Old 08-02-2006, 07:54 PM   #19
TrancosRt
TrancosRt's Avatar
Drives: 07 Silver HB Yaris
Am I crazy for washing my Yaris in less than a week of owning it? :P
In my defence, in the first night I had it, 2 pouring storms fell on it, so the all the glasses were quite dirty. Being so small, it is a brease to wash!!! The only problem I foresee will be leaving the huge windshield spotless (well, streaks-less).
TrancosRt is offline   Reply With Quote
Old 08-03-2006, 09:33 AM   #20
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
You are not crazy at all... the first thing new owners should be doing ASAP after getting their cars, is getting a coat of wax on it!
Yes it may look showroom PERFECT, but there is NOTHING protecting the paint at that point! Even if you go buy the super easy to apply, super easy to remove Turtle Wax ICE wax thats out right now (works awesome BTW!), get something on the paint, and protect it early.
Old 08-05-2006, 12:07 AM   #21
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
yeah, I wondered if they actually waxed our Yarii from the factory or dealership...but I'm guessing not. My black paint is starting to get tougher and tougher to wash. I've only washed it three times, becauase i'm afraid that everytime I wash it (without wax) i'm basically scratching the clearcoat more
THE MOST INFORMATIVE WEBSITE FOR AUTO DETAILING / WAXING!!!!!!
AUTOPIA.COM
MY WASH TIPS:
ALWAYS HAVE 2 WASH BUCKETS. 1 for soap, 1 to rinse off your sponge/washmitt TO KEEP your SOAP BUCKET from getting contaminated with dirt..
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 08-09-2006, 09:17 PM   #22
TrancosRt
TrancosRt's Avatar
Don't get me wrong, I've been using the wax as you dry stuff for a long time in all my cars. In my next wash I might go all the way for a full wax, but I'll have to buy a good wax mit and polisher.
Old 08-09-2006, 09:34 PM   #23
sroberts
sroberts's Avatar
Drives: 2007 Yaris Sedan
Originally Posted by Buckethead
Someone mentioned that when you get your car washed that you should go to the dealer to maintain warranty.
the guy who told you that must do this a lot.....
I am not allowed to put anything here because I do not have any ricey mods on my Yaris....
sroberts is offline   Reply With Quote
Old 08-11-2006, 12:55 PM   #24
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Alright I am now going to pull back on my previous post for using a touch free car wash. I just got back from the one that I have used for years and when i pulled out I went to pick up food....I came out and saw something flicker wrong on my front body lip. After closer observation I have found that a 4x6 inch section of paint has peeled off! I immediately called the dealer closest to me (60 miles away) and they told me to bring it in to repair it under the paint warranty. On the way back to work I dropped in to a buddy of mine that has an auto body shop and he told me that they didn't clear coat the body kit, the front, bumper assembly, nor the rear! WTF? I can't imagine why that is so...I asked him if that was right and he said that he didn't believe that the car should be sold that way? Anyone have any ideas?
Old 08-11-2006, 03:46 PM   #25
Buckethead
Awe, man, that shit breaks my heart!
Gotta call Toyota, and ask them if it was clear coated or not. I wonder if it's an isolated incident or if they all came off the truck that way.
Buckethead is offline   Reply With Quote
Old 08-12-2006, 07:38 AM   #26
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Toyota dropped the ball. good luck getting it fixed, since REPAINTS WILL NEVER BE EVEN HALF as good as OEM paint that is applied/cured under STRICT ENVIRONMENTAL CONDITIONS (temp, humidity, air pressure,etc.)
Old 08-13-2006, 06:21 PM   #27
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
Cool
Originally Posted by casterqc
Basic car washing: How to:
items needed:
- any liquid or gel car wash...I prefer gel
- a clean wash mitt
- a clean Chamois
Rules:
- Use a water hose to get rid of surface dirt all around your car
- Clean wash mitt and chamois with water and soap
- Use wash mitt with gel car wash to wash your car...don't ever use Dishwashing Liquid...unless you do it in the purpose of waxing your car in the minute after.
