Old 08-14-2006, 07:51 AM   #19
Carvin'07
Selling all mods
Carvin'07's Avatar
Drives: '07 Bayou Blue - totally stock
Originally Posted by Linkseal
Ok...so you are using 17x7 Offset 42 and 205/40/17...It seems it defenitely look perfect on your Yaris...But which brand and how low your springs in both front and rear are? Is there any fender rolling during your driving?
Since I am thinking also using 17x7 205/40/17 but with Offset 40, do you think this is a good set up if I plan to lower my car around 1.6"?
Konig Kolors and on TRD springs, so only about a 1.2" drop. I think you will be fine with the setup you have suggested above.
Cheers
Carvin'07 is offline   Reply With Quote
Old 08-14-2006, 01:51 PM   #20
Linkseal
Drives: DBA-NCP91
Send a message via MSN to Linkseal
Cheers
Got Ya...Thanx for ur input...any pics of urs or URL?
Linkseal is offline   Reply With Quote
Old 08-14-2006, 04:24 PM   #21
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
Keep in mind that just focusing on the tire size is missing the point. The width of the rim and the offset is just as important. Just because someone is running 205's without problems - it doesn't mean it will work for you. If someone using 205's are running a narrower rim with a greater offset, it is the complete combination that's making it work, not just the tire width.
Idjiit is offline   Reply With Quote
Old 08-14-2006, 04:43 PM   #22
Carvin'07
Selling all mods
Carvin'07's Avatar
Check out the pics in the Bayou Blue thread.
Idjit makes a very good point. Every single aspect of the spring, wheel and tire combo makes a difference.
Cheers!
Old 08-14-2006, 05:45 PM   #23
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
It is sounding like there is a general consensus that 205/40/17 with a +40mm offset is working just fine. Even people with a +42mm offset are ok.
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 09:55 AM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
