#19 |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
Interesting you mention that, but wasn't an EGR pipe mentioned in the recent recall?
#20 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
or 2 the mechanic who is working on his car is a idiot and just made up some code. Most mechanics know that when a egr code pops up you simply test the egr with a vacuum pump if egr tests good then its a solinoid if its electronic operated if not then the egr pintle is stuck or the pipe is severely crudded up restricting flow. Either way it can usually be fixed by cleaning the egr system. |
#21 |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
this could be the culprit . The defective E.G.R. unit being recalled . Do you happen to smell any exhaust fumes in the car ? If so , most likely the E.G.R. pipe has broke . Get it to dealer service soon as possible .
#22 |
Hi,
I finally got the codes. Its; p0403 p1589 p1605 Upon clearing the codes from the OBD-II scanner the 2nd and 3rd codes disappears but the first one i.e. P0403 remains uncleared. What should be done ????
Where I Stand I Stand Alone |
#23 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
P0403 - Exhaust Gas Recirculation Circuit Malfunction
http://www.obd-codes.com/p0403 I cannot find a Toyota code of P1589 P1605 Knock Control CPU
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#24 | |
Will keep you posted when I go with it.
#25 |
§†ęĄ¶‡Ћ-NCP96
"mechanic did add oil through air intake pipe. "
WTF ? He put oil in your intake pipe ??? WTF no wonder your having problems. |
#26 |
Hi to all.
I finally change my car's EGR thing. Cost me around 100$. P0403 and P1605 are gone. Error code P1589 is still active and so is the ML (CHK engine light) In the scanner the code this code is describe as; "Acceleration sensor learning value" The scanner is X431. any ideas about it. help needed again.
#27 |
Drives: Vitz 06 Join Date: Apr 2009
hi ali. im from lahore and i own an 05 vitz and am having the exact same problem as yours. how/where did u get the new egr from?
#28 | |
I got the egr thing from sher shah karachi. please further tell me that what kinda of problems are you facing with this error and i will share mine. Secondly are you car still on CNG or on Petrol.
| Test Car needed for BlueBat overlays | Turbo&Auto | General Yaris / Vitz Discussion | 12 | 07-24-2009 02:35 AM |
| Rear skirt needed | Danish Yaris | Cosmetic Modifications (Exterior/Interior) | 6 | 01-09-2009 04:54 PM |
| What is needed for coilovers | justinparadise21 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 01-03-2009 12:53 AM |
| Feedback needed on wheels | kimona | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 06-09-2007 02:22 PM |
| opinion needed | uncleyaris | Cosmetic Modifications (Exterior/Interior) | 9 | 01-12-2007 07:12 AM |
