#19 |
btw i'll be doing paddle shifts on the steering wheel as well.. i want to put some serious thought into the design (thinking something like the IS-F) and this stock shifter will get me going in the right direction
#20 |
SIPNDEW
ah so were going sequential shifter style first. haha sweet
#21 |
#22 |
§†ęĄ¶‡Ћ-NCP96
woot, good progress so far, keep it up
#23 |
I used to have 1700 posts
this is so awesome and confusing all at once. I LOVE IT!
#24 |
#25 |
here's the shifter with the limit switches installed.. due to UPS taking their sweet ass time this project will not be done till after thanksgiving :(
#26 |
very impresive,keep up the good work.
#27 |
![]() ![]() Drives: 2007 5 Door Hatch Join Date: Jun 2007
If you can master this setup than work on an auto setup, i'd be down with that. Paddle shifting like the Fit Sport on the Yaris would be cool and the RS Yaris should have had it. I am patiently waiting for this
#28 |
#29 |
§†ęĄ¶‡Ћ-NCP96
nice work so far man. Coming along good.
#30 |
★weeaboo★
Subscribed! This looks amazing! Are you going to add in some sort of gear display that shows what your current gear is?
#31 |
i will have to get a bigger (more outputs) PLC to do that unfortunately.. that or a ton of relays.. i'm definitely trying to figure out how to do it inexpensively :D
#32 | |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
Their Street Manual All Products page shows good images of the actual modules that bolt in place of the stock shifter assembly to control the existing cable-drive stuff. *ALL* their systems are designed to work with cable-driven transmissions actually.
#33 | ||
either way, the intent of my setup is to do away with cables ;) |
#34 |
picked up my enclosure from the wonderful folks at City Electric today..
here's the basic layout of the parts. i gotta pick up a piece of DIN rail, hope i can find a manifold for the valves, and will most likely mount the power supply (lower left, converts 12V into 24V) on a 90degree angle.. contemplating a cooling fan but not sure if i'll be generating that much heat
#35 | |
The MasterShift kit comes with a programming cable and software CD for a reason: It's for setting the distances the box actually has to shift the cable-linkages for the gate-selector and syncro-selector inputs, and specifying paths and routes for the shifting to follow. And any cable linkage can be replaced with a hydraulic linkage, witness modern brakes versus the old cable-powered brakes used as recently at the 80's. Hell, many vehicles with in-board brakes (brakes mounted beside the differential, bolted to the chassis instead of part of the wheel assembly, Jaguar's and Hummer-1's mostly) can have hard brake line going all the way to the brake calipers. They'd use hydraulics more places, but it's a lot more expensive to design and prone to maintenance headaches than a length of steel rope inside a plastic sheath, which is almost all a transmission-cable is since it doesn't have to deal with large forces like brakes do/did. Didn't mean to come off as knockin' on the work you're doing, it's looking awesome so far. :-)
#36 | |
i'm jealous of their paddle controls :( |
| Didn't buy; awkward shifting? | drmitch | New YARIS Purchase Forum | 89 | 03-03-2009 09:44 AM |
| Yaris Auto Transmission shifting | g man | Canada | 9 | 08-23-2007 12:16 PM |
| Shifting (A/T) | daq421 | General Yaris / Vitz Discussion | 54 | 04-03-2007 12:30 PM |
| Paddle Shifter? | spkrman | Performance Modifications | 10 | 03-09-2007 05:17 PM |
| Sticky When Shifting and Sticky When Reving? | jouslee | DIY / Maintenance / Service | 22 | 01-23-2007 11:07 PM |
