Old 01-16-2009, 02:33 PM   #19
gid
Drives: '08 Yaris sedan , '08 Liftback
Talking and profalactics ...
Originally Posted by 1stToyota View Post
Yeah, back in the good old days when gas stations sold tires and batteries instead of bread and eggs.
gid is offline   Reply With Quote
Old 01-16-2009, 03:33 PM   #20
otterhere
Drives: 2008 Yaris 3-door Meteorite
Your gas station sells bread and eggs? Mine sells money orders and lotto tickets.
otterhere is offline   Reply With Quote
Old 01-17-2009, 07:45 PM   #21
gid
filled '08 5 spped manual Liftback with 9.41 gallons of SUNOCO 89 at 332.5 miles ( 2 bars left ) and got 35.3 miles per gallon . The average temp was 20 , many hills , all season tires , 2 people (90% of time ) , 38% City /62% Hwy.. Better than the 33.62 m.p.g. I predicted .
Old 01-17-2009, 07:53 PM   #22
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
This thing has not been as bothered by the cold temps as my Jeeps which drop 5+ mpg in the winter-must be the cold fluids in the differentials/transfer case and bigger transmissions that make the difference. I'm hanging in at 39-42 depending on if that tank was mostly freeway or city driving.
Old 01-18-2009, 02:46 AM   #23
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
25mpg.
Average temperature was -28C, and I was over at a friend's most every night, so no block heater usage. It really is a 5K screamer when it's cold!
firemachine69 is offline   Reply With Quote
Old 01-18-2009, 08:07 AM   #24
metalshark
MetalShark
Drives: 2008 Yaris LB
Originally Posted by 50MPGDream View Post
I wonder if the fuel maps in the automatics are different than the manual cars, I also have a full grill block and any time when the temp dips to below 20*F it seems to really kill my MPG. (my 20% drop in the winter as opposed to your 7%)
The water temp is still staying in the 184-188 range, but it seems at any given RPM I'm sucking more gas, the only difference I can attribute this to is the intake air temp
anyone else have any thoughts???
I'm thinking the ATF gets cooled off a lot more than the grease in a MT and has a resultant higher mean winter viscosity.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 01-18-2009, 07:25 PM   #25
Forrest
Drives: 08 LB BLACK
I remember.....they used to wash your windshield and check your oil while car was fueling. Could always get a flat tire fixed fast and local mechanic did not have all sorts of electronics to deal with.
Forrest is offline   Reply With Quote
Old 01-18-2009, 11:34 PM   #26
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Although my Yaris is new....and shiny.....I have been getting around 34 MPG in mixed driving. Here in Indianapolis, the temps have been below 30 degees with a couple of days in the singe to minus digits.
Old 01-21-2009, 09:27 AM   #27
REM
REM's Avatar
Drives: 2012 Nissan Leaf SL
Last time I filled up I got 33 mpg, and that was with a lot of idling and spinning of tires (I got stuck).
Cheers,
Ryan
REM is offline   Reply With Quote
Old 01-21-2009, 11:40 AM   #28
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i have to try covering the grill.. summer im doing 6.42 li/100km winter my average is about 7.1 li/100 km..
Old 01-21-2009, 12:22 PM   #29
otterhere
Another thing... Had two bars left when I put it to bed last night; this morning, after warming it up/thawing out the windshield for five minutes, it was FLASHING rapidly to refill (skipped the slow flash entirely). I raced over to the pump, where it took under 10 gallons, giving me the usual 32 mpg for this tank. When does yours start to flash???
Old 01-21-2009, 12:52 PM   #30
marcus
toyota
marcus's Avatar
that will happen once every now and then.. for 2 years that happen once..
the last bar should give u 6.2 liters.. i think itll flash faster once ur on the last 3 liters.
Old 01-23-2009, 04:52 AM   #31
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
I'm curious what octane you guys are using... I've been putting premium in mine, because the difference in a 10 gallon tank is only about $2-$3 extra per fill up and in our yari, that's not that often... Seems to have better pickup and mileage. What do you guys think?
Old 01-23-2009, 08:20 AM   #32
Woody_Woodchuck
Drives: 2008 Yaris LB 5M
First few months with mine so I do not have any previous winter numbers to compare to.
Warm weather I hit a few 45 mpg tanks, the average with my 6,500 miles is ~43.5 mpg. Winter mornings here we have temps in the teens, many 20’s and the overall average right now is 29. Afternoons usually into the 30’s or 40’s with many 50 degree highs. I have a full upper grille block that stays on until 55 F. I don’t really seem to be losing much mileage, maybe 1 or 2 mpg per tank. Current tank, which has been our coldest weather so far, is sitting at 43.1. I did have one bad commute with an accident on a long uphill that I have been slowly trying to recover from.
I am working hard for this mileage! I’m working harder with the cold weather so maybe this is why the difference is small. I’m hoping that I stumbled on a technique to get me 44 mpg in the winter and this will give me closer to 50 mpg in warm weather. I’m chasing Voodoo22’s consecutive 50 mpg tank record. Watch your back Voodoo22… I’m coming after that record!
Woody_Woodchuck is offline   Reply With Quote
Old 01-23-2009, 10:37 AM   #33
BailOut
Steals terrorist's lunch
BailOut's Avatar
That is a topic that has been hashed out thoroughly but the data was lost in the hack. The findings were consistent, though:
If you drive it like you stole it you will see a slight increase in MPG with higher octane fuel but if you drive lighter or are a hypermiler you will see a large decrease in MPG with higher octane fuel.
- Brian
Share the Road
Old 01-23-2009, 10:51 AM   #34
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
In full summer set up i was getting close to 800 kilometers per tank,now with winter tires,and winter formulated gas and only city driving i'm lucky to get 400kms,as for using higher octane gas in a car meant for regular gas?an absurd waste of money.
Old 01-23-2009, 11:15 AM   #35
marcus
toyota
marcus's Avatar
ok i dont get how ur losing half of ur mpg... i guess im not doing too bad with 500km on a 36 liters./ 7 bars this winter 60/40 cty/hwy.
Old 01-23-2009, 01:30 PM   #36
jambo101
jambo101's Avatar
I might be able to get it up to 500kms but that would be getting into the flashing last bar for sure.
-Mileage Thread- -Log your mileage, year, model, color, any problems here... Kal-El DIY / Maintenance / Service 322 07-20-2016 10:07 AM
Sedan better gas mileage than LB? 5 month gas chart included flint_mica_manual General Yaris / Vitz Discussion 24 03-09-2009 08:24 AM
ACEITES Y MANTENIMIENTOS Yaris PTY-507 Central and South America 22 10-01-2007 10:57 AM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 12:32 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
