Old 11-19-2006, 10:44 AM   #1
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
sounds like it could be a bad install, i am yet to come across a bad cc unit that we've installed... especially on a DBW vehicle..
Toyotech is offline   Reply With Quote
Old 11-20-2006, 05:49 AM   #2
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
sounds like a bad conection there you plug it in to the tps to me . I have been thinking about getting one myself that's really the only thing my car needs that it doesn't have
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 12-02-2006, 10:37 PM   #3
gonzo452001
Installed mine this morning works great so far i thought the wire taps were hard to get on there should be special pliers to hold them so you can get them into tight places couldn't squeeze hard enough to get them on by hand it was 25F out there this morning sure that didn't help any.
oem style foglights
Scan GaugeII
Old 12-24-2006, 10:39 PM   #4
TC-LIFTBACK
Drives: 2007 Liftback
Just got mine installed. Ordered it from the distrubutor # on the rosta website. Got it shipped for $190, they said they gave me a discount because I'm in Minnesota.
Some suggestions on the Manual install...
1. You have to remove the steering column to screw the nut onto the cruise control stalk.
2. Make sure that you correctly reconnect those wierd black lever things on the junction box if you remove them to easily get the connections done the T-Taps.
3. I used a 12mm bolt on the steering stalk as a ground (I also used this as a ground on my heated seat install with no problems before (DIY to come soon)
4. I'd print off the instructions in color. It'll be alot easier.
5. I'm not sure what the Yellow wire was supposed to connected to on the Manual transmission one but if anybody know's, please post it in this posting.
6. You should get lots of light in there to be able to work properly.
The cruise works very well and I'm pumped to use it on long car trips. Werd.
TC-LIFTBACK is offline   Reply With Quote
Old 12-25-2006, 08:49 AM   #5
gonzo452001
the yellow wire is for the tach. I also printed out the color instructions
oem style foglights
Scan GaugeII
Old 12-26-2006, 07:37 AM   #6
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I got a kit for Christmas. Can't wait to install it!
Old 12-28-2006, 10:06 PM   #7
gonzo452001
Dim light on all the time
I noticed this morning with my cruise control off there was a very dim light on the LED maybe it has always done this and I just noticed Has anybody else noticed this .Its a rostra I put in my self.
oem style foglights
Scan GaugeII
Old 05-12-2007, 10:34 PM   #8
Snappy
Drives: 2 Yaris Hatchbacks
Yellow Wire
My self install went great except for the yellow tach wire. The instructions were a little unclear, what you are tapping is the backside of the OBD (scanner) port, and the instruction illustration shows the wire you tap is in the upper right of the port. That is true, but it is as viewed from the plug-in face of the gauge (as seen lying on your back with your head on the floormat!) If you are sitting in the driver's seat, looking in the space where the small item box is, the wire you tap is at the upper LEFT of the port. My first test drive resulted in great cruise control, except when I pushed the clutch pedal in, the engine revved up to redline! (At least it was easy to fix, just pop out the small item storage box and re-tap.) With the right wire, pushing in the clutch during cruise results in a real brief rev then the engine speed drops down quick. One tip: to take the panel under the steering column out, unsnap it starting at the top, fold it down, and a hinged bottom piece has two hidden screws that need to be removed. The bottom of the junction box that the main cruise module tapes to is also the main inside fuse box, so I tried to keep the wires off to the side to allow easy fuse box access. I paid 230 for the cruise from the distributor mentioned on the first page of this thread. So far, I like it a lot. You have to turn it on every time you start the car, I guess.
Snappy is offline   Reply With Quote
Old 05-13-2007, 07:22 AM   #9
gonzo452001
I was confussed about that also I looked at somebodys post about installing a tach
oem style foglights
Scan GaugeII
Old 09-18-2007, 03:21 PM   #10
KSIbucky
KSIbucky's Avatar
diy needed
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 11-04-2006, 08:35 PM   #11
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
I love mine...no problems whatsoever
YamilR is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
Liftback - Easiest Way to Get a Tach and Cruise Control... weeze-dog General Yaris / Vitz Discussion 60 10-20-2006 05:40 PM
price for sub/amp install PSU Yaris In Car Entertainment + Electronics (audio / video / alarm) 14 08-09-2006 12:39 PM
