Old 03-13-2009, 09:27 PM   #1
mrbond
mrbond's Avatar
Originally Posted by turboyaris View Post
I can make you anything you want
The bushings were originally intended to verify that they would work, and then be produced in either urethane or delrin. However, if you are truly interested, I could make you a special set of bushings in aluminum. p.m. me and we could talk more seriously about it. I feel that urethane or delrin would sell better then aluminum because of racing regulations. Also too though, if you were interested in a full set of aluminum bushings, that would allow me to make them all in aluminum, so I could then make them all in delrin or urethane at a later date.
You know, you could DEFINITELY make a killing making molds to make poly or delrin bushings!!! Think: most or all of the people doing autox or just wanting stiffer suspension would love to have that set! It's a good idea, you know. Do try to run with it. For the sake of all Yaris kind.
Old 03-13-2009, 09:31 PM   #2
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
actually delrin is machined, urethane is the only one needing a mold... there is just some care needed in machining the delrin as too much heat in the piece will cause it to thermally expand or the plastic will melt to the cutter... I will keep you all updated on the process.
turboyaris is offline   Reply With Quote
Old 03-13-2009, 09:34 PM   #3
mrbond
mrbond's Avatar
haha, see, i don't know what delrin is. well, in that case, polyurethane molds would be the best bet. maybe start a thread to feel for support for it? if the whole set was under like $200 I would totally be on board.
Old 03-13-2009, 09:45 PM   #4
turboyaris
the only hopes for them coming in that cheap, is if certain bushings could be crossed over to something that say energy suspension already made.
maybe I'm forgetting some bushings, but there is the axle beam bushings, sway bar bushings, the front bushing in the lower control arm, I'm not sure if there is a bushing in the rack and pinion. Any that I forgot?
Old 03-13-2009, 10:01 PM   #5
mrbond
mrbond's Avatar
that pretty much covers all the main bushings. anything more might be overkill...plus you'd have to start tearing apart your car, and i don't think most people would be interested in that just yet ;)
Old 03-13-2009, 10:16 PM   #6
turboyaris
when i get a lower control arm for one of my next projects, i'll have that one done too
Old 03-13-2009, 11:19 PM   #7
2006fronty
2006fronty's Avatar
Drives: 2010 Mazda3 iTouring
I'm pretty sure PTFE is the "plastic" that doesn"t machine well
Aluminum lower control arm maybe?????
Old 03-13-2009, 11:30 PM   #8
turboyaris
no a chromoly lower control arm... fully adjustable ;)
Yea delrin isn't too bad to machine, just saying the things you gotta look out for
DIY - NST shifter bushings kurokoma-kun DIY / Maintenance / Service 1 04-05-2009 08:31 AM
NST Shifter Bushing Kit ruimond Performance Modifications 5 12-06-2008 12:48 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
Aftermarket Short Shifter UPDATES ChinoCharles Performance Modifications 40 05-23-2007 03:17 AM
