Old 10-05-2006, 10:38 PM   #1
Kitt
Kitt's Avatar
Guys i think the miles runned move with the cluster... http://www.yarisworld.com/forums/sho...highlight=tach
Old 10-05-2006, 11:24 PM   #2
paultyler_82
They do, but as tiksman proved (as noted in that thread) that can be easily remedied by swapping out the EEPROM that stores the milage info.
Old 10-06-2006, 10:48 PM   #3
Kitt
Kitt's Avatar
oops, sorry didn't read enough lol
Old 10-19-2006, 03:20 PM   #4
tonywenzel
Drives: Z33, NCP91
Can anyone confirm if the sedan cluster works in the LB?
tonywenzel is offline   Reply With Quote
Old 10-19-2006, 10:16 PM   #5
paultyler_82
I don't beleive it will, the mounting tabs are in different positions, and the connector is different.
Old 10-23-2006, 03:39 PM   #6
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
I would have expected there to be a different connector there or maybe a seperate one for the tach. There must be a way to swap clusters or add a tach to the USDM Liftback without going to some obnoxious monster tach.
Ran Kizama is offline   Reply With Quote
Old 10-24-2006, 05:02 AM   #7
paultyler_82
There may be, if all the technical details of swapping the Canadian Cluster in can be overcome. It fits, plugs up, and functions properly... it's just that You'll of course see Km/H and the Odometer will show Kilometers, not miles.
Old 10-24-2006, 07:44 AM   #8
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
That's fine for me. If you look on the Canadian speedo, it also reads in MPH under the Km/H.
Old 10-24-2006, 12:32 PM   #9
funkstrong
Has anybody tried to make their own cluster using other guages? It would look cool if you set them in a piece of carbon fiber and mounted it in the stock location. I was thinking about it but cost and my lack of knowledge on how exactly they work is stopping me.
funkstrong is offline   Reply With Quote
Old 01-24-2007, 03:57 PM   #10
Treyz
~ ambient one ~
Treyz's Avatar
Its all good, I'm used to it as well. Have a JDM cluster in the S13.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 11-03-2006, 07:07 AM   #11
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Actually I just learned that that's a photo of the old model Yaris. The new one is similar - I'm trying to get someone there to snap a photo for us.
Old 11-03-2006, 11:13 AM   #12
grimez
grimez's Avatar
Drives: 2007 Yaris
God i hope its just a direct swap, that would make life so much easier.
grimez is offline   Reply With Quote
Old 11-03-2006, 12:32 PM   #13
Violin
Violin's Avatar
This is a photo snagged off the Toyota UK site:
Old 11-06-2006, 10:24 AM   #14
Violin
Violin's Avatar
According to the 'blokes' on that UK site, the British speedometer is meant to be viewed from the right. The left side passenger can't read it so it won't work in our cars. They suggested other European versions of the same cluster that are meant to be viewed from the left like the Netherlands.
Old 11-12-2006, 12:48 PM   #15
grimez
grimez's Avatar
Drives: 2007 Yaris
Well lets find us someone from the Netherlands to help us out.
Old 01-07-2007, 10:59 AM   #16
titan0111
Drives: Future Yaris Owner
i came across this site when searching for a Canadian Cluster
titan0111 is offline   Reply With Quote
Old 01-09-2007, 08:04 PM   #17
grimez
grimez's Avatar
Drives: 2007 Yaris
Is there any other info in this area... I'm still very interested.
Old 02-01-2007, 07:44 PM   #18
dansides
dansides's Avatar
Drives: 07 3 dr
www.autometer.com found these gauges that have peak an warn functions! was thinking about installing a 3 1\8 in tach in center of left glove box an then put 1 2 1\16 gauge on ea side maybe install into existing box door or remove door an build a unit to mount in space. any one done this may also install scan gauge in same area need input
dansides is offline   Reply With Quote
