Old 11-18-2008, 12:43 PM   #19
richardholdener
Drives: 2008 Yaris hatch
Sure, we could hook it to a remte or better yet have it comtrolled by the ECU-now we are talking about big bucks. No battery relocation is necessary for either design and the gains offered for the daily driver is that you get to have an intake design that gains significant power in the lower rev ranges and then change it for high rpm power. The real benefit is having the choice.
crazy idea... how is the adjustment done? could it in some way be linked to a servo, for in-car adjustment?
richardholdener is offline   Reply With Quote
Old 11-18-2008, 12:45 PM   #20
richardholdener
What we are wrestling with is positioning the throttle body in the stock location which will meaning anything that currently hooks to this location will work (yours will work). Having the throttle body in the stock location will meaning it can't be made to be adjustable.
i'm on the list AND i am getting this. I want the high end version. too much work for the dual version.
You said with the high end the throttle body will hook up to almost all CAIs, but what about short ram intakes? Same deal? I got the AFE short ram in take. They called it the AFE Cold Air Intake 2, but i think they sent me the short ram. Unless they call it the CAI because it comes with the "heat shield."
Old 11-18-2008, 12:47 PM   #21
richardholdener
Actually your air intake would work with either design since we could rotate the inlet tube.
Old 11-18-2008, 01:40 PM   #22
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
it looks like an easy install as well...hmmmm..
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
Thinking about making a full Intake Manifold Replacement YogiYaris Performance Modifications 26 06-07-2007 10:26 PM
