Old 03-09-2009, 08:16 AM   #1
that's another possibility, but it would be interesting if you could look at the model number on yours, to test WolfWings' theory!
Old 03-09-2009, 05:38 PM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
on both cars the throttle bodies came from japan. there is no american built TB on either car. the chassis may be built here in the us but the parts may not be. i opened up my corolla tb and my yaris tb and both are made by denso japan.
Old 03-09-2009, 05:45 PM   #3
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
car is running great with the new tb set up, no cels what so ever at this point
Cold Air Induction|Blitz SUS POWER Air Cleaner System|2.4L 2AZ-FE Throttle Body|Blitz Compressor System|Full Light weight pulley kit|GReddy Ti-C exhaust System|Blitz Throttle Controller|T/B Coolant Bypass + Gasket Trimmed|Weight deduction|Exhaust Manifold|Center pipe|PCV Bypassed
Yaris T-Sport is offline   Reply With Quote
Old 03-09-2009, 05:48 PM   #4
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
REALLY, toyota parts catalog lists 2 different TB's for corolla/matrix based on vin numbers. my findings were already posted.......
Old 03-09-2009, 05:51 PM   #5
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Where do you see your gains? Low end? Top end?
Old 03-09-2009, 07:42 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Gains are reported to be in the mid- to high-end of the spectrum. I still have to install it to see for myself.
Old 03-09-2009, 10:10 PM   #7
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
wait wait wait.
people with the 1zz tb were getting cel's? i never got one. i did get some oscilation but only in temperatures below freezing.
could u swap the chips from the yaris 1nz to a scion tc tb? because i noticed a greater gain in power and response using the tc TB except i got thee CEL from it.
Old 03-09-2009, 10:55 PM   #8
yarstar
Drives: 2008 Absolute Red HB
Whooppee - you just got lucky. The rest of us had major CELs issues. Mine came on no matter what I did.
The gains seen with mine was major pickup mid to high end. The car really jumped @ 40 mph and continued excelerating from that point on, much stronger than stock.
Drilling out these rivets is a pain, but I'm working on it. I see you also used a allen key bolt so you keep the bolthead size to a minimum. There's one spot of the six that is super close fitting for an 'other than rivet' attachment.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 03-09-2009, 11:06 PM   #9
whooppee777
i'd rather b lucky than good.
im thinking about taking apart my tc throttle body. it sounds like something is loose inside of it. could something b broken inside of it? the 1nz throttle body sounds solid when u shake it, no noises or feelings of movement from the inside
Old 03-09-2009, 06:06 PM   #10
mikenacarato
SIPNDEW
Drives: 15 STI
ok so you found 2 part numbers..good job. my yaris throttle body pn is different than the 08s, was my car made in the usa? i dont think so. denso japan is made in japan.
Old 03-09-2009, 06:12 PM   #11
BLAZINBLUEVITZ
im sorry MR KNOW IT ALL. i guess you can't comprehend what i wrote and i refuse to explain it to you. unsubscribed......
Old 03-09-2009, 06:38 PM   #12
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
#22030-0D030
Mine must be uber special ;)
FunctionSpec is offline   Reply With Quote
Old 03-09-2009, 06:41 PM   #13
mikenacarato
SIPNDEW
Drives: 15 STI
please feel free to explain it to me, ill listen. you said american made throttle body. the throttle body on that car is not made in america. the chassis and body panels are, but electrical and most engine components are still made in japan. go look at the sticker on a new camry or corolla and it says the percentages and what was made where. if they dont have that sticker on it, then ask them and they will go get it
Old 03-11-2009, 05:28 PM   #14
hatchbackkid82
Drives: .
how much do these go for and where can i get one from
Old 03-11-2009, 05:46 PM   #15
yarstar
See post #19, this thread.
Old 03-11-2009, 05:59 PM   #16
hatchbackkid82
Drives: .
Thanks just bought one from the same guy
Old 03-18-2009, 04:10 AM   #17
dallas
Drives: Yaris Hatch /Landrover D2
How much bigger is the new throttle body opening than the intake it bolts to, as the intake side may become the restrictor? From the picture it looks like it has a step so you can't really port match it to the new throttle body.
dallas is offline   Reply With Quote
Old 03-19-2009, 11:24 AM   #18
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
Originally Posted by Jerkratt View Post
would the TRD CAI fit over the TB opening or would i have to "Lip" it?
I'm very sure you can, the other memeber has an TRD intake and he has been running with the new tb.
the pic of the my OEM tube has already been ported .25" bigger
1nz = 2"
1zz = 2.25"
just a report back it's been 11 days since ,my chip swap, cold start idle is around 2000 RPM instead of 3000 before, drops down to around 1000 in a couple of mins, when the car is fully warmed up, it idles at 750 RPM, no CEL the whole time, very happy with the extra mid-nigh end gain, can definitely feel the difference by my butt dyno even off the line, much better mod than an intake or exhaust if you can find one cheap, perhaps I couldn't even feel a difference when I upgraded my intake nor exhaust alone by my but dyno expect the increase of engine noise, but this one, I surely CAN.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
