Old 08-22-2006, 01:20 PM   #19
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
Originally Posted by argylesocks
better to find out now, then after you have been doing it for 30k miles.
Absolutely, ignorance when it deals with possibly damaging ur limiting the life of your car isnt good -- esp if one is concerned about the costs that will result out of driving your vehicle in a poor-for-it manner.
Jem_hadar is offline   Reply With Quote
Old 08-23-2006, 12:11 AM   #20
pennystocks
pennystocks's Avatar
Drives: 07 Civic Si Coupe(Black Pearl)
Well, i learned on my 91 Z28 and 97 Trans am 6-speed, that once you replace 3 transmissions, throw-out bearing including slave cylinder, 1-3.23, 1-3.43, 2-4.10 gears, pinion bearing, 2 fuel pumps, 6 sets of tires (only replaced the front tires once on each car ), 3 trans mounts and a throttle cable that when something can break you dont do your best to break it. After all that tho it was all worth it
Hmm, i feel like i missed something...
Maybe its just the sedan for the steering, i dunno.
I'm also gonna ask a mechanic about coasting in neutral hurting the tranny. If the pump runs off the input shaft, then even in neutral the input shaft still spins w/ the engine on. Also the computer knows the trans temp, so if it does overheat the check engine light would come on.
pennystocks is offline   Reply With Quote
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 12:18 PM
Scangauge finaly available pennystocks General Yaris / Vitz Discussion 26 07-10-2006 07:22 PM
