Old 12-02-2012, 10:11 PM   #19
Originally Posted by Golddeenoh View Post
what about the LHD hatchback with the cluster in the middle, do you have to lengthen the wires for that one or is it plug and play?
The LHD is almost plug-n-play. You have to move a couple of wires around to account for the differences in the wiring with Japanese built versus French built Yaris.
Old 12-02-2012, 10:19 PM   #20
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
wow you responded fast... are the gauge pods versus USDM and French that much different, and can it be set to display in MPH instead of KPH?
other note, doing this would make my wife a little jealous of there being a digital gauge in my car, as that is one of the things she wish she had in her Mustang.
Old 12-02-2012, 11:36 PM   #21
nookandcrannycar
Originally Posted by peckerhead View Post
I have a Canadian cluster in my '07 LB. The speedo is metric, which most people don't like, but it's got a factory tach and it works great. Bought it on ebay for $50, and it was about a 10-minute swap.
Old 12-02-2012, 11:55 PM   #22
Some are switchable, and some are not (depending on the area they were intended for). If you got one that was not, my KM to Mile conversion device would work for the digital cluster as well as the analog one.
Micro Image Short Shift Kit DIY jpmck03 DIY / Maintenance / Service 17 02-24-2014 07:57 AM
