Old 03-05-2009, 01:43 PM   #1
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Fog Light Help
So I ended up getting the new headlight stalk with fog light control on it and something just isn't right. I have rechecked everything numerous times and for some reason the fog lights only turn on when the high beams are switched on. The fog lights are installed, with one wire to a ground, and the other into the proper pin in the fuse box under the hood. An OEM relay was also installed under the dash, and the new stalk was installed. Any suggestions why this would be happening?
cm07yaris is offline   Reply With Quote
Rear fog light for US '08 3Door Yaris (stick shift9 Stefan DIY / Maintenance / Service 21 04-21-2010 04:30 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
