#19 |
#20 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Thanks for those part numbers CTScott. I wonder if install of the new light control stalk w/ fog light switch is the same as w/ the '07 / '08LBs... I'd like to install fogs on my '09 as well, but won't do it unless I can also install the stalk w/ fog switch built in. Will the light control stalk w/ fog light switch AND fog light relay that worked with the '07 / '08 LBs work with the '09 LBs?
#21 |
![]() Drives: 2007 Yaris LB Join Date: Nov 2008
If you go to toyota and ask them for the part number of the 08 and 09 foglight switch stalk, and they are the same then it will work. Because the wiring of the stalk is the same. Just look for the relay position to see if its the same as the pics in the DIY foglight and if it matches, then you should be good to install it.
#22 |
Drives: 2009 Yaris liftback Join Date: Nov 2008
#23 |
SIPNDEW
+1
#24 | |
09: 84140-52151 08: 84140-52150 |
#25 | |
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
Oh I forgot to ask, 808 ... how much did everything come out to?
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
#26 |
![]() ![]() ![]() Drives: 2007 and 2008 MM Yari LBs Join Date: Aug 2006
Shoot for that money I would have got the kaminari kit and called it a day.
Two Yari on home! ![]() |
| 2009 Front Bumper Conversion | 808yarisLB | Hawaii | 7 | 07-21-2010 10:49 AM |
| for sale - yaris hatch front bumper (slight damage) | jesse1000 | Canada | 4 | 12-06-2008 09:03 AM |
| FS: JDM Modellist II Front bumper & JDM LED tails | DKN-YARIS | Items for Sale by private party | 7 | 11-09-2008 01:10 AM |
| Thailand OEM/Aftermarket Accessories and Bodykits GB Round 2! | eTiMaGo | Items for Sale by private party | 118 | 09-10-2007 02:10 PM |
| Front Bumper Question | tca4 | Cosmetic Modifications (Exterior/Interior) | 8 | 01-30-2007 03:58 PM |
