some snow flurries and icy roads in Wisconsin this evening. There was
something like 27 accidents in an hour during rush hour. I guess winter is here....
#24 |
73 Centurion droptop 455
Drives: 2009 S Sedan Join Date: Oct 2008
you need to use fresh air mode when defrosting the windows,not recirculate.
#25 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
#26 |
Bacon!
Drives: 2008 Red Yaris LB Join Date: Oct 2008
#27 |
![]() ![]() Drives: 07 Yaris Sedan Join Date: Apr 2007
Well, I tried the 'fresh' air as opposed to recirculate and guess what...NO FOG!
My thanks to all that helped. Ice is bad enough, but icey roads and foggy windows makes for a really nerve wracking ride. |
#28 |
![]() ![]() Drives: 2008 blazing blue yaris LB Join Date: Oct 2008
i agree with this i have never had this much problem with fogging till this car.
http://cardomain.com/ride/3151056 ![]() ![]() mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch coming soon: window tint, custom sub grills, tach and........ |
#29 |
Agree with what? He solved his problem. What's yours? :P
#30 | |
![]() ![]() Drives: 09 Yaris hatch, 09 Z51 'Vette Join Date: Oct 2008
The little diagrams on the car's ventilation switch make that perfectly clear, as does the owner's manual and good sense. The defogger in my '09 Yaris works at least as well as any of the other 15 or so cars that I've owned. |
#31 |
Hey guys.. know this is an old thread but bringin it back to life. The inside of my windows have been fogging up bad as of the past few weeks on my daily commute to work. I have it set to 'fresh air', not 'recirculate'. Temp is on the warmest setting, vents are all open and directed to the side windows, and fan is on high. Even after driving for almost 30 minutes, its my rear side windows that are fogging up terribly. To the point where I can't see out of them whatsoever. Not sure what the problem is here but maybe I need to to try this turning of the AC on manually as this is the one thing I just read here I have not tried.
#32 |
The past couple weeks every day driving the vehicle, the rear side windows have been fogged up beyond belief. To the point where I have to put the windows down to reverse into a parking spot.
Have tried everything from ensuring the switch is set to fresh air, direct the air vents towards the side windows, push the AC button on, and even crack all the windows slightly. Long story short I may have found the problem today. Emptied out he entire hatch including the spare tire, to find a huge puddle of water frozen in the centre lowest section of the hatch (under the spare tire). There was also some water on the floor surface area by the drivers side tail lamp. Dried everything up and ensured the black rubber grommet was in place on the hatch floor. Not sure at this point how all the water is getting into the hatch but I do believe this explains the window fogging. Will keep posted. |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
| rear corner windows fogging | wushumasterku | General Yaris / Vitz Discussion | 14 | 01-23-2006 03:09 PM |