- Always wash the car from the top to the bottom...once you have done the bottom you can't go back on the top. The reason is simple...the dirt on the bottom of the car (bottom sides, bumper) is the kind of dirt that can damage your paint the most. On the road, you're car will catch bugs, grease, rubber (that they use to fill holes on the road)...the sand and little rocks stick to those...you don't want to put these all around your car while washing it.
- DO NOT drop you wash mitt on the ground...do I have to explain why?
- Wash the wheels at the end.
- Don't try to wash your tires with your wash mitt!
- Use hose frequently to get rid of the remaining soap on the car...you don't want it to dry...it leaves ugly spots.
- Use wet chamois to avoid water spots on the paint
- Use chamois from top to bottom...same rule
When everything is done, take the time to clean the mitt and the chamois with water and soap so it will be clean next time you use it.
Your done.
I do not recommend any car wash. The reason is that it keeps dirt from other vehicules on the brushes. I also not recommend the touchless car wash because pressure hose on paint can be damageable with time.
have fun!
Thank you. Great tips and procedures. This will be very helpful for me! ^5
Jem
Jem_hadar is offline   Reply With Quote
Old 08-15-2006, 07:53 PM   #28
Buckethead
ain't that the truth! I would also advise then next time you see them to cut them off from the or else you could just tell them they are full of and then after you
P.S. if you do the above mentioned make sure you get good pics!
Ok....I am done being an ass for the day.
Were you able to paint the ride?
Old 08-15-2006, 08:24 PM   #29
fnkngrv
fnkngrv's Avatar
I am working with the dealer on it...they are having issues finding my VIN in the Toyota System. I am going to demand a new front lip....since they would just repaint the lip itself I may just pay the difference with them to get the new lip...that way I have OEM paint.
Old 08-16-2006, 01:18 AM   #30
Buckethead
Excellent.
Old 08-16-2006, 10:52 PM   #31
swng
swng's Avatar
Drives: 06 3-dr auto RS
Wish you success in your negotiation.
Your fall back position, which is if Toyota insists to repaint the lip only, you can say you wish to pay the difference between the paint job's cost and a new lip's price in order to get a new lip, is smart. Intuitively, I do not think the difference is big. You can even claim back the damaged lip from them afterwards and sell it.
Hope you don't have to offer this to Toyota anyway.
swng is offline   Reply With Quote
Old 08-17-2006, 10:45 AM   #32
ChinoCharles
Drives: LB
On the topic of the original topic, I bought that Turtle Wax ICE detailing spray and some microfiber products and used them yesterday, and I was astonished. It literally looked cleaner than it was coming from the dealership. ICE = Great product.
Old 08-17-2006, 10:59 AM   #33
Chris07LB
Chris07LB's Avatar
Try using the TW ICE, then go over the whole car again with the TW ICE Detailer Spray with a damp microfiber towel... then take a clean dry microfiber towel next, and just go over the whole car. Dead sexy!
Old 08-17-2006, 11:29 AM   #34
Buckethead
Wow, that's cool!
It's coming up for a car wash, and I will buy the Ice detailer, and do it all over again.
The ICE stuff works wondersQQ
ICE wax/ICE detailer=
Old 08-17-2006, 12:59 PM   #35
fnkngrv
fnkngrv's Avatar
Well I decided to give Meguiar’s NXT Generation along with Black Magic Titanium for the tires and they both work excellent. I used Meguiars NXT Generation Car Wash for washing itself. I can't get over how clean it looks...even better than when i pulled it off the lot....I would recommend to anyone.
Old 08-17-2006, 01:17 PM   #36
TrancosRt
TrancosRt's Avatar
TW Ice Wax= sexy Yaris.
I was expecting a little more of a "color depth" but I'm quite satisfied with the end result. Probably is the color though since I've heard that Silver is a tough color for waxes.
