#19 | |
#20 |
Drives: 2009 Yaris liftback Join Date: Nov 2008
Scott,
Noticed the exact same thing. The light was merely whiter....not any brighter. The whiter light "appears" brighter because the eye likes that light but it doesn't do much for the poor lighting. Looks like I'll live with it. It's possible that I'd do HID's down the road but I'd have to get a projecter style (correct) housing. |
#21 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
And I picked up an extra set of 8000K bulbs off of the forum for $20 to have as spares, just in case. |
#22 | |
#23 |
#24 |
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
If only depotautolights make the ccfl type projectors for the 09's.. =(
#25 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
You don't blind oncoming traffic?
#26 |
#27 |
![]() Drives: HONDA Join Date: Oct 2008
HID will be alot brighter then the Silverstar, the difference is night and day. I provided a link below with more information on our HID Kits
http://www.yarisworld.com/forums/showthread.php?t=9610 |
#28 | |
#29 |
CTScott go to www.powerbulbs.com and order either Osram Nightbreakers H4's or Philips X Treme H4's, and you will crap your pants compared to the stock bulbs and even the U.S. Sylvania Silverstar bulbs. The US versions use Halogen gas and tint the lens of the bulb to get the white color. The ones from Power Bulbs are filled with Xenon gas and most of the times never tint the glass. They are extremely bright and very very white compared to stock and US versions.
I am currently using the Philips X treme and love them. The Osram Nightbreakers didnt last very long for me and the Philips are as bright but are rated for a longer life. |
#30 | |
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
I purchased the Nightbreakers and noticed very little if any difference. The white is just brighter. I hope that somebody comes out with a nice projector headlight for the 09. |
#31 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
5 minutes to remove the bumper.. seriously...maybe i can now swap my horn to a boat horn...
#32 |
I love momentum.
Just to add the other side of the story here, Silverstars don't last long. For a bulb that costs that much they tend to go in less than a year (I personally know 4+ people that had to replace at least one bulb within a few months). They also don't have as bright a light output as the Osram Silverstars (available online, pricey).
Personally I would give rallylights.com a call and tell them what you're looking for. They stock an insane number of bulbs and don't charge much at all. |
#33 |
toyota
thats why u go for hids..low power consumption longer life as well plus a whole lot brighter.
#34 |
![]() ![]() Drives: 2008 Red Yaris LB 5 sp Join Date: Jan 2009
#35 |
Not even understanding this at all. I operate a lube center in Texas. We change light bulbs everyday. I bought my replacement bulbs from www.powerbulbs.com and I am very pleased with them. They are the Philips and they were recommended by the sales staff. I changed both of them and DID NOT remove the bumper. Was not a big deal at ALL. That is a lot of trouble to go to just to change a couple of bulbs. Just my .02 cents.
'07 Polar White Liftback, 15in Alloy Wheels, Exhaust Tip, Cruise Control, Tinted Windows, TRD Valve Caps, PadsPlus Pads, |
#36 |
Drives: ScionXA Join Date: Aug 2009
Thanks for the pictures, 2005 Scion Xa uses the same type of housing and lights, I am using a 4000K lights my lights where about 1 1/2 years old so I did see a good improvement as they start to be weaker as time goes on. I was able to do this in less than 10mins due to your pictures. Understanding what was under the rubber boot made it a very easy job of un hooking the clips by feel, I did notice on the driver side on the Xa its very cramped due to the fuse box I have heard allot of people say to unbolt it, I found by removing the fuse box cover my small hands where barely able to do it with out the need of unbolting anything. Thank you
On Xenon light kits, Plastic lens are going to melt pretty fast, also federal law mandates in the USA any xenon light must be in a housing intended to for it, so standard plastic lens on the Yaris and Xa are going to be illegal as 17 year old, The reason behind this is the optics of a halogen and the optics of a Xenon are different the Glare and the light will go places it shouldn’t and will blind people unless you replace the lens swell. So before you blow 80 dollars on Xenon kit I would consider is it worth the 150 dollar ticket or the 300-500 dollars more to get the correct housing for them to be street legal. |
| Sylvania SilverStar or SilverStar ULTRA | Benggolf2 | Cosmetic Modifications (Exterior/Interior) | 9 | 11-13-2008 05:33 AM |
| Changing Headlight Bulb Tutorial | RSboyz | DIY / Maintenance / Service | 29 | 03-15-2007 01:35 PM |
| How to remove headlight bulb with chubby hand? D: | jmew0ng | DIY / Maintenance / Service | 2 | 02-22-2007 11:40 AM |
| OEM Toyota HID Headlight Assembly - Where to SOURCE? | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 18 | 12-21-2006 05:01 PM |
