Old 05-10-2009, 05:59 PM   #1
1NZYaris1
1NZYaris1's Avatar
Originally Posted by argylesocks View Post
I didn't see anything on your site for an 09 Hatchy... did I miss it??
09 Hatch use's the same lights as the 06-08, but use's different face plates .
09 faceplate's are only available at the dealer's ,for know , probably until next year.
Old 03-22-2009, 11:50 AM   #2
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
whats needed for the factory install, im installing it loosely for now just to have it on, but if i can install it where when i turn the fogs on the indicator on the dash turns on that would be sweet
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 03-22-2009, 06:51 PM   #3
Arkhangel
Arkhangel's Avatar
With the info you have supplied me its getting clearer and clearer...
in cabin wiring still a bit hazy . i like the idea of the OEM Light Stalk
but only if i can get on the cheap lol
Old 03-22-2009, 07:18 PM   #4
1NZYaris1
1NZYaris1's Avatar
plenty of members here have it , just borrow there car for a little while .
the other offer is open to all .
Old 03-22-2009, 08:30 PM   #5
Arkhangel
Arkhangel's Avatar
not many members are from Puerto Rico :P
Old 03-27-2009, 05:33 AM   #6
lunjiaow
lunjiaow's Avatar
Where abouts does the relay go under the dash?
nevermind, i found it.
lunjiaow is offline   Reply With Quote
Old 03-27-2009, 09:44 PM   #7
cyberfrogg
cyberfrogg's Avatar
Drives: Yaris Sedan S
Wait. Where can I get the relay needed for the fog lights?? I'm confused.... Everything's set up for em but I just need that darn relay. I can't find it at chechers, or auto zone..
cyberfrogg is offline   Reply With Quote
Old 03-27-2009, 09:46 PM   #8
1NZYaris1
1NZYaris1's Avatar
Garm has them a long with the wireing ,
Old 03-27-2009, 09:59 PM   #9
cyberfrogg
cyberfrogg's Avatar
I already got the wiring down and I have this exact same kit: http://www.yarisworld.com/forums/showthread.php?t=9473 I just need the relay... I'm so confused. @_@
Old 03-27-2009, 11:34 PM   #10
1NZYaris1
1NZYaris1's Avatar
you can go to toyota but it will cost you dearly , or you can try Garm .
or do a google search,sorry i can't be of any more help .
Old 04-29-2009, 05:37 PM   #11
Metrixx3
Metrixx3
Drives: 09 Yaris Hatchback 5 Door's
Send a message via MSN to Metrixx3 Send a message via Yahoo to Metrixx3
INZYaris1...and garm can't find those placed on the web , could you post links to this placed ??. thanks.
Metrixx3 is offline   Reply With Quote
Old 04-29-2009, 06:07 PM   #12
1NZYaris1
1NZYaris1's Avatar
http://www.trademotion.com/partlocat...07&catalogid=2
or Sparks Toyota http://www.sparkstoyota.com/TRD.aspx
Old 09-12-2009, 10:58 AM   #13
jefferelli
Drives: 08 Yaris HB
Well bought a set of foglights on ebay.. now wishing I would have just bought them at micro image
The switch is not the same size as the others in the center console. I dont feel like dremeling the console just to make a funky long shaped switch fit that will bug me when I look at it and it doesnt match the others. So I was thinking that I might try the fog light Stalk as it would be more convienent anyway. TRD sparks had it for 75 bucks. Has anyone put one of these in and could give me some advice? I have been searching posts and see that it was mentioned you just remove the old and plug in the new. Does this require me to remove the steering wheel also like you need to for the varianble wiper stalk?
Does Micro Image still sell the under the hood red 2 wire connector setup seperatly. I was looking on the site and didnt see it. I could make my own I suppose, just need crimpers and pins.. But was hoping for the convienence of a premade.
Thanks for any help .
jefferelli is offline   Reply With Quote
Old 09-14-2009, 01:44 PM   #14
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
PM Garm (CaliYaris) for the wiring kit alone. He should be able to hook you up.
As for the switch, I have an interesting story. The switch that came with my lights off ebay was a bit faulty. When I would turn them on then off then on again fast, they wouldn't come back on the second time. I'd have to leave them off for like 3 seconds first. Then they'd work again. So from a suggestion from CTScott, I tried just bridging the connection and was able to turn them on and off fast. So I replaced the stupid fog switch with a little general-use rocker on/off switch. I dremeled one of the plastic place-holders to fit the rocker switch and got it in the same spot as I had the actual fog switch (right by the e-brake). So now I can switch it on/off repeatedly fast and they come on each time. And it actually looks A LOT nicer than the big clunky fog button.
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY - fog light install kurokoma-kun DIY / Maintenance / Service 3 09-18-2012 12:52 AM
Rav4 and Highlander fog light parts 1NZYaris1 Items for Sale by private party 5 02-13-2009 10:43 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
