Old 02-20-2009, 05:49 PM   #19
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
i got it to move now but when i push the pedal it sequels a little.
Old 02-20-2009, 05:54 PM   #20
jkuchta
Drives: 2007 Yaris hatch (red)
Check the belt deflection at the midpoint between the crank and the alt pulleys. The deflection on a belt used more than 5 min. is 11-13mm (assuming you're using the old belt). The service manual in the DIY section has the specs and a diagram.
Too much belt tension can kill the water pump bearing.
jkuchta is offline   Reply With Quote
Old 02-20-2009, 06:24 PM   #21
Yoda
Yoda's Avatar
ok got int good but now i have that red battery light. the books says that means its have problems charging...
Old 02-20-2009, 06:26 PM   #22
jkuchta
Is the alternator spinning?
Old 02-20-2009, 06:32 PM   #23
Yoda
Yoda's Avatar
let me check
Old 02-20-2009, 06:34 PM   #24
Yoda
Yoda's Avatar
yes it is. do i need to make it tighter just a bit?
Old 02-20-2009, 06:38 PM   #25
jkuchta
What is the deflection of the belt right now (engine off).?
Old 02-20-2009, 06:55 PM   #26
Yoda
Yoda's Avatar
its 12mm then i again i am using a ruler. there seems to be a very very very small point where it will not sequel and have the battery light off the best i got was a little sequel with the battery light off. you thing driving it a bit will make it go away?
well i go the sequel sound to go away on start up and the battery light but when you give it some gas it sequels
Old 02-20-2009, 07:05 PM   #27
jkuchta
Is it a new belt, or the old one. Chances are that driving it will make the noise go away after a little while it it's a new belt.
Old 02-20-2009, 07:30 PM   #28
Yoda
Yoda's Avatar
i got 5000 miles on it
Old 02-20-2009, 11:59 PM   #29
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
Ive always known squealing ment your belt was too lose.
id3379 is offline   Reply With Quote
Old 02-21-2009, 12:34 AM   #30
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I didn't even mark the original place of the alternator. Just moved it so the belt was tight and good to go!
Old 02-21-2009, 01:14 AM   #31
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
the alternator needs to be moved past where it was before you installed the pulley... the pulley is smaller so there's more slack on the belt mine moved about an inch
before
after
Old 02-21-2009, 07:20 AM   #32
Yoda
Yoda's Avatar
hmm i see i will take care of it later i got ice on my car....
Old 02-21-2009, 11:33 AM   #33
Yoda
Yoda's Avatar
got it fixed and running havent gotten to really get on it yet i will let you all kno later on
Old 02-22-2009, 04:50 PM   #34
Yoda
Yoda's Avatar
WOT
Its nice...its real nice. I mean nice. I got the tq i lost from the header and more.
Now i have a new problem... My thrid gear grinds when i shift into it hard. At normal driving it doesnt but i still feel it just a little
Old 02-22-2009, 05:02 PM   #35
CtrlAltDefeat
I ♥ Yaris
err um.. It shouldn't have messed with that.... maybe you're too eager with the shifts?
Old 02-22-2009, 05:03 PM   #36
CtrlAltDefeat
I ♥ Yaris
but yea, I love my pulley I think it even sounds better
