Old 12-16-2008, 09:14 PM   #19
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by TKO View Post
This is the pocket I'm talking about...Yaris has one right?
The Yaris only has the rear bolt exposed. The one right behind the rear seat is covered up by plastic paneling, but I'm pretty sure the bolt is pretty much in the same area as yours.
I'm getting really interested in this mod all of a sudden. Is there any chance that you'd like to fab a few of these for fellow YW members?
Old 12-16-2008, 09:24 PM   #20
pinoypizzaboy
Drives: 08 toyota yaris LB
You should have spent alittle more...Here is my rear brace that I made up.
Plus, I have a matching front strut brace as well...all for $50.00
But none-the-less...Great job on Doing it yourself!!!!
thats nice
pinoypizzaboy is offline   Reply With Quote
Old 12-16-2008, 10:34 PM   #21
YarisSedan
Drives: 08 Yaris Sedan
Originally Posted by pinoypizzaboy View Post
thats nice
What the heck. how did you make those. Come make some for me =).
Old 12-16-2008, 10:51 PM   #22
TKO
Drives: 4 door hatch
I got the steel from a metal supply store. Think of it as a home depot...but all they carry is metal. And to bend them I used a harbor freight tubing bender.
I could make them...But I don't have a yaris to use to fab it up. But, most likely, I have one before summer next year.
TKO is offline   Reply With Quote
Old 12-16-2008, 11:05 PM   #23
Originally Posted by Loren View Post
Brilliant, except that you're bolting to the top of the shock, and the shock is still mounted in rubber at both ends. A "brace" with 1/4" or more of flex at it's mounting points isn't much of a brace, is it?
Originally Posted by largeorangefont View Post
/thread.
The both of you always tend to do this. I know you are not "intentionally" trying to flame but the end result is, you are. Throw a tension gauge on and I'm sure that the flex is much less with, than without.
Great job on the brace kou
Old 12-16-2008, 11:15 PM   #24
Can you make something like that for the sedan?
Old 12-17-2008, 10:22 AM   #25
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
My new bar does not seem to stiffen the car much either but it's much easier to bring home my shirts from the cleaners.
Old 12-17-2008, 11:08 AM   #26
or you could have midgets do chin-ups at the back!
seriously, back to the OP's post, great value for money
Old 12-17-2008, 01:40 PM   #27
MUSKOKA800
MUSKOKA800's Avatar
Toyota already gave us sedan owners a rear strut tower brace. It's call a rear window deck and has features like speakers holders, rear seat back latches, rear glass, etc, already integrated.
Old 12-17-2008, 04:28 PM   #28
at3GG
at3GG's Avatar
Drives: 07 metmet LB
paint it black and it will look better. Looks cool though. If you feel difference, what more could ask out of $20??
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 12-18-2008, 08:34 AM   #29
http://www.engin.brown.edu/courses/e...odyProject.htm
Old 12-18-2008, 11:08 PM   #30
03Z33
03Z33's Avatar
Drives: TCR10
I believe the C-One rear strut brace is the only brace I've seen that mounts solidly to the chassis (from the ones I've seen). You do not use the rubber shock upper mounts when installing this bar. It is designed as a solid mount with a machined cup that fits snug in the chassis hole. This design will help reduce chassis flex.
It can also be argued that this design is also flawed since it doesn't allow for side to side play or twist in the shock shaft which can lead to premature shock wear.
Notice the end cups at either end of the brace:
03Z33 is offline   Reply With Quote
Old 12-19-2008, 09:06 AM   #31
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
surprising to see no posts about how USELESS and what a waste of money this is......
Old 12-19-2008, 02:42 PM   #32
ddongbap
I'm totally down for that super crazy custom brown pipe one.
Old 12-24-2008, 11:02 PM   #33
teejay
Drives: liftback
count me in on brown pipe bar!
teejay is offline   Reply With Quote
How to remove the Nut on the top of the shock tower hystria DIY / Maintenance / Service 29 12-08-2006 09:30 PM
Rear shock absorbers problem Yaris PTY-507 Central and South America 1 10-16-2006 04:07 PM
